标题: 老罗,给点思路 [打印本页] 作者: 缔造神话 时间: 2014-4-24 11:11 标题: 老罗,给点思路 硬盘扫描无坏道,主板能正常开机,进PE系统,就是进不了系统,重装也不行,重建引导记录也不行,提示:windows could not because of a compter disk hardware configuration problem could not from the selected boot disk check boot path and disk hardware please check the windows documentation about hardware disk configuration and your hardware reference manuals for additional information
怎么解决? 作者: 罗工SAS 时间: 2014-4-24 13:53
清一下日志。作者: 缔造神话 时间: 2014-4-24 15:28
额 有点麻烦,后面直接把XP装成WIN7的系统就好了。
