【已修复】小影霸R550E花屏测试结果
盱眙桂林
2008-11-28 18:45
【已修复】小影霸R550E花屏测试结果
如题:全面测试结果
RV370/M22 A12b (0x5b63) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID G0VB001
1024 x 768 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDB0 10 32 33 48 49 50 51 53 ...
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
failing bit : MDB0 8 9 10 11 12 13 14 15 ...
[3 ] RW column (GUI) : FAIL
Error ID G0VB024
[4 ] RW page (GUI) : FAIL
Error ID G0VB025
[5 ] RW channel (GUI) : FAIL
Error ID G0VB028
[6 ] Data mask : FAIL
Error ID G0VB006
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
[7 ] Macro + Micro8x2 tiling read : FAIL
Error ID G0VC006
[8 ] Macro + Micro4x4 tiling write : FAIL
Error ID G0VC009
[9 ] Byte swap macro+micro8x2 read : FAIL
Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write : FAIL
Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write : FAIL
Error ID G0VC052
[12 ] Macro+Micro4x4 alignment read : FAIL
Error ID G0VC057
[13 ] Movblit, 4 align, T : FAIL
Error ID G0TR055
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 8 9 10 11 12 13 14 15 ...
[14 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID G0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 1 2 3 4 5 6 7 9 ... MDB0 8 9 10 11 12 13 14 15 ...
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 2 4 5 6 7 8 9 10 ... MDB0 8 9 10 11 12 13 14 15 ...
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
failing bit : MDA0 1 2 3 4 7 8 9 10 ... MDB0 8 9 10 11 12 13 14 15 ...
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
[15 ] Line slopes/dir/P/solid : FAIL
Error ID G0TR010
显存正反各四颗,哪颗坏了?
(9.52 KB, 下载次数: 9)
下载附件
保存到相册
2008-11-29 10:51 上传
(9.16 KB, 下载次数: 5)
下载附件
保存到相册
2008-11-29 10:51 上传
正面排列:U32 U35
U34
U33
反面排列:U36 U31
U30
U29
先换掉U35再测MDB 32 33 34 35 36 37 38 39 报错,又换掉U36再测MDB 48 50 ,加焊U36后OK
修不来主板
2008-11-28 22:10
排列和料号
最好发个照片
盱眙桂林
2008-11-28 22:17
把曾版点拨一下,测试结果中那么多,关键看哪些测试结果,再根据图纸看显存定位。
踪影
2008-11-30 11:11
回复 #3 盱眙桂林 的帖子
是啊,哪位大哥能否讲讲每项测试都代表什么意思?
晨翔电脑
2008-12-10 23:05
我快晕了,但是最后LZ说换掉了U36后还出错,加焊后就OK了,我觉得怎么怪怪的呀, 是因为什么呢
