标题: GA EP31 DS3L reset led on the card test plink [打印本页] 作者: Aquafina 时间: 2014-11-21 02:46 标题: GA EP31 DS3L reset led on the card test plink 本帖最后由 Aquafina 于 2014-11-21 02:52 编辑
Motherboard GA Which is very Easy Repair -. I Think so BUT i MUST say this Case That "WOW shit, Again !!!" You guys CAN See. I have Been checked RAM, CHIPSET NB, SB, CPU supply and reup BIOS, RESET signal from I / O. All of these things are good. But till nothing change. I Have no ideas about this case, so would you guys show me how to solve it. Thanks you guys so much.
yes. the reset lamp go on and off again and again 作者: 脚踏实地... 时间: 2014-11-26 09:24
先查一下主板有没有氧化,然后再刷bios 如果不行 最后就是桥的问题了 这种一般都是修不了的 看运气作者: 周海 时间: 2014-11-26 09:36
不懂英文怎么回答啊作者: Aquafina 时间: 2014-11-26 22:14
if you can solve it that you can show me how to do by your language. That is not problem 作者: 黄祺益 时间: 2014-12-5 12:55
技嘉主板复位闪 常见的是下面的原因引起
COM
BIOS
IO
时钟 作者: Aquafina 时间: 2014-12-10 00:15
