标题: 请教ttl线刷W308R [打印本页] 作者: yianjp 时间: 2013-10-23 12:04 标题: 请教ttl线刷W308R 请教一下 我的W308R ttl 到 Starting program at 0x80001000 就不动了,这是哪的问题,怎么解决啊
Decompressing...done
CFE version 5.100.138.3 based on BBP 1.0.37 for BCM947XX (32bit,SP,LE)
Build Date: 2011-05-26 10:33:50 4 (richard@aeteam.com)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 131072(0x20000)
Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.100.138.3
CPU type 0x19749: 300MHz
Tot mem: 16384 KBytes
