标题: 一只7200. [打印本页]
作者: 孤帆远影    时间: 2008-7-16 16:14
标题: 一只7200.
Head Mask 0000 - Switch to full int.
              Spin Ready
T>
T>
T>
T>
T>
T>N2,AA,22
T>No valid SeaDex script in buffer.
Begin Test 02
ASCII logging on
                      Not Power Cycling
ERROR: No Serial Number
ASCII logging off
    Code - 47  Track 0E31F.0.006  Sns 006  Rty FFFF.20.20FF  Rtf 1800  LBA 00000000
!!! Adaptives corrupt !!!
AbEnd Test 02
T>#
Enter Drive S/N  3JX0TMSL
Enter Packwriter S/N 3JX0TMSL
    Code - 33  Track 00019.0.0D6  Sns 0D6  Rty F7FF.FF.80FF  Rtf 1800  LBA 00000000
T>N2,AA,22
T>Begin Test 02
ASCII logging on
                      Not Power Cycling
                      Not Power Cycling
Zone 00 Head 00 adaptives set to defaults
Zone 01 Head 00 adaptives set to defaults
Zone 02 Head 00 adaptives set to defaults
Zone 03 Head 00 adaptives set to defaults
Zone 04 Head 00 adaptives set to defaults
Zone 05 Head 00 adaptives set to defaults
Zone 06 Head 00 adaptives set to defaults
Zone 07 Head 00 adaptives set to defaults
Zone 08 Head 00 adaptives set to defaults
Zone 09 Head 00 adaptives set to defaults
Zone 0A Head 00 adaptives set to defaults
Zone 0B Head 00 adaptives set to defaults
Zone 0C Head 00 adaptives set to defaults
Zone 0D Head 00 adaptives set to defaults
Zone 0E Head 00 adaptives set to defaults
Zone 0F Head 00 adaptives set to defaults
Head Mask 0000 -
Read Bias - Head      0   1   2   3
                      B
HiTemp Bias Head      0   1   2   3
                      B
              Spin Ready
Calibrating Physical Track 0 on heads 0 thru 0
Calibrating Head 0 ...
Radial Offset Table:
Head 0    Offset = FCE
Head 1    Offset = 1388
Head 2    Offset = 1388
Head 3    Offset = 1388
SkpCylList deleted
Sys= 0E6C0-0E73F   0280 SPTK on sys trks
<empty>
drive must be reformatted
Skipping MDW oversample s/n cylinders.
Zone 00:  00018 - 00BE8  1100 (044C) 683.439
Zone 01:  00BE9 - 027FE  1056 (0420) 666.63
Zone 02:  027FF - 04707  1026 (0402) 646.275
Zone 03:  04708 - 06CA3   990 (03DE) 622.431
Zone 04:  06CA4 - 08B66   953 (03B9) 602.353
Zone 05:  08B67 - 0A479   916 (0394) 580.392
Zone 06:  0A47A - 0C405   880 (0370) 545.882
Zone 07:  0C406 - 0D99A   836 (0344) 527.59
Zone 08:  0D99B - 0ECD9   806 (0326) 506.144
Zone 09:  0ECDA - 10337   770 (0302) 480.724
Zone 0A:  10338 - 11397   733 (02DD) 461.672
Zone 0B:  11398 - 12854   691 (02B3) 437.423
Zone 0C:  12855 - 13F38   660 (0294) 410.353
Zone 0D:  13F39 - 14AE7   623 (026F) 396.401
Zone 0E:  14AE8 - 155D6   605 (025D) 383.316
Zone 0F:  155D7 - 16358   572 (023C) 363.922
Total LBAs = 04A96402
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
No entries in Log
All Hds 0-0, All Cyls 00018-16358, Rnd data
Performing AFC Zone Cal
ACFC Calibration:
            CRRO Orders Prior to Cal: (PES*2)^2
  Cyl.Hd    2    3    4    5    6    7    8   12   24
00018.00 0172 002d 0001 000d 0055 0020 018a 0008 0000
02000.00 0151 001d 0001 0008 0062 0008 0140 0019 0001
04000.00 0115 001d 0004 000d 0029 0014 0151 0029 0001
06000.00 00e9 0014 0004 000a 0029 0008 01a8 0029 0001
08000.00 00d0 0011 0004 0005 0029 000d 0110 001d 0001
0a000.00 00b9 0014 0009 000d 0019 0001 01d0 001d 0001
0e000.00 0082 0019 0011 0019 0011 0005 0195 001a 0001
10000.00 0082 0014 0011 0019 0014 0002 0140 0024 0001
12000.00 00aa 0014 0025 0029 0029 0001 0175 0025 0001
14000.00 00c1 0014 0044 003d 0092 0004 0152 0032 0001
16000.00 00e9 0028 00a0 0075 0251 000d 0185 0041 0001
RTE Amplitude = 0005 servo clocks. Sector = 00D4h. Trk/2 = B2B3h.
