标题: ST 7200.4做自校的停在aaaaaaaaaaaaaaaaaaaaaaaaaaaaa [打印本页] 作者: 智岛电脑 时间: 2008-9-26 11:13 标题: ST 7200.4做自校的停在aaaaaaaaaaaaaaaaaaaaaaaaaaaaa 这个盘是我以前乱做自校做坏的,这几天上ST的课,就拿出来练手。
大家帮看看这个盘还有救不,下面是这个自校的流程:
T>N2,AA,22
T>VALID Cert Disk Code Detected - Revision # 3.75
Cert Table loaded
Begin Test 02
ASCII logging on
Not Power Cycling
Not Power Cycling
Zone 0 Head 0 adaptives set to defaults
Zone 0 Head 1 adaptives set to defaults
Zone 1 Head 0 adaptives set to defaults
Zone 1 Head 1 adaptives set to defaults
Zone 2 Head 0 adaptives set to defaults
Zone 2 Head 1 adaptives set to defaults
Zone 3 Head 0 adaptives set to defaults
Zone 3 Head 1 adaptives set to defaults
Zone 4 Head 0 adaptives set to defaults
Zone 4 Head 1 adaptives set to defaults
Zone 5 Head 0 adaptives set to defaults
Zone 5 Head 1 adaptives set to defaults
Zone 6 Head 0 adaptives set to defaults
Zone 6 Head 1 adaptives set to defaults
Zone 7 Head 0 adaptives set to defaults
Zone 7 Head 1 adaptives set to defaults
Zone 8 Head 0 adaptives set to defaults
Zone 8 Head 1 adaptives set to defaults
Zone 9 Head 0 adaptives set to defaults
Zone 9 Head 1 adaptives set to defaults
Zone A Head 0 adaptives set to defaults
Zone A Head 1 adaptives set to defaults
Zone B Head 0 adaptives set to defaults
Zone B Head 1 adaptives set to defaults
Zone C Head 0 adaptives set to defaults
Zone C Head 1 adaptives set to defaults
SkpCylList deleted
Sys= 7000-7028 02B9 SPTK on sys trks
<empty>
drive must be reformatted
Zone 0: 0015 - 17AF 833 552.156
Zone 1: 17B0 - 2FE0 833 552.156
Zone 2: 2FE1 - 40F0 833 552.156
Zone 3: 40F1 - 5700 784 510.588
Zone 4: 5701 - 696B 784 510.588
Zone 5: 696C - 7D00 718 477.647
Zone 6: 7D01 - 8B8B 686 454.117
Zone 7: 8B8C - 9B24 653 435.294
Zone 8: 9B25 - A9D6 616 414.117
Zone 9: A9D7 - BA00 588 385.882
Zone A: BA01 - C4BA 548 371.092
Zone B: C4BB - D105 522 352.941
Zone C: D106 - DC91 490 330.756
Total LBAs = 04C66911
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, VCO=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
No entries in Log
Head Mask 000F -
Read Bias - Head 0 1 2 3
E E
HiTemp Bias Head 0 1 2 3
B B
Switch to full int.
Spin Ready
All Hds 0-1, All Cyls 0015-DC91, Rnd data
EP=0, TA=0, HiGain=0, OTRd=0, Early Rd=0, Splash=0, Reload=0, VCO=0, MRBias=0
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=1, ECC 1=1, ECC 0=1
Data=02, Write=40, ID=1E
Napa Srvo Table
Head Addr Ctrl VGA SATT Tap5 Tap6 Tap3 Tap7 Tap2 Tap8 Tap9
00 FA06 50 3C E8 8D A1 D4 9B 1B CD 85
01 FA1A 50 43 E8 8B 9F D0 96 1A C6 7E
Adapt Servo Zone 07
Adapt Servo 9358.00
Adapts Loaded
Napa DATA load
