ZXCVWtest
7200.7跑SF跑完03直接到4D
缘来这么难
2008-12-14 21:01
7200.7跑SF跑完03直接到4D
正常启动后提示
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Head Mask 000F - Switch to full int.
Spin Ready
Error Reading Reserve Track Defect List
F>
在F级跑SF后过03就直接到4D,一会就停在4E了
Begin Test 03
ASCII logging on
..............................省略。
Actuator Geometry Test ...
Geometry Difference = 1 Microseconds
!!! Adaptives corrupt !!!
ASCII logging off
Code - 43 Track 0E914.0.08C Sns 08C Rty FFFF.20.20FF Rtf 1802 LBA 0918922C
Code - 43 Track 0E914.0.08C Sns 08C Rty FFFF.20.20FF Rtf 1822 LBA 0918922C
AbEnd Test 03
Begin Test 4D
ASCII logging on
Not Power Cycling
ASCII logging off
ASCII logging on
Fail Log Summary .....
Cum Health = 608C
Code - 43 Track 0E914.0.004 Sns 004 Rty FFFF.20.20FF Rtf 1802 LBA 0918922C
...................已省略
Code - 43 Track 0E91B.1.108 Sns 108 Rty FFFF.20.20FF Rtf 1822 LBA 0918922C
Head #Defect #Align radial defect(%) EC59 EC60
0 . . Code - 43 Track 0E91C.1.227 Sns 227 Rty FFFF.20.20FF Rtf 1822 LBA 0918922C
1 . . Code - 43 Track 0E91C.1.227 Sns 227 Rty FFFF.20.20FF Rtf 1822 LBA 0918922C
Power Cycling
ASCII logging off
Code - 43 Track 0E91B.1.190 Sns 190 Rty FFFF.20.20FF Rtf 1822 LBA 0918922C
Code - 43 Track 0E91B.1.190 Sns 190 Rty FFFF.20.20FF Rtf 1802 LBA 0918922C
AbEnd Test 4D
Begin Test 39
ASCII logging on
ASCII logging off
Code - 43 Track 0E917.0.0C1 Sns 0C1 Rty FFFF.20.20FF Rtf 1822 LBA 0918922C
Code - 43 Track 0E917.0.0C1 Sns 0C1 Rty FFFF.20.20FF Rtf 1802 LBA 0918922C
AbEnd Test 39
Begin Test 4E
ASCII logging on
Not Power Cycling
ASCII logging off
ASCII logging on
Code - 43 Track 0E914.0.00C Sns 00C Rty FFFF.20.20FF Rtf 1822 LBA 0918922C
02: Log Read Not OK
.........................已省略。
6F: Log Read Not OK
Total Cert Time = 00:00:00
ASCII logging off
Code - 43 Track 0E91B.0.0A5 Sns 0A5 Rty FFFF.20.20FF Rtf 1802 LBA 0918922C
Code - 43 Track 0E91B.0.0A5 Sns 0A5 Rty FFFF.20.20FF Rtf 1822 LBA 0918922C
AbEnd Test 4E。 请哪位帮着看看下面该怎么解决呀??固件已经换过了
缘来这么难
2008-12-15 07:51
大家谁知道ST砍0头的ROM哪里有下载的呀??
仗剑闯天涯
2008-12-18 00:22
你说的没错,很可能是0头坏了。不过,头全坏的可能也是有的。
M14好像没人放出砍0头的ROM,因为M14的ROM是集成在芯片上的。
要砍头,只有换块S.15的板试试,有S.15砍0头的ROM
