Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
3.03 04-08-05 16:03
(P)PATA Reset
Master with Non-conforming Slave
3.03 04-08-05 16:03
(P)PATA Reset
AT Er 00 Nwt Er 37 RdWr 0001e.00.02ab
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 000099a0 ff 000099a0.3.af0 0009 0000 0000 0000
AutoRd Err 43 at 00001e.00.02ab
SCAN Error
AT Er 00 Nwt Er 43 RdWr 118e5.00.01ad
CE Log EC=43 Rtype=24 OV=0 STStatus0
AT Er 00 Nwt Er 43 RdWr 118e5.00.01b4
AT Er 00 Nwt Er 37 RdWr 118e5.00.01c3
AutoRd Err 43 at 0118e5.00.01c3
SCAN Error
T>Age=50 Type=18 MxCyl=1B5F9 MxHd=3 MxSct=470 BSz=2000 TCode=FDFBFCFA
敲盘时显示:
4096k x 16 buffer detected
TONKA - 1_Disk S.00 04-08-05 16:00
Spin Ready
作者: 孤帆远影 时间: 2008-9-10 15:03
用PC3000灯泡修呀作者: 浏览者 时间: 2008-10-27 19:25
业余级,没有PC3K,有网上下的ST_MEM软件和破解的春花,
前天无意中按了f回车显示
F>f
OK
OK
OK
OK
OK
OK
OK
Check sum Error
是什么意思???
再加电不敲盘了,显示F>
Interface task reset
1024k x 16 buffer detected
MASKROM - 1_Disk M-20 12-07-03 15:39
请教怎样转入T级?(ST-MEM)谁有固件的帮忙发个,谢过了!!
用网上说的ST-MEMF级转T,转不了。