RTE Amplitude = 0004 servo clocks. Sector = 00D4h. Trk/2 = 8EF8h.
RTE Amplitude = 0003 servo clocks. Sector = 00CFh. Trk/2 = 6B3Dh.
RTE Amplitude = 0003 servo clocks. Sector = 00C2h. Trk/2 = 4782h.
RTE Amplitude = 0002 servo clocks. Sector = 00CDh. Trk/2 = 23C7h.
RTE Amplitude = 0002 servo clocks. Sector = 00BFh. Trk/2 = 000Ch.
EP=0, TA=0, HiGain=0, OTRd=0, Early Rd=0, Splash=0, Reload=0, NPML=0, MRBias=0
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=1, ECC 1=1, ECC 0=1
Data=02, Write=40, ID=1E
Channel Srvo Table
  Head   Addr   VGA  SATT  Tap5  Tap6  Tap3  Tap7  Tap2  Tap8  Tap9  RATT   XDC
    00   F7F2    2D    02    5C    C4    9E    A0    50    98    60    41    5A
Adapt Servo Zone 08
Adapt Servo 0000e33a.00
Adapts Loaded
Dbck DATA load
Test 0000e33a.00 10800000 BER 03000000
Adjust ATTR 01 VGAS 25 VGAR ea FREQR 7e  Read 0047
MRASYM     80 10800000 BER 03000000
MRASYM     7d 10800000 BER 03000000 hold
Zone  8 [0000D9A3.0,FC64,0264,C0]
Retry to find bath using coarse offset
[0000D9C3.0,FB64,0364,EB]
    Left Bath = FFD4, Right Bath = 0028 : Pick (FFFE) ( Min/Max AGC D2FF )
Zone  9 [0000ECE2.0,FD05,0305,C0]
[0000ED02.0,FC05,0405,E9]
    Left Bath = 0078, Right Bath = 00E1 : Pick (00AC) ( Min/Max AGC CCFF )
Zone  0 [00000020.0,F689,FC89,C0]
    Left Bath = FA18, Right Bath = FA70 : Pick (FA44) ( Min/Max AGC AEFF )
Zone  1 [00000BF1.0,F6D4,FCD4,C0]
    Left Bath = FA55, Right Bath = FA92 : Pick (FA73) ( Min/Max AGC B4FF )
Test 00000bc8.00 008520dc BER 03001939
RDBIAS  Lower 0001  Upper 000b  Step 0001  Right 0a  Mask 2000
Default  000b 00875a07 BER 03002a93
Floor  1   01 000bc280 000bc280
Left   1 0006 000bc280
Middle 1 0006 000bc280
Right  1 0006 000bc280
Lowest 1 0006 000bc280
Curve    Size Bathtub
New      0006 008d5922 BER 030031d3
Adjust ATTR 01 VGAS 41 VGAR c7 FREQR 82  Read 0043 SRVTEST 41  Read 0043
fail lower limit
MRASYM     7f 1080e9a7 BER 0300058c hold
Dbck DATA load
Test 0000e33a.00 1080d377 BER 03000d9b
Adapt Servo 0000e35a.00
Adapts Loaded
Dbck DATA load
Test 0000e35a.00 10800000 BER 03000000
Adjust ATTR 01 VGAS 2b VGAR c7 FREQR 80  Read 0043 SRVTEST 41  Read 0043
fail lower limit
MRASYM     7f 10800000 BER 03000000 hold
Zone  8 [0000D9A3.0,FCFE,02FE,C0]
[0000D9C3.0,FBFE,03FE,ED]
    Left Bath = FFDD, Right Bath = 0021 : Pick (FFFF) ( Min/Max AGC DFFF )
Zone  9 [0000ECE2.0,FDAC,03AC,C0]
[0000ED02.0,FCAC,04AC,ED]
    Left Bath = 007A, Right Bath = 00E7 : Pick (00B0) ( Min/Max AGC CCFF )
Test 0000e35a.00 10801c35 BER 030007af
Zone  0 [00000020.0,F744,FD44,C0]
    Left Bath = FA18, Right Bath = FA72 : Pick (FA45) ( Min/Max AGC A3FF )
Zone  1 [00000BF1.0,F773,FD73,C0]
    Left Bath = FA53, Right Bath = FA91 : Pick (FA72) ( Min/Max AGC B5FF )
Test 00000bc8.00 1080d3e2 BER 03000b51
Default  000b 1080762c BER 030005c8
Floor  0   00 ffffffff 007fffff
Left   0 0001 10804a05
Middle 0 0006 1080e7a4
Right  0 000b 10805e7f
Lowest 0 0001 10804a05
Restore  000b 10806bc2 BER 03000794
Adjust ATTR 01 VGAS 2d VGAR b7 FREQR 73  Read 0043 SRVTEST 41  Read 0043
fail lower limit
MRASYM     80 1080d38d BER 030005a2
MRASYM     7f 10807b0c BER 030005cf update 7f hold
Default Tap Weight 00000000 Settle Tap Weight 00000154
XDCTAP     5a 08834b8f BER 03000000 adapt
XDCTAP     26 0883aa77 BER 03000000 hold
CUTOFF  Lower 0022  Upper 013b  Step 0003  Right 18  Mask 0008
Default  0127 08811c0d BER 03000000
Left   0 0022 10800000
Middle 0 0116 08838443
Right  0 013b 0881814b
Lowest 0 0022 10800000
Restore  0127 0881a0c7 BER 03000000
SV TAP5 Lower 0020  Upper 00df  Step 0006  Right 1f  Mask 1000
Default  005c 0882c69a BER 03000000
Left   0 0020 0881ba3d
Middle 0 007f 08829d8f
Right  0 00df 08838e2c
Lowest 0 0020 0881ba3d
Restore  005c 0881d9b9 BER 03000000
0881d03d BER 03000000 _ATT 01 VGAS 30 VGAR 5e FREQR 6b Taps frozen read adapt
