ATIFLASH.EXE
[3.60]
- Use SCLK to flash BIOS on RV730 only (SCLK will be scaled down while flashing the BIOS)
[3.59]
- Add RV730 support
[3.58]
- fix pa paramter, synchornize the same behaviour as ATIWinFlash
[3.57]
- Add R700 Support
- Reduce size
[3.56]
- fix corrupted zip file. Same releaes as 3.55
[3.55]
- add option (excl_memtrain_dtable) to keep memory training information while flashing new bios
- add partial check for -pavbpn
[3.54]
- Add "nw" in help
[3.53]
- Add unique identifier for Ry7xx
[3.52]
- Add RV770 device ID support
[3.51]
- add -AMD flag to allow searching for devices with AMD vendor ID
[3.50]
- update SPI write sequence to check for both WREN and BUSY bits to be deasserted before verifying the write (solves issues seen with intermittent write failures)
[3.49]
- update description for RV670 slave devices to identify uniquely on Gemini boards
[3.48]
- correctly print Old and New P/N when flashing with newer bioses
[3.47]
- explicitly identify RV635 ASICs
[3.46]
- fix problems with GPIO19 asserting the CTF signal on RV670 boards
[3.45]
- fix problems with crashes on some systems when flashing onto blank ROMs
[3.43]
- added -pavbpn (allows the use of -pa with VBIOS PN)
- added support for new ROM used by multimedia cards (Quito and Lima)
[3.42]
- fix -mb command for Ry6xx
[3.41]
- fix Ry6xx SST support
[3.40]
- fix RV610 + Rialto hang issue
[3.39]
- fix RV610 write issue
[3.38]
- Add Quito support
[3.35]
- resolved -i/-ai corruption issue
[3.34]
- -ai now displays full PCI ID information
- ATMEL flash procedurce redesigned for stability/reduced overall flash time
- -ai -scansii combination will report SST/ATMEL firmware revision
[3.33]
- internal release
[3.32]
-add flashing over 128KB
[3.31]
-resolved pak issues with SST/ATMEL
[3.30]
-update device ID support for RV630/M76 & 0x000 for Ry6xx
[3.29]
-add new option -pak to build flash package
[3.28] 11/02/06
-add new option -fa to force flashing if the ROM is already programmed
-add new option -fm to force flashing if legacy memory config mismatch
-add new option -fs to force flashing if SSID mismatch
-add new option -fp to force flashing if BIOS P/N mismatch
-add new command -pa to search and program multiple adapters according to
BIOS P/N
-add new option -padevid to search for adapters of a specific PCI device
ID when used with -pa command
-add new option -passid to search for adapters of a specific subsystem
-add new option -pasvid to search for adapters of a specific subsystem
vendor ID when used with -pa command
Older revisions
[3.00] 09/08/04
- initial release
[3.01] 09/16/04
- adjust bus scanning sequence
[3.02] 09/30/04
- add Rialto support
[3.03] 10/19/04
- fix issues for Rialto
[3.04] 12/01/04
- remove 32K limit for Rialto
[3.05] 12/09/04
- add RN50 support
[3.06] 03/03/05
- fix issue in flashing secondary adapters
[3.07] 03/15/05
- fix SST support with -sst option
- fix infinite looping on write failure
[3.08] 04/05/05
- display BIOS P/N in -i option
[3.09] 04/29/05
- add -mi command to modify SSID in ROM image
- add support R530
[3.10] 09/30/05
- support write-protected sector on 128k serial flash ROMs
- add RIO support
[3.11] 11/11/05
- mask out GENERICD pad output register clear to avoid setting VDDC on A520xx-20 PCB
[3.12] 11/14/05
- add verified LIMA support
[3.13] 02/03/06
- add new option -mb for modifying BIOS SSID, SVID, BIOS P/N and bootup message
[3.14] 02/13/06
- add update SiImage firmware
[3.15] 02/24/06
- add support for Warhol (RV570/M68/RV560/M67) device IDs
- mask out GPIO[6..3] clear to avoid overwriting MVP settings on RV570/RV560
[3.16] 04/24/06
-allow autodetect and/or pin specification for SiImage firmware updating
[3.20] 06/09/06
-Add new options, -reboot, -pci, -pcie, -agp, -noagp, -nopcie
-Fix SiI1930 Mobile FW Update issues
[3.21]
-add new command -ai, advanced information
-add new options -log, -logappend
-reformat help menu, help menu appears with use of -h, /h, -? or /?
[3.22]
-add display more BIOS information when flashing
-add reboot message when flashing completed successfully
