查看: 10025|回复: 31
INTEL D845EPI/D845GVSR主板跑E9什么意思呀?
发表于 2008-12-23 15:45:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
大家好呀,我有一片INTEL  D845EPI/D845GVSR的板
不插显卡,诊断卡跑D3还一直跳,后来插上显卡却跑E9是什么回事呀
不懂,请教下各位高手
发表于 2008-12-23 16:32:24 | 只看该作者 �
INTEL 的Progress Codes
;; XX means match any port 81 code
;; test name format = <feature>_<activitiy>
;; all text after the "," is appended to error message
10XX = CPU_POWERON, Power-on initialization of the host processor (Boot Strap Processor)
11XX = CPU_CACHE, Host processor Cache initialization (including APs)
12XX = CPU_INITIALIZATION, Starting Application processor initialization
13XX = SMM_INITIALIZATION, SMM initialization
21XX = CHIPSET_INITIALIZATION, Initializing a chipset component
22XX = MEM_READING_SPD, Reading SPD from memory DIMMs
23XX = MEM_DIMM_PRESENSE, Detecting presence of memory DIMMs
24XX = MEM_TIMING_PARAMETERS, Programming timing parameters in the memory controller and the DIMMs
25XX = MEM_CONFIGURATION, Configuring memory
26XX = MEM_OPTOMIZATION, Optimizing memory settings
27XX = MEM_INITIALIZATION, Initializing memory, such as ECC init
28XX = MEM_TESTING, Testing memory
50XX = PCI_ENUMERATION, Enumerating PCI busses
51XX = PCI_RESOURCE_ALLOCATION, Allocating resources to PCI bus
52XX = PCI_HOTPLUG_INITIALIZATION, Hot Plug PCI controller initialization
58XX = USB_RESETTING, Resetting USB bus
59XX = USB_RESERVED, Reserved for USB
5AXX = ATA_RESETTING, Resetting PATA/SATA bus and all devices
5BXX = ATA_RESERVED, Reserved for ATA
5CXX = SMBUS_RESETTING, Resetting SMBUS
5DXX = SMBUS_RESERVED, Reserved for SMBUS
70XX = VGA_RESET, Resetting the VGA controller
71XX = VGA_DISABLE, Disabling the VGA controller
72XX = VGA_ENABLE, Enabling the VGA controller
78XX = REMOTE_CONSOLE_RESET, Resetting the console controller
79XX = REMOTE_CONSOLE_DISABLE, Disabling the console controller
7AXX = REMOTE_CONSOLE_ENABLE, Enabling the console controller
90XX = KEYBOARD_RESET, Resetting keyboard
91XX = KEYBOARD_DISABLE, Disabling the keyboard
92XX = KEYBOARD_DETECT, Detecting the presence of the keyboard
93XX = KEYBOARD_ENABLE, Enabling the keyboard
94XX = KEYBOARD_BUFFER, Clearing keyboard input buffer
95XX = KEYBOARD_SELF_TEST, Instructing keyboard controller to run Self Test (PS2 only)
98XX = MOUSE_RESET, Resetting mouse
99XX = MOUSE_DETECT, Detecting mouse
9AXX = MOUSE_DETECT, Detecting presence of mouse
9BXX = MOUSE_ENABLE, Enabling mouse
B0XX = FIXED_MEDIA_RESET, Resetting fixed media
B1XX = FIXED_MEDIA_DISABLE, Disabling fixed media
B2XX = FIXED_MEDIA_DETECT, Detecting presence of a fixed media (IDE hard drive detection etc.)
B3XX = FIXED_MEDIA_ENABLE, Enabling/configuring a fixed media
B8XX = REMOVABLE_MEDIA_RESET, Resetting removable media
B9XX = REMOVABLE_MEDIA_DISABLE, Disabling removable media
BAXX = REMOVABLE_MEDIA_DETECT, Detecting presence of a removable media (IDE, CDROM detection etc.)
BCXX = REMOVABLE_MEDIA_ENABLE, Enabling/configuring a removable media
DXXX = BDS_BOOT_SELECTION, Trying boot selection y (y=0 to 15)
E0XX = PEI_STARTED, Started dispatching PEIMs (emitted on first report of EFI_SW_PC_INIT_BEGIN EFI_SW_PEI_PC_HANDOFF_TO_NEXT
E1XX = PEI_RESERVED, Reserved for PEI/PEIMs
E2XX = PEI_FOUND, Permanent memory found.