Current Tap Weight 00003ce8 diff ffffc318 tap limits
0881c69a BER 03000000 _ATT 01 VGAS 2e VGAR 55 FREQR 82 Taps frozen read adapt
Current Tap Weight 00000162 diff 00003b86 tap limits
0883456b BER 03000000 _ATT 01 VGAS 2e VGAR 58 FREQR 78 Taps frozen read adapt
Current Tap Weight 00000189 diff ffffffd9 Save servo Force servo update
Dbck DATA load
Test 0000e35a.00 1080a104 BER 030003fc
Zone  8 [0000D9A3.0,FCFF,02FF,C0]
[0000D9C3.0,FBFF,03FF,ED]
    Left Bath = FFDD, Right Bath = 0026 : Pick (0001) ( Min/Max AGC E6FF )
Zone  9 [0000ECE2.0,FDB0,03B0,C0]
[0000ED02.0,FCB0,04B0,EE]
    Left Bath = 0082, Right Bath = 00E4 : Pick (00B3) ( Min/Max AGC CDFF )
HiTemp Bias BackOff Head   0   1   2   3
                           6
Media 0000
Channel Srvo Table
    00   F7F2    58    02    5C    81    72    CE    80    4E    B4    41    26
Adapt Data Zone 08
Test 0000e33a.00 10800000 BER 03000178
Test 0000e33a.00 1080dd21 BER 03000170
Test 0000e35a.00 00800000 BER 03000000
Test 0000e37a.00 10800000 BER 03000000
Test 0000e39a.00 10800000 BER 03000000
Adapt Data 0000e39a.00
Dbck DATA load
NPML       00
Test 0000da1b.00 1080ad88 BER 03000ba3
Test 0000e39a.00 1080cd2b BER 030007db
Check  ATTR 01 VGAS 36 VGAR c9 FREQR 82  Read 0043 within VGAR FREQR
MRASYM     7f 1080b713 BER 030005ec
MRASYM     82 1080d9e6 BER 030003f2 hold
OD OFST Lower ffa1  Upper 0060  Step 0006  Right 1f  Mask 4340
Default  0001 10806b44 BER 030003ed
Left   0 ffa1 10809780
Middle 0 0000 1080c3a6
Right  0 0060 1080ecd5
Lowest 0 ffa1 10809780
Restore  0001 1080584d BER 030003d8
Check  ATTR 01 VGAS 35 VGAR be FREQR 9d  Read 0043 within VGAR FREQR
Test 0000e39a.00 1080d6bc BER 030003ea
Noise target  00000000
Dbck Noise OFF
Dbck DATA save
WRITE_I Lower 0000  Upper 001b  Step 0001  Right 1b  Mask 0342
Default  000e 10800000 BER 03000000
Left   0 0000 007fffff
Middle 0 000d 007fffff
Right  0 001b 007fffff
Lowest 0 0000 007fffff
Restore  000e 10800000 BER 03000000
MRASYM     7f 108028fb BER 030001f8 hold
Media 0000
FAILED DATA Zone 08 Head 00 Error 0047
Performing Servo Cals, view results in log 3
ASCII logging off
Cylinder   ID->OD Bias   OD->ID Bias
00100          009E         0096
00300          0096         0089
00500          008E         007D
00700          0087         006E
00900          0079         0062
00B00          0067         0056
00D00          005B         0045
00F00          004A         0037
01100          0042         0028
01300          0034         001F
01500          0033         0020
01700          003A         0022
01900          003F         0030
01B00          0049         0034
01D00          0053         003A
01F00          0054         003E
02100          0059         003B
02300          0057         0038
02500          0052         0040
02700          004F         003A
02900          004C         003B
02B00          0048         0034
02D00          004A         002F
02F00          0048         002F
03100          004C         0031
03300          004B         0030
03500          004A         0035
03700          0048         0031
03900          0046         002E
03B00          0045         002F
03D00          0042         002B
03F00          0043         002C
04100          0045         002C
04300          0044         0028
04500          0041         002A
04700          0042         002E
04900          0042         002B
04B00          003F         0026
04D00          003F         0023
04F00          0037         001E
05100          0035         001E
05300          0030         001C
05500          002F         0019
05700          0032         0014
05900          002F         0015
05B00          002E         0015
05D00          002E         001B
05F00          0031         0019
06100          002F         0016
06300          0030         0016
06500          0031         0019
