标题: 最近启动后花屏一会不断会死机 mats测试 [打印本页]
作者: 酷裳衣阁    时间: 2014-1-25 11:27
  1. MATS version G98_BETA1.  Testing G92 with 384 MB of memory.
  2.    LANE    EB0 READ ERR EB0 WRT ERR  UNKNOWN ERR
  3. ---------- ------------ ------------ ------------
  4. FBB[31: 0]           0            0            0
  5. FBB[63:32]           0            0            0
  6. FBC[31: 0]           0            0            0
  7. FBC[63:32]           0            0            0
  8. FBD[31: 0]           0            0            0
  9. FBD[63:32]           0            0            0
  10. External Bank 0 Failing bits:
  11.    None
  12. Read    Error Count: 0
  13. Write   Error Count: 0
  14. Unknown Error Count: 0
  15. No errors logged.
  16. No errors logged.
复制代码
启动是没有花屏 启动后 鼠标指针附近有方块  不定时出现显示器驱动重置  然后黑屏 一会就会死机  win7 64
换过各种驱动      如果禁用显卡 各种现象消失
作者: 伥明    时间: 2014-1-25 17:41
换个显卡试试
作者: 酷裳衣阁    时间: 2014-1-25 21:46
  1. [2013-1-25 下午 12:07:48] Test started for "主显示器驱动程序 (NVIDIA GeForce 9600 GSO)"...
  2. Trying 16bpp RGB:565 mode...OK
  3. TEST CANCELED
  4. Changing video mode to 640x480x16...OK
  5. [2013-1-25 下午 12:08:53] Test started for "主显示器驱动程序 (NVIDIA GeForce 9600 GSO)"...
  6. Trying 16bpp RGB:565 mode...OK
  7. Trying 16bpp RGB:555 mode...OK
  8. Trying 16bpp BGR:565 mode...NOT SUPPORTED (Code: 88760091)
  9. Trying 32bpp RGB:888 mode...OK
  10. Trying 32bpp BGR:888 mode...OK
  11. [2013-1-25 下午 12:16:58] Pass completed (0 errors found).
  12. Trying 16bpp RGB:565 mode...OK
  13. Trying 16bpp RGB:555 mode...OK
  14. Trying 16bpp BGR:565 mode...NOT SUPPORTED (Code: 88760091)
  15. Trying 32bpp RGB:888 mode...OK
  16. Trying 32bpp BGR:888 mode...OK
  17. [2013-1-25 下午 12:25:01] Pass completed (0 errors found).
  18. Trying 16bpp RGB:565 mode...OK
  19. Trying 16bpp RGB:555 mode...OK
  20. Trying 16bpp BGR:565 mode...NOT SUPPORTED (Code: 88760091)
  21. Trying 32bpp RGB:888 mode...OK
  22. Trying 32bpp BGR:888 mode...OK
  23. TEST CANCELED
复制代码
VMT测试
作者: 伟仔仔    时间: 2014-1-26 12:02
显卡金手指擦一下
作者: 酷裳衣阁    时间: 2014-1-26 13:14
换成Xp后现象消失 会是系统出现的冲突问题吗
作者: 酷裳衣阁    时间: 2014-1-27 12:14
又出现花屏了 难道真是显卡要挂的表现 真不是时候
作者: 余乐乐    时间: 2014-10-21 11:53
加焊显卡实施
