Planar parity.) (内存奇偶校验出错) 1. Go to Memory Checkout 2. DIMM car*. 3. Detach the expansion unit if it is attache* to the computer.4. System boar*.
I/O parity.) 1. Go to Memory Checkout 2. Expansion unit or port replicator. 3. System boar*.
Har* *isk passwor* was not set even though the supervisor passwor* is set.) (超 级用户密码已设,但硬盘密码没有设置) 1. Set the passwor* for har* *isk *rive.(设置硬盘密码)| 欢迎光临 迅维网 (https://www.chinafix.com/) | Powered by Discuz! X3.4 |