06700          0033         0019
06900          002F         0017
06B00          002D         0016
06D00          002D         0015
06F00          0031         0019
07100          0030         0017
07300          002D         0011
07500          0028         0010
07700          0027         0010
07900          002A         0013
07B00          002C         0014
07D00          002D         0010
07F00          0028         000B
08100          0026         000D
08300          0023         000F
08500          0023         000E
08700          0026         000A
08900          0025         0008
08B00          0025         0009
08D00          0022         000B
08F00          001D         0009
09100          001E         0006
09300          001E         0003
09500          001E         0006
09700          0020         0008
09900          001E         0008
09B00          001D         0005
09D00          001C         0003
09F00          0020         0008
0A100          0022         0008
0A300          001F         0002
0A500          001B        -0001
0A700          0017        -0001
0A900          0016        -0002
0AB00          0016        -0002
0AD00          0014        -000B
0AF00          000E        -000D
0B100          000D        -000A
0B300          0009        -000B
0B500          0009        -000F
0B700          0008        -0016
0B900          0005        -0016
0BB00          0004        -0018
0BD00          0002        -0015
0BF00          0002        -0014
0C100          0006        -0014
0C300          000A        -000F
0C500          0015        -0005
0C700          0020         0006
0C900          0022         000D
0CB00          0027         0010
0CD00          002D         0014
0CF00          0029         0014
0D100          0024         000A
0D300          0018        -0002
0D500          0008        -000E
0D700         -0006        -001E
0D900         -0017        -0028
0DB00         -0023        -0039
0DD00         -0029        -0045
0DF00         -002B        -0048
0E100         -002F        -0042
0E300         -002B        -0040
0E500         -0026        -003D
0E700         -001B        -0034
0E900         -0015        -002D
0EB00         -000C        -0022
0ED00         -0006        -001D
0EF00         -000B        -0025
0F100         -0013        -0029
0F300         -0019        -002F
0F500         -001D        -0035
0F700         -0022        -003B
0F900         -0026        -0044
0FB00         -0028        -0044
0FD00         -0027        -003F
0FF00         -0024        -003B
10100         -0020        -0038
10300         -0016        -0036
10500         -0011        -0030
10700         -000D        -0029
10900         -000B        -0020
10B00         -0005        -0020
10D00         -0004        -0020
10F00         -0002        -001F
11100          0001        -001C
11300          0005        -0015
11500          0008        -0010
11700          000A        -0015
11900          000C        -0012
11B00          0018        -0009
11D00          001A        -0003
11F00          001D         0001
12100          0020         0001
12300          0024         0004
12500          002C         000F
12700          0033         0018
12900          003F         0025
12B00          004E         002A
12D00          0055         0034
12F00          0062         0043
13100          006C         004D
13300          0076         005B
13500          0082         0066
13700          008B         006C
13900          0096         0077
13B00          00AC         0087
13D00          00B7         009A
13F00          00CC         00AD
14100          00DE         00BB
14300          00EC         00CB
14500          0108         00E7
14700          011A         00FE
14900          013C         011B
14B00          014E         0139
