RAM:
HDD Info reading........................ : Ok
Heads number............................ : 6
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1980
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 25.12E
ROM generation.......................... : 25.13E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00250012
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 377 653
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00250012
Service area:
Permanent overlay....................... : Loaded
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
HDD ID reading.......................... : Ok
Solve "slow responding" problem
HDD ID writing.......................... : Ok
Relo-List clearing
Defect candidates reading............... : Ok
Defect candidates writing............... : Ok
It needs to switch power OFF and ON to restart HDD
Translator regeneration
Regeneration method..................... : Use P-List only
P-List Copy 0........................... : Ok
P-List Copy 1........................... : Ok
Completed
Summary Error Log....................... : Ok
Self Test Log........................... : Ok
Other S.M.A.R.T. logs................... : Ok
专修一切正常,刚刚把第一次用过的磁头装到第二个好盘上,出现了客户一样的故障,看来还是头的问题作者: 烦恼90后 时间: 2014-3-13 22:14
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 0,1,2,5,6,7
Head 0.................................. : Ok
Head 1.................................. : Error W : 0;R : 1980
Head 2.................................. : Error W : 0;R : 1
Head 5.................................. : Skip
Head 6.................................. : Skip
Head 7.................................. : Skip
Heads test
Heads to test........................... : 5,6,7
Head 5.................................. : Error W : 2
Heads test
Heads to test........................... : 6,7
Head 6.................................. : Error W : 2
Heads test
Heads to test........................... : 7
Head 7.................................. : Error W : 2
Heads test
Head 0.................................. : Ok 作者: 烦恼90后 时间: 2014-3-13 22:16
搞的头大了{:4_91:}作者: 罗工SAS 时间: 2014-3-14 16:05
开始不能读,换了磁头,什么都没操作,就能读取30G数据,这个证实是磁头坏了,读30G又把磁头读坏了,运气太不好了吧。
一般固件也会引起全盘坏道。作者: 芯超科技小俊 时间: 2014-3-14 21:56
你换了头以后,直接用UDMA分头拷贝即可。作者: 烦恼90后 时间: 2014-3-15 15:38
