标题: Need Help [打印本页]
作者: mohannarwade    时间: 2014-7-8 19:57
标题: Need Help
How to use RST pro usb software and which tool is needed to run this software
作者: A55    时间: 2014-7-9 20:33
POOR SON, YOU NEED WINHEX  WRITE THE RST IMG 。IF you fail, you may add my qq . I CAN HELP YOU REMOT...
