No Windows 8.1 Settings were harmed in the making of this ISO
No Programs are added to Windows
No Registry Settings were modified
No Unattended Settings were added to the ISO
Installation Indexes:
Windows 8.1 (Core) x64 / KMS-Activated
Windows 8.1 (Core) N x64 / KMS-Activated
Windows 8.1 (Core) Single Language x64 / KMS-Activated
Windows 8.1 Pro x64 / KMS-Activated
Windows 8.1 Pro N x64 / KMS-Activated
Windows 8.1 Pro with Media Center x64 / KMS-Activated
Windows 8.1 Pro VL x64 / KMS-Activated
Windows 8.1 Pro N VL x64 / KMS-Activated
Windows 8.1 Enterprise x64 / KMS-Activated
Windows 8.1 Enterprise N x64 / KMS-Activated
Tools used:
imagex for /flags "ProfessionalWMC" setting and index renames
dism for set-edition for ProWMC, KB integration, install.esd export
oscdimg for ISO mastering with MS's default -u1 option
Info folder added to Windows Setup folder to annoy credit theives
Features:
Non-Activated and Pre-Activated indexes. Take your pick.*
*Uses custom AutoKMS_VL_ALL folder in Windows directory. You can
uninstall the daily task there if you wish to use a different
activator later. I've included the uninstall script
Highly Compressed install.esd recovery compression format
UEFI boot information added to ISO boot data
Notes
v1 was missing the non-activated ProWMC index. Nothing else was wrong
with it. You don't need to download this if you don't want the ProWMC
index. Nothing is different except the additional index and a slightly
newer version of the activator. If you have v1, this activator will
likely not fix any issues you have with it
First proper Win81AIO with pre-activation
All indexes use original MSDN 9/9 Win8.1 isos with integrated hotfixes
Added ei.cfg to sources\ directory. You *HAVE* to extract the iso and
delete the file if you want to upgrade from a previous version of
Windows. Use the win81-pkeys.txt on the ISO for install keys
CODYQX4, mikmik38, nosferati87, deagles, hotbird64, etc - Activator*
*Honestly, many more people worked on the project, but I can't name
them all. There's too many
murphy78 - Testing, Activator work, Sysprepping and ISO design
Office Professional Plus 2013 enables you to work together even better by
giving you more control over compliance, new tools for analyzing and sharing
data, and more possibilities for communication. Plus, Access, Lync and InfoPath
are included in the suite
New capabilities for email and compliance
With Team Mailbox, users can add mail and documents to a public folder managed
by IT via Exchange and SharePoint. Data Loss Prevention informs users and blocks
email messages if they contain information marked sensitive by IT. Now you can
encrypt email messages when sending then to recipients inside and outside of your
organization. IT can enable or disable recording of Lync meetings via group policy
and archive recorded meetings, including IM conversations, to SharePoint
New possibilities for working with data
Explore different cuts and views of your data with a click, and discover new insights
hidden in your data. With one click, conduct a cross-tab analysis of large datasets
and get a 360? view of what your data can show you. Trying to predict future trends?
A good place to start is to look at the historical time series data. Now you can pull up a
chart showing the trend based on the historical data. To help prevent fraud, the new
Excel add-in scans spreadsheets and performs diagnostics for errors, hidden information
and broken links, and it compares workbooks looking for inconsistencies. You even have an
audit trail of the changes in the spreadsheet. You can to extract the PowerPivot model to
Analysis Services with the new PowerPivot add-in
New opportunities for communicating
Users can put a Lync call on hold and answer or continue a conversation on another Lync
call. Enjoy high quality voice and video experiene over virtual desktop infrastructure (VDI)
with Lync. With Lync, you can trace malicious calls. Reach potential customers faster with
support for a call center scenario, in which a group of phones rings when a single number is
dialed. Now there?s support for a small branch office as an extension to the main branch of
your public switched telephone network (PSTN)