14D00          016C         014A
14F00          0189         0169
15100          01A2         0186
15300          01C7         01A4
15500          01E5         01CB
15700          020D         01F2
15900          0232         0218
15B00          0256         0240
15D00          0282         026A
15F00          02A7         0297
16100          02DC         02C7
16300          02FF         02FD
Head Linearizing
Cyl = 00B2C0
Head = 00 Gain Adjust = 0135
Head Linearizing
Cyl = 0002D4
Head = 00 Gain Adjust = 0121
Head Linearizing
Cyl = 0162AC
Head = 00 Gain Adjust = 011B
CYL = 003C0 KA = 52A0 scaled by 4000  CYL = 00BC0 KA = 50E0 scaled by 4000
CYL = 013C0 KA = 4E50 scaled by 4000  CYL = 01BC0 KA = 4D30 scaled by 4000
CYL = 023C0 KA = 4BC0 scaled by 4000  CYL = 02BC0 KA = 4C00 scaled by 4000
CYL = 033C0 KA = 4AD0 scaled by 4000  CYL = 03BC0 KA = 4A40 scaled by 4000
CYL = 043C0 KA = 4960 scaled by 4000  CYL = 04BC0 KA = 4960 scaled by 4000
CYL = 0B2C0 KA = 4980 scaled by 4000
CYL = 11929 KA = 48A0 scaled by 4000  CYL = 12129 KA = 4950 scaled by 4000
CYL = 12929 KA = 48E0 scaled by 4000  CYL = 13129 KA = 49A0 scaled by 4000
CYL = 13929 KA = 4A30 scaled by 4000  CYL = 14129 KA = 4B70 scaled by 4000
CYL = 14929 KA = 4C90 scaled by 4000  CYL = 15129 KA = 4D90 scaled by 4000
CYL = 15929 KA = 4EF0 scaled by 4000  CYL = 16129 KA = 5030 scaled by 4000
Head Linearizing
Cyl = 00B2C0
Head = 00 Gain Adjust = 0132
Head Linearizing
Cyl = 0002D4
Head = 00 Gain Adjust = 0124
Head Linearizing
Cyl = 0162AC
Head = 00 Gain Adjust = 011D
Table Linearization in Process
Head Gain Measure
Head   Max  -38h  -28h  -18h  -08h  +08h  +18h  +28h  +38h
   00  3C53  3333  34C0  35AB  3486  359B  3B86  3C53  3544
Normalized Integrated Gain
Head  -40h  -30h  -20h  -10h   00   +10h  +20h  +30h  +40h
   00  0000  0365  06E4  0A72  0DED  117A  156C  196B  1CF3
PES to Position Table
   00  FFC0  FFCF  FFDE  FFEE  FFFE  000D  001F  0030  0040
ASCII logging on
Head 0    Offset = FCE
Performing ACFC Cal
ASCII logging off
ACFC Calibration:
00018.00 00f4 0008 0000 0002 0019 0000 0068 000d 0000
02000.00 00e1 000a 0001 0001 0032 0001 00b9 000d 0000
04000.00 00d0 000a 0001 0005 0022 0000 00a9 0004 0000
06000.00 00ca 000a 0001 0002 0020 0001 007d 0002 0000
08000.00 00a4 000a 0001 0002 0022 0001 0092 0001 0000
0a000.00 0091 000a 0004 0002 001d 0001 0074 0005 0000
0e000.00 0062 000a 0009 0005 0010 0002 007d 0004 0000
10000.00 0062 0005 0009 000d 001a 0001 007d 0005 0000
12000.00 0082 0009 0019 000d 0022 0002 0091 0008 0000
14000.00 0082 000a 0024 0014 0055 0002 0094 0008 0000
16000.00 0091 000a 0035 0022 00b9 0008 0082 0011 0000
ASCII logging on
RTE Amplitude = 0005 servo clocks. Sector = 00CFh. Trk/2 = B2B3h.
RTE Amplitude = 0003 servo clocks. Sector = 00D1h. Trk/2 = 6B3Dh.
RTE Amplitude = 0003 servo clocks. Sector = 00D1h. Trk/2 = 4782h.
RTE Amplitude = 0002 servo clocks. Sector = 00D4h. Trk/2 = 23C7h.
RTE Amplitude = 0002 servo clocks. Sector = 00CAh. Trk/2 = 000Ch.
MROffset Summary
Head 00 (00,00)
Zone  0 [00000020.0,F745,FD45,C0]
    Left Bath = FA25, Right Bath = FA63 : Pick (FA44) ( Min/Max AGC B2FF )
Zone  1 [00000BF1.0,F772,FD72,C0]
    Left Bath = FA59, Right Bath = FA95 : Pick (FA77) ( Min/Max AGC B4FF )
Zone  2 [00002807.0,F786,FD86,C0]
    Left Bath = FAFF, Right Bath = FB30 : Pick (FB17) ( Min/Max AGC B9FF )
Zone  3 [00004710.0,F852,FE52,C0]
[00004730.0,F752,FF52,E3]
    Left Bath = FB9A, Right Bath = FC0F : Pick (FBD4) ( Min/Max AGC C8FF )
Zone  4 [00006CAC.0,F94B,FF4B,C0]
[00006CCC.0,F84B,004B,E5]
    Left Bath = FC9D, Right Bath = FD04 : Pick (FCD0) ( Min/Max AGC C3FF )
Zone  5 [00008B6F.0,FA1E,001E,C0]
[00008B8F.0,F91E,011E,E5]
    Left Bath = FD6E, Right Bath = FDD4 : Pick (FDA1) ( Min/Max AGC C9FF )
Zone  6 [0000A482.0,FAD2,00D2,C0]
[0000A4A2.0,F9D2,01D2,EB]
