标题: F3用指令修改缺陷列表 [打印本页]
作者: 286763430    时间: 2013-5-15 07:57
标题: F3用指令修改缺陷列表
------------------------------------------Modify Track Defect List (Level 2 'F')---------------------------------------------                                                          修改磁道缺陷列表       F3 2>F
  Description:
     详解:
    The Modify Track Defect List command
           修改缺陷列表指令
    modifies the defect list for the specified sector(s).
                 修改缺陷列表指定扇区
  Quick Help:
   快速帮助:
    "ModTrkDfctLst, F[PSctr/LBA],[Action]";
   “修改缺陷列表,F扇区/LBA值,操作(加入/移除)
  Input Parameters:
     输入的参数:
    0 - Physical Sector or LBA to Modify.
            用物理扇区或LBA值来修改
        If Parameter 1 is A1, B1, C1, or F1, this value is an LBA.
        如果参数1是A1,B1,C1,或F1,该值是一个LBA。(A1,B1,C1,F1的功能请看下面1 - Defect List Action)
        If parameter 1 is some other value, this parameter is the physical sector number of the block to be affected.  The         cylinder and head come from the current address.
        如果参数1是一些其他的值,这个参数就是会受到影响的某块的物理扇区号。柱面和磁头来自当前地址。
          Type:    Unsigned 32-bit value
          类型:      无符号的32位值
          Range:   0 to 0xFFFFFFFF
(扇区/LBA)范围:   从0到0xFFFFFFFF
          Default: 0
          初始值: 0扇区/LBA
          Note:    The track and head used are the current track.  When working with sectors
          注意:   that are already alted, it is best to use the LBA mode actions (B1 and C1
                   below) .
                   这句话的意思是:如果当前磁头运行在记录ALT列表的扇区上,那么最好使用LBA模式进行操作。
                  (下面的B1和C1—)
    1 - Defect List Action.
         缺陷列表的操作
        Parameter 1 specifies the format action to be taken. The valid choices are:
                    参数1指定的格式应采取的操作。                 有效的选择:
          A - Add Sector to Alternated Sector List
          A -       添加扇区到ALT列表
          A1 - Add LBA to Alternated Sector List
                    添加LBA到ALT列表
          B - Add Sector to Pending Sector List
                    添加扇区到P列表
          B1 - Add LBA to Pending Sector List
                    添加LBA到P列表
          C1 - Remove LBA from Alternated Sector List
                    删除LBA从ALT列表
          F1 - Remove LBA from Alternated Sector List ( same as C1 above )
                    从ALT列表删除LBA                    与上面的C1相同
          Default: 0x0C1
  Output Data:
  输出的数据:
    If an error occurred, the following information will be displayed.
                   如果发生错误,将显示以下信息
          "DiagError aaaaaaaa "
       where
          aaaaaaaa is the Diagnostic Error Code
               aaaaaaaa是诊断错误代码
  Examples:
    例如:
    Example #1:
    To remove LBA 1234 from the alt list:
        要删除LBA1234从alt列表
       F3 2>F1234,f1
    To add LBA 1234 from the alt list:
    要填加LBA1234到alt列表
       F3 2>F1234,B1
  Revision History:
     版本历史:
    0001.0000 Initial Revision.
                初始的版本
    0002.0000 Remove 2>Fx,F; add Fx,F1 to unalt by sector.
    0011.0000   Combined the PSG Diagnostic Error Codes (PSGDEC) and the Diagnostic External
                Test Service Error Codes (DETSEC) into a single set of Diagnostic Error Codes
                (DiagError).
                结合PSG诊断错误的代码(PSGDEC)和诊断的外部测试服务错误的代码(DETSEC)一组诊断错误代码                                      (DiagError)
作者: sis620    时间: 2013-5-15 08:32
这条命令很有用,一直在找,试试是否有效。
