| POWER PLANE | VOLTAGE | DESCRIPTION | CONTROLSIGNAL | ACTIVE IN |
| VIN | +10V~+19V | MAIN POWER | ALWAYS | ALWAYS |
| +VCCRTC | +3V~+3.3V | RTC POWER | ALWAYS | ALWAYS |
| +3VPCU | +3.3V | EC POWER | ALWAYS | ALWAYS |
| +5VPCU | +5V | CHARGE POWER | ALWAYS | ALWAYS |
| +15V | +15V | CHARGE PUMP POWER | ALWAYS | ALWAYS |
| +3V_S5 | +3.3V | LAN/BT/CIR POWER | S5_ON | S0-S5 |
| +5V_S5 | +5V | USB POWER | S5_ON | S0-S5 |
| +5V | +5V | HDD/ODD/Codec/TP/CRT/HDMI POWER | MAINON | S0 |
| +3V | +3.3V | PCH/GPU/Peripheral component POWER | MAINON | S0 |
| +1.5VSUS | +1.5V | CPU/SODIMM CORE POWER | SUSON | S0-S3 |
| +0.75V_DDR_VTT | +0.75V | SODIMM Termination POWER | MAINON | S0 |
| +VGFX_AXG | variation | Internal GPU POWER | GFX_ON | S0 |
| +1.8V | +1.8V | CPU/PCH/Braidwood POWER | MAINON | S0 |
| +1.5V | +1.5V | MINI CARD/NEW CARD POWER | MAINON | S0 |
| +1.1V_VTT | +1.05V or +1.1V | CPU VTT POWER | MAINON | S0 |
| +1.05V | +1.05V | PCH CORE POWER | MAINON | S0 |
| +VCC_CORE | variation | CPU CORE POWER | VRON | S0 |
| LCDVCC | +3.3V | LCD POWER | LVDS_VDDEN | S0 |
| +5V_GPU | +5V | SWITCHABLE PWM IC POWER | dGPU_PWR_EN# | Discrete enable |
| +GPU_CORE | +0.9V~+1.1V | GPU CORE POWER | +3V_D | Discrete enable |
| +GPU_IO | +0.9V~+1.1V | GPU I/O POWER | PG_GPUIO_EN | Discrete enable |
| +1.5V_GPU | +1.5V | VRAM CORE POWER | PG_1.5V_EN | Discrete enable |
| +1.8V_GPU | +1.8V | GPU_CRE/LVDS/PLL POWER | +1.5V_GPU | Discrete enable |
