标题: Seagate .11 Generations often repair disk "busy Short Point [打印本页]
作者: Chinafriend    时间: 2014-1-18 19:33
.11 Generations oftenrepair disk "busy" when the following error:
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif
Methods under thecommand input any information, appear above suggest, this time you can try thefollowing on the board "red dot" to deal with short-circuited againoperation.
Currently the board typefound in the following series:
PCB No.: 100 512 588 (below)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image003.jpg
PCB No.: 100 475 720 (below)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image005.jpg
PCB No.: 100 504 364 (below)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image007.jpg
PCB No.: 100 496 208 (below)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image009.jpg
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image011.jpg
PCB No.: 100 466 725 (below)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image013.jpg
PCB No.: 100 466 524 (below)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image015.jpg
PCB 100,466,824 (below)
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image016.jpg
Note: short-order andmethod
First, remove thecircuit board (from the disc body)
Shorted wiring short,the welding method can be used, then the installation accessories K11 busyrepair process repair shorted state at
Briefly explain that,first circuit board according to the picture above the red dot short circuit,then bare board off the motor, heat exchange to the plate body, open motor,under 级 1 N1 reset SMART,remove the short-wiring board, finished
作者: suyongkeng    时间: 2014-1-21 15:54
楼主你在写葵花宝典么怎么全是英文到底是想说神马东西啊小弟我英文不大好建议翻译一下
作者: Chinafriend    时间: 2014-1-22 01:16
My Friend my english is not so good...
作者: Chinafriend    时间: 2014-1-24 13:35
friend my english is not good.
作者: 罗工SAS    时间: 2014-2-10 18:17
英文大概意思懂,但是看不到图片。
固件门硬盘一直忙,可以按照论坛上的处理固件门的方法处理一下看看。
作者: 芯超科技小俊    时间: 2014-2-10 19:18
楼主是要告诉我们11代盘,忙通病各种电路板的短接点,但是图片没有发成功。
