- 积分
- 11162
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2008-2-25
- 精华
推荐
发表于 2013-1-29 23:44:44
只看该作者
来自: 广东 来自 广东
Current Limit Setting (OCP)
RT8208E/F has cycle-by-cycle current limiting control.
The current limit circuit employs a unique “valley” current
sensing algorithm. If the magnitude of the current sense
signal at CS is above the current limit threshold, the PWM
is not allowed to initiate a new cycle (Figure 7) in order to
provide both good accuracy and a cost effective solution,
the RT8208E/F supports temperature compensated
MOSFET RDS(ON)
sensing. The CS pin should be
connected to GND through the trip voltage setting resistor,
RCS. The CS terminal source 10μA ICS current, and the
trip level is set to the CS trip voltage, VCS as in the following
equation.
数据手册14页,写了一大堆,留给会看英语的看吧 |
