MR=0 TA=0 FcFb=0 OTRd=0 EarlyRd=0 Splash=0 Rload=0 VGA=0
ForcedSync=0 Burnish=0 FIR=0 RunOut=0 MaxECC=0 ECC2=0 ECC1=0 ECC0=0
Data=00 Write=00 GlobalData=00 RetryMode=00
Single trk - Hd 0, 2EE0 mS cmd timeout
Write unsafe is now disabled.
Write unsafe is now enabled.
UStack=AE00
OkEnd Test 04
Begin Test 07
UStack=AE00
HEAD 1x WEIGHTS 2x WEIGHTS 3x WEIGHTS 24x WEIGHTS
00 -0503 6E79* 034E -0042 -0112 -0402 000A -05E4
The AFC 1x sum of squares weight limit is HEX 2710
The AFC 2x sum of squares weight limit is HEX 1388
The AFC 3x sum of squares weight limit is HEX 1388
The AFC 24x sum of squares weight limit is HEX 1388
UStack=AE00
AbEnd Test 07
Begin Test 4E
UStack=AE00
