标题: 戴尔M9开机报警 提示按F1关机 [打印本页]
作者: 蔡政    时间: 2013-3-10 20:59
    一台戴尔M90的机子,插上电池就电池报警【warning:the battery attached can not power the system.
the system will not boot with this battery plugged in.
press F1 to shutdown the system】,提示按F1关机。  插电源就电源报警【warning: a 90w ac power abapter has been detected. the system can only       boot winth a 130 w power abapter or greater.          strike the f1 key to shutdown2 】,提示按F1关机。
    有没有那位高手修过这样的机子,现在不知道怎么样下手了