    Left Bath = FE27, Right Bath = FEA1 : Pick (FE64) ( Min/Max AGC C4FF )
Zone  7 [0000C40E.0,FBBD,01BD,C0]
[0000C42E.0,FABD,02BD,EE]
    Left Bath = FF1F, Right Bath = FF8D : Pick (FF56) ( Min/Max AGC D3FF )
Zone  8 [0000D9A3.0,FD01,0301,C0]
[0000D9C3.0,FC01,0401,FD]
offset unchanged
Zone  9 [0000ECE2.0,FDB3,03B3,C0]
[0000ED02.0,FCB3,04B3,ED]
    Left Bath = 007F, Right Bath = 00DF : Pick (00AF) ( Min/Max AGC D1FF )
Zone  A [00010340.0,FDC7,03C7,C0]
[00010360.0,FCC7,04C7,EA]
    Left Bath = 0150, Right Bath = 01A4 : Pick (017A) ( Min/Max AGC D6FF )
Zone  B [000113A0.0,FE5A,045A,C0]
[000113C0.0,FD5A,055A,E7]
    Left Bath = 01DE, Right Bath = 0243 : Pick (0210) ( Min/Max AGC CBFF )
Zone  C [0001285D.0,FF22,0522,C0]
[0001287D.0,FE22,0622,E9]
    Left Bath = 02B0, Right Bath = 0306 : Pick (02DB) ( Min/Max AGC C6FF )
Zone  D [00013F41.0,0010,0610,C0]
[00013F61.0,FF10,0710,F0]
    Left Bath = 03AF, Right Bath = 0402 : Pick (03D8) ( Min/Max AGC E4FF )
Zone  E [00014AF0.0,0093,0693,C0]
[00014B10.0,FF93,0793,EF]
    Left Bath = 0451, Right Bath = 0461 : Pick (0459) ( Min/Max AGC EEFF )
Zone  F [000155DF.0,0113,0713,C0]
[000155FF.0,0013,0813,F3]
offset unchanged
Zone 10 [00016350.0,01B5,07B5,C0]
[00016330.0,00B5,08B5,F7]
    Left Bath = 056B, Right Bath = 0591 : Pick (057E) ( Min/Max AGC F2FF )
End MROffset Summary
        PLO Phase
Head  0 Zone 0 target = 10
Too many R/W errors. Reverted to current value 0003
Zone 1 target = 10
Too many R/W errors. Reverted to previous zones value 0003
Zone 2 target = 10
Zone 3 target = 10
Zone 4 target = 10
Zone 5 target = f
Zone 6 target = f
Zone 7 target = f
Zone 8 target = f
Zone 9 target = f
Zone A target = f
Zone B target = f
Zone C target = f
Zone D target = f
Zone E target = f
Zone F target = f
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=0, ECC 1=0, ECC 0=1
Data=05, Write=40, ID=1E
00EA Entries:
_____Head___0______
47 0E6D5.000 000 17
43 0E6D5.000 009 01
59 0E6D5.000 014 01
47 0E6D6.000 000 18
59 0E6D6.000 014 01
47 0E6D7.000 000 18
59 0E6D7.000 014 01
47 0E6D8.000 000 18
59 0E6D8.000 014 01
47 0E6D9.000 000 18
59 0E6D9.000 014 01
47 0E6DA.000 000 18
59 0E6DA.000 014 01
47 0E6DB.000 000 18
59 0E6DB.000 014 01
47 0E6DC.000 000 18
59 0E6DC.000 014 01
47 0E6DD.000 000 18
59 0E6DD.000 014 01
47 0E6DE.000 000 18
59 0E6DE.000 014 01
47 0E6DF.000 000 17
43 0E6DF.000 00E 01
59 0E6DF.000 014 01
47 0E6E0.000 000 18
59 0E6E0.000 014 01
47 0E6E1.000 000 18
59 0E6E1.000 014 01
47 0E6E2.000 000 18
59 0E6E2.000 014 01
47 0E6E3.000 000 18
59 0E6E3.000 014 01
47 0E6E4.000 000 18
59 0E6E4.000 014 01
47 0E6E5.000 000 18
59 0E6E5.000 014 01
47 0E6E6.000 000 18
59 0E6E6.000 014 01
47 0E6E7.000 000 18
60 0E6E7.000 014 04
47 0E6E8.000 000 04
60 0E6E8.000 000 04
47 0E6E9.000 000 04
60 0E6E9.000 000 04
47 0E6EA.000 000 04
60 0E6EA.000 000 04
47 0E6EB.000 000 04
60 0E6EB.000 000 04
47 0E6EC.000 000 03
60 0E6EC.000 000 03
47 0E6ED.000 000 03
60 0E6ED.000 000 03
47 0E6EE.000 000 03
60 0E6EE.000 000 03
47 0E6EF.000 000 03
60 0E6EF.000 000 03
47 0E6F0.000 000 03
60 0E6F0.000 000 03
47 0E6F1.000 000 03
60 0E6F1.000 000 03
47 0E6F2.000 000 03
60 0E6F2.000 000 03
47 0E6F3.000 000 03
60 0E6F3.000 000 03
47 0E6F4.000 000 03
60 0E6F4.000 000 03
47 0E6F5.000 000 03
60 0E6F5.000 000 03
47 0E6F6.000 000 03
60 0E6F6.000 000 03
47 0E6F7.000 000 03
60 0E6F7.000 000 03
47 0E6F8.000 000 03
60 0E6F8.000 000 03
47 0E6F9.000 000 03
60 0E6F9.000 000 03
47 0E6FA.000 000 03
60 0E6FA.000 000 03
47 0E6FB.000 000 03
60 0E6FB.000 000 03
47 0E6FC.000 000 03
60 0E6FC.000 000 03
47 0E6FD.000 000 03
60 0E6FD.000 000 03
47 0E6FE.000 000 03
60 0E6FE.000 000 03
47 0E6FF.000 000 03
60 0E6FF.000 000 03
47 0E700.000 000 03
60 0E700.000 000 03
47 0E701.000 000 03
60 0E701.000 000 03
47 0E702.000 000 03
60 0E702.000 000 03
47 0E703.000 000 03
60 0E703.000 000 03
