Shut down the computer.
Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
Release all the keys and the power button at the same time.
Press the power button to turn on the computer.
PRAM RESET
Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step
Turn on the computer.
Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
Hold the keys down until the computer restarts and you hear the startup sound for the second time.
Release the keys.作者: liaochengbang 时间: 2013-8-24 14:19
哥,来点汉语的呗,英文的咱不懂啊作者: taxuewuhen 时间: 2013-8-24 14:41
