标题: 交换机配置连载(七) [打印本页]
作者: lijianwei652 时间: 2013-1-22 16:25
标题: 交换机配置连载(七)
20、在两台6509上配置HSRP将需要起HSRP的三层端口分别在两台主备6509上进行如下配置:
SS6509-1#vlan database
SS6509-1 (vlan)#vlan 31 name ****
SS6509-1 (vlan)#exit
SS6509-1#conf t
SS6509-1(config)#int vlan 31
SS6509-1(config-if)#description **** ****
SS6509-1(config-if)#ip address 172.21.11.252 255.255.0.0
SS6509-1(config-if)#standby 100 ip 172.21.11.254 (定义standby组号及虚IP地址)
SS6509-1(config-if)#standby 100 priority 120
(定义该设备本standby组的优先级,优先级的值越大优先级越高)
SS6509-2#vlan database
SS6509-2 (vlan)#vlan 31 name ****
SS6509-2(vlan)#exit
SS6509-2#conf t
SS6509-2(config)#int vlan 31
SS6509-2(config-if)#description **** ****
SS6509-2(config-if)#ip address 172.21.11.253 255.255.0.0
SS6509-2(config-if)#standby 100 ip 172.21.11.254 (定义standby组号及虚IP地址)
SS6509-2(config-if)#standby 100 priority 100 (定义该设备本standby组的优先级)
21、配置端口MAC梆定Switch(config)# mac access-list extended f02
Switch((config-ext-macl)# permit host 0016.d325.f96a any
Switch(config)# interface FastEthernet0/2
Switch(config-if)# mac access-group f02 in
Powered by Discuz! X3.4 |