47 0E704.000 000 03
60 0E704.000 000 03
47 0E705.000 000 03
60 0E705.000 000 03
47 0E706.000 000 03
60 0E706.000 000 03
47 0E707.000 000 03
60 0E707.000 000 03
47 0E708.000 000 03
60 0E708.000 000 03
47 0E709.000 000 03
60 0E709.000 000 03
47 0E70A.000 000 03
60 0E70A.000 000 03
47 0E70B.000 000 03
60 0E70B.000 000 03
47 0E70C.000 000 03
60 0E70C.000 000 03
47 0E70D.000 000 03
60 0E70D.000 000 03
47 0E70E.000 000 03
60 0E70E.000 000 03
47 0E70F.000 000 03
60 0E70F.000 000 03
47 0E710.000 000 03
60 0E710.000 000 03
47 0E711.000 000 03
60 0E711.000 000 03
47 0E712.000 000 03
60 0E712.000 000 03
47 0E713.000 000 03
60 0E713.000 000 03
47 0E714.000 000 03
60 0E714.000 000 03
47 0E715.000 000 03
60 0E715.000 000 03
47 0E716.000 000 03
60 0E716.000 000 03
47 0E717.000 000 03
60 0E717.000 000 03
47 0E718.000 000 03
60 0E718.000 000 03
47 0E719.000 000 03
60 0E719.000 000 03
47 0E71A.000 000 03
60 0E71A.000 000 03
47 0E71B.000 000 03
60 0E71B.000 000 03
47 0E71C.000 000 03
60 0E71C.000 000 03
47 0E71D.000 000 03
60 0E71D.000 000 03
47 0E71E.000 000 03
60 0E71E.000 000 03
47 0E71F.000 000 03
60 0E71F.000 000 03
47 0E720.000 000 03
60 0E720.000 000 03
47 0E721.000 000 03
60 0E721.000 000 03
47 0E722.000 000 03
60 0E722.000 000 03
47 0E723.000 000 03
60 0E723.000 000 03
47 0E724.000 000 03
60 0E724.000 000 03
47 0E725.000 000 03
60 0E725.000 000 03
47 0E726.000 000 03
60 0E726.000 000 03
47 0E727.000 000 03
60 0E727.000 000 03
47 0E728.000 000 03
60 0E728.000 000 03
47 0E729.000 000 03
60 0E729.000 000 03
47 0E72A.000 000 03
60 0E72A.000 000 03
47 0E72B.000 000 03
60 0E72B.000 000 03
47 0E72C.000 000 03
60 0E72C.000 000 03
47 0E72D.000 000 03
60 0E72D.000 000 03
47 0E72E.000 000 03
60 0E72E.000 000 03
47 0E72F.000 000 03
60 0E72F.000 000 03
47 0E730.000 000 03
60 0E730.000 000 03
47 0E731.000 000 03
60 0E731.000 000 03
47 0E732.000 000 03
60 0E732.000 000 03
47 0E733.000 000 03
60 0E733.000 000 03
47 0E734.000 000 03
60 0E734.000 000 03
47 0E735.000 000 03
60 0E735.000 000 03
47 0E736.000 000 03
60 0E736.000 000 03
47 0E737.000 000 03
60 0E737.000 000 03
47 0E738.000 000 03
60 0E738.000 000 03
47 0E739.000 000 03
60 0E739.000 000 03
47 0E73A.000 000 03
60 0E73A.000 000 03
47 0E73B.000 000 03
60 0E73B.000 000 03
47 0E73C.000 000 03
60 0E73C.000 000 03
47 0E73D.000 000 03
60 0E73D.000 000 03
47 0E73E.000 000 03
60 0E73E.000 000 03
47 0E73F.000 000 03
60 0E73F.000 000 03
60 0E6D5.000 014 03
60 0E6D6.000 014 03
60 0E6D7.000 014 03
60 0E6D8.000 014 03
60 0E6D9.000 014 03
60 0E6DA.000 014 03
60 0E6DB.000 014 03
60 0E6DC.000 014 03
60 0E6DD.000 014 03
60 0E6DE.000 014 03
60 0E6DF.000 014 03
60 0E6E0.000 014 03
60 0E6E1.000 014 03
60 0E6E2.000 014 03
60 0E6E3.000 014 03
60 0E6E4.000 014 03
60 0E6E5.000 014 03
60 0E6E6.000 014 03
ASCII logging off
EP=0, TA=0, HiGain=1, OTRd=0, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Data=40, Write=40, ID=1E
                          Power Cycling
    Code - 47  Track 0E6D9.0.006  Sns 01A  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 43  Track 0E6D9.0.006  Sns 01A  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
ASCII logging on
(SN: 3JX0TMSL)
.PW 3JX0TMSL
ASCII logging off
.107
Channel Srvo Table
                          Power Cycling
OkEnd Test 02
Begin Test 03
ASCII logging on
DBackReg 30 = 0087
DBackReg 3E = 0026
DAC offset =  0038 DAC bits.
00100          00EF         00EB
00300          008D         00C6
00500          008E         0090
00700          0087         006E
00900          0079         0062
00B00          0096         009C
00D00          0095         0091
00F00          004A         0037
01100          0042         0028
01300          0035         001F
01500          0033         0030
01700          003A         0022
01900          003F         0030
01B00          004D         0034
