标题: 惠普温度报警! [打印本页] 作者: sunyuguq 时间: 2013-1-9 19:04 标题: 惠普温度报警! 开机出现温度报警The System BIOS has detected your notebook PC was placed in hibernation to avoid overheating. The system is now operating normally and your data should remain intact.Overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification. The note book PC should return to normal operation once the situation is resolved.System Temperature (90D)ENTER-Continue Startup
需要按一下回车 然后才能进入系统很麻烦,进入了系统 测试温度感觉还行 开机一般50度 游戏看电影大概70-80几度,机器我已经拆开过,清理了灰尘,进BIOS也找不到关闭温度检测的款项,除了刷BIOS还有别的方式取消这个提示吗? 作者: sunyuguq 时间: 2013-1-9 19:24
学友们有谁见过呀作者: sunyuguq 时间: 2013-1-12 10:45
这个问题没有能回答吗