E3XX = PEI_RESERVED, Reserved for PEI/PEIMs
E4XX = DXE_ENTERED, Entered DXE phase
E5XX = DXE_DRIVERS, Started dispatching drivers
E5XX = DXE_DRIVERS, Started connecting drivers
E7XX = DXE_WAITING_FOR_USER_INPUT, Waiting for user input
E8XX = DXE_PASSWORD, Checking password
E9XX = DXE_BIOS_SETUP, Entering BIOS setup
EAXX = DXE_TBD, TBD - Flash Update
EBXX = DXE_OPTION_ROMS, Calling Legacy Option ROMs
EEXX = DXE_TBD, TBD - Calling Int 19. One beep unless silent boot is enabled.
EFXX = DXE_TBD, TBD - Unrecoverable Boot failure/S3 resume failure
F4XX = SLEEP_STATE_ENTER, Entering Sleep state
F5XX = SLEEP_STATE_EXIT, Exiting Sleep state
F8XX = EFI_EXIT_BOOT_SERVICES, EFI boot service ExitBootServices ( )  has been called
F9XX = EFI_SET_VIRTUAL_ADDRESS_MAP, EFI runtime service SetVirtualAddressMap (  ) has been called
FAXX = EFI_RESET_SYSTEM, EFI runtime service ResetSystem ( ) has been called
30XX = PEI_CRISIS_RECOVERY_USER, Crisis Recovery has initiated per User request
31XX = PEI_CRISIS_RECOVERY_SW, Crisis Recovery has initiated by software (corrupt flash)
34XX = PEI_LOADING_RECOVERY, Loading recovery capsule
35XX = PEI_STARTING_RECOVERY, Handing off control to the recovery capsule
3FXX = PEI_UNABLE_TO_RECOVER, Unable to recover
发表于 2008-12-23 16:57:38 | 只看该作者 �
不插显卡一直跳D3是没有过内存
发表于 2008-12-23 17:24:22 | 只看该作者 �
INTEL板请先刷BIOS
发表于 2008-12-23 17:39:10 | 只看该作者 �
不用说100%是BIOS问题。并且网上下的BIOS用机器刷进去不能用。只能用一个相同主板的BIOS。用编程机读出来在写在你现在的主板上就可以了。很简单的
发表于 2008-12-23 17:54:49 | 只看该作者 �
应该是BIOS跳线不对,,或是跳线没有了,,检查一下,不行就刷一下,,这个主板的BIOS我有
发表于 2008-12-23 18:03:12 | 只看该作者 �
建议先刷BIOS
发表于 2008-12-23 18:18:08 | 只看该作者 �
BIOS坏了啊,杀
发表于 2008-12-24 00:43:08 | 只看该作者 �
昨天就一片英特尔板的845PESV跑E9,刷BIOS后OK了。建议你先刷BIOS试试
发表于 2008-12-24 12:03:14 | 只看该作者 �
bios问题  刷bios就可以了
发表于 2008-12-24 13:21:00 | 只看该作者 �
刷BIOS是万能的吗? 我觉得有很多都是人为刷坏的!
发表于 2008-12-24 17:56:15 | 只看该作者 �
刷BIOS,INTEL845的主板最为常见。跑E9的基本上都是BIOS资料出错。。
发表于 2008-12-24 18:07:14 | 只看该作者 �
这个问题在前几天已有人提问过了,你搜索一下
发表于 2008-12-25 16:21:19 | 只看该作者 �
先检查跳线  在考虑刷BIOS
发表于 2008-12-28 18:15:17 | 只看该作者 �
回复 6# 王志华 的帖子
你有这个BIOS吗?发给我好不?
我邮箱WERWTY123@163.COM
谢谢
发表于 2008-12-28 23:48:52 | 只看该作者 �
你要的BIOS!!
D845EPI.rar
369.22 KB, 下载次数: 483, 下载积分: 下载分 -2 分, 下载 1 次
发表于 2008-12-29 11:37:58 | 只看该作者 �
谢谢
发表于 2008-12-29 11:56:24 | 只看该作者 �
谁知道754南北桥供电是多少伏呀?
我有个技嘉754的板CPU没有复位
南北桥供电是1.24伏,正常吗?
发表于 2009-1-2 17:30:47 | 只看该作者 �
刷bios吧,intel的板bios爱坏。
发表于 2009-1-11 16:46:03 | 只看该作者 �
我刚也有一块 拿来还是好的  就是显卡坏了  换了个显卡就可以显示了  客户要我在试下他的显卡 就跑E9了 不知道是不是BIOS坏了
