我在寻找的绘图是“Fujitsu MISTLETOE” the real Fujitsu lifebook P7230 board.
Shef作者: 月饼 时间: 2013-5-24 23:06
根据你对时钟芯片和芯片组的描述,Inventec PORTLAND 10\10G
就是一样的,但是你认为不一样,是指哪里不一样呢?
Google Translate:
Based on your clock chip and chipset description , Inventec PORTLAND 10 \ 10G
Is the same, but you do not think the same, is not the same as where it ?作者: Shef 时间: 2013-5-28 05:44
Inventec portland 10\10G is 945GM chipset with ICS9LPRS316
Fujitsu P7230 (=Fujitsu "MISTLETOE"). has 945GMS (Ultra Low Voltage) chipset and ICS9LPR311.
Those boards has nothing in common,not even one part is same, different power supplies, different KBC, different clock, different CPU....etc.
Inventec Portland IS 6050A2076901-MB and that IS Toshiba M115 board. (Source http://vlab.pp.ru/viewtopic.php?t=10355)
Everyone is describing it wrong.
