The method is as follow :
1- Extract the rar file, you will have a folder named crisdisk.
2- Download the bios flash rom file, and rename it to BIOS.WPH, the put it in the crisdiks folder , beside WINCRIS.EXE.
3- Insert your usb drive , it’s better to have one with less than 2Gb, and open WINCRIS.EXE , choose ‘’Removable ‘’ in Disk format, thenk click on
4- Now, in your dead Laptop, remove the battery , CD or DVD rom, any card, unplug it from the AC source , and put in the usb drive.
5- You must put your laptop in Crisis Recovery Mode, by Holding down: Fn+B and while holding, plug the computer in to power and press the power button.
6- You should see the usb drive LED blinking for a while, then it stops ! wait for 2 or 3 min until the CPU Fan noise stops.
7- Unplug the power , and boot yor laptop, it’s alive ! eh voilà !
作者: 南极宝宝 时间: 2012-11-5 08:10
good, is it support other bios system?i mean like award winbond. anyway,it can't be used by windows 7 .作者: camelionx 时间: 2012-11-5 08:56
no win 7 good in win xp this programme work for acer . hp . toshiba ..samsung and you can unlock password whit this ok 作者: xingge 时间: 2012-11-5 09:25
still can't understand how to use it!作者: 阿副 时间: 2012-11-5 09:29
论坛人才济济呀..........给力
怎么都说英文呢?
是提取东芝BIOS的意思吧...通用吗?作者: xingge 时间: 2012-11-5 09:36
软件界面
如上
1.找一U盘格成FAT32
2.运行附件中的软件。制作一个自动刷Bios的U盘,几个步骤不再赘述!
3.将官网上下的BIOS文件(.WPH)改名成BIOS.WPH替换U盘里面BIOS.WPH
4.去掉本本上的电池和电源
5.插上U盘
6.按FN+B不放,插电源(此时两灯会闪一下),开机
7.看到U盘在闪,本本在滴滴叫,然后松开FN+B
8.本本叫个2,3分钟,自动重启,一切OK.
注:This procedure is for Phoenix BIOS`es only 作者: fffzzd 时间: 2012-11-5 11:48
提示: 作者被禁止或删除 内容自动屏蔽作者: 酱油拌饭 时间: 2012-11-5 12:14
楼主是在国外吗?作者: camelionx 时间: 2012-11-6 06:28
he what baby its simple create your usb boot it push win+b in keyboard ok 作者: camelionx 时间: 2012-11-6 06:55
get translator作者: 仟元电脑 时间: 2012-11-9 11:48
想来学习的,什么没看出来,楼主真牛作者: 志诚本本维修 时间: 2012-11-9 17:46
