希捷ST3500320AS解密--指令全程
xwwlug
2012-10-19 15:33
F3 2>s21FED,00,22
F3 2>r,10d,1
F3 2>B1708,1708
Buffer Block 1708 compared to Buffer Block 1708 (200 Bytes/Block)
Addr 0 1 2 3 4 5 6 7 8 9 A B C D E F
002E1000 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E10F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1100 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1110 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1120 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1130 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1140 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1150 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1160 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1170 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1180 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E1190 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
002E11F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F3 2>C1708,1708,1
F3 2>s21FED,00,22
F3 2>w,10d,1
F3 2>
补充内容 (2012-10-28 21:40):
这个是用超级终端输入的指令全过程。先/2回车进入二级F3 2>,再依次输入指令s21FED,00,22 r,10d,1 B1708,1708,其中FF FF...是自动显示的缓冲区数据,是全部FF的就表示密码被清除。再指令保存C1708,1708,1...
yz323
2012-10-19 15:38
q897494086
2012-10-19 15:47
什么意思啊
393983415
2012-10-19 16:39
实在是高,不懂啊
825963175
2012-10-22 13:23
看不懂什么意思。。楼主解释下,
1055660999
2012-11-1 13:05
这个还还真就没试过,保存下来试试看可以搞定不 先谢谢楼主这么高尚的风格
ting1990x
2012-11-1 21:41
不是所有都一样的
jingbaihang
2017-7-18 17:21
指令解密
