故障录入:明基 T31E,开机报错
逸雨涵梦
2012-9-10 16:45
故障录入:明基 T31E,开机报错
明基 T31E
板号:DAOED5MB8FO REV:F、
故障:开机到LOOGOO时提示 :system initialization has failed
do you want to continue booting 意思是:系统初始化失败, 你要继续引导
