标题: 高手们,点7的这个故障,讨论讨论 [打印本页]
作者: 急速漂移    时间: 2007-6-20 01:42
T>N2,,22
T>No valid SeaDex script in buffer.
Begin Test 02
ASCII logging on
                      Not Power Cycling
                      Not Power Cycling
Zone 00 Head 00 adaptives set to defaults
Zone 00 Head 01 adaptives set to defaults
Zone 01 Head 00 adaptives set to defaults
Zone 01 Head 01 adaptives set to defaults
Zone 02 Head 00 adaptives set to defaults
Zone 02 Head 01 adaptives set to defaults
Zone 03 Head 00 adaptives set to defaults
Zone 03 Head 01 adaptives set to defaults
Zone 04 Head 00 adaptives set to defaults
Zone 04 Head 01 adaptives set to defaults
Zone 05 Head 00 adaptives set to defaults
Zone 05 Head 01 adaptives set to defaults
Zone 06 Head 00 adaptives set to defaults
Zone 06 Head 01 adaptives set to defaults
Zone 07 Head 00 adaptives set to defaults
Zone 07 Head 01 adaptives set to defaults
Zone 08 Head 00 adaptives set to defaults
Zone 08 Head 01 adaptives set to defaults
Zone 09 Head 00 adaptives set to defaults
Zone 09 Head 01 adaptives set to defaults
Zone 0A Head 00 adaptives set to defaults
Zone 0A Head 01 adaptives set to defaults
Zone 0B Head 00 adaptives set to defaults
Zone 0B Head 01 adaptives set to defaults
Zone 0C Head 00 adaptives set to defaults
Zone 0C Head 01 adaptives set to defaults
Zone 0D Head 00 adaptives set to defaults
Zone 0D Head 01 adaptives set to defaults
Zone 0E Head 00 adaptives set to defaults
Zone 0E Head 01 adaptives set to defaults
Zone 0F Head 00 adaptives set to defaults
Zone 0F Head 01 adaptives set to defaults
Head Mask 000F -
Read Bias - Head      0   1   2   3
                      A   A
HiTemp Bias Head      0   1   2   3
                      A   A
Head Mask 000F - Switch to full int.
              Spin Ready
Ref Trk Tan Timing Skew (h0 to h0) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h0) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h1) = 0036 servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = 0022 servo clocks.
Ref Trk Tan Timing Skew (h0 to h2) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h2) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h3) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h3) = 0000 servo clocks.
Calibrating Physical Track 0 on heads 0 thru 1
Calibrating Head 0 ...
GC Seek Error 2 !!!
!!! Adaptives corrupt !!!
AbEnd Test 02
听声音感觉好象磁头突然掉进了一个大坑一样的
固件区卡住了?
还是磁头飞出来了?
高手们都有什么见解
都怎么去解决的呀?
作者: 张先生    时间: 2007-6-20 07:09
注意最后的几句:
GC Seek Error 2 !!!
AbEnd Test 02
做不成了。
作者: 孤帆远影    时间: 2007-6-20 17:31
应该是头的问题
作者: zhywan988    时间: 2007-7-2 19:27
磁头有问题,上面的英文提示大概是说0磁头出现错误,请重置。
作者: alol    时间: 2007-7-12 23:37
一部分是头的问题
但有一部分不是
作者: 火速挪移    时间: 2007-10-16 01:48
有部分不是头坏的
可以完美解决
就用指令就可以