01D00          0053         0043
01F00          0054         003E
02100          0059         0083
02300          0054         007B
02500          0052         0048
02700          0085         0094
02900          0081         007F
02B00          004A         0034
02D00          004A         0041
02F00          0048         002F
03100          004C         0031
03300          0047         0030
03500          004A         0040
03700          0048         0031
03900          0046         002E
03B00          0043         002F
03D00          0042         003B
03F00          0043         002C
04100          0045         006D
04300          0042         0069
04500          0041         0040
04700          0073         0072
04900          0042         002B
04B00          0039         0026
04D00          003F         0039
04F00          0037         001E
05100          0035         001E
05300          0030         001C
05500          002F         0019
05700          0032         0014
05900          002F         0015
05B00          002E         0015
05D00          002E         001B
05F00          0031         0019
06100          002F         0055
06300          0030         0057
06500          0031         0019
06700          0033         0019
06900          002F         0017
06B00          002D         0016
06D00          005C         005C
06F00          0031         0019
07100          0030         0017
07300          002D         0011
07500          0028         0010
07700          0027         0010
07900          002A         0013
07B00          002C         0014
07D00          002D         0010
07F00          0028         000B
08100          0026         004F
08300          0023         0047
08500          0023         000E
08700          0026         000A
08900          0025         0008
08B00          004D         004F
08D00          0022         000B
08F00          005A         0009
09100          001E         0006
09300          001E         0003
09500          001E         0006
09700          0020         0008
09900          001E         0008
09B00          001D         0005
09D00          001C         0003
09F00          0020         0008
0A100          0022         0042
0A300          001F         0042
0A500          0046         0046
0A700          0017        -0001
0A900          0016        -0002
0AB00          0016        -0002
0AD00          0014        -000B
0AF00          0008        -000D
0B100          000D        -000A
0B300          0011         0008
0B500          0009        -000F
0B700          0008        -0016
0B900          0005        -0016
0BB00          0004        -0018
0BD00          0002        -0015
0BF00          0002        -0014
0C100          0006        -000D
0C300          000A        -000F
0C500          003A         003A
0C700          0020         0006
0C900          0022         000D
0CB00          0027         0010
0CD00          002D         0014
0CF00          0029         0014
0D100          0024         000A
0D300          0018        -0002
0D500          0008        -000E
0D700          0039        -001E
0D900          000C         000D
0DB00         -0023        -0039
0DD00         -0029        -0045
0DF00         -002B        -0048
0E100         -002F        -0008
0E300         -002B        -0003
0E500         -0026        -003D
0E700          0007         0009
0E900         -0015        -002D
0EB00         -000C        -0022
0ED00          001C         0020
0EF00         -000B        -0025
0F100         -0013        -0029
0F300         -0019        -002F
0F500         -001D        -0035
0F700         -0022        -003B
0F900         -0026        -0044
0FB00         -0028        -0044
0FD00         -0027        -003F
0FF00         -0024        -003B
10100         -0020         0002
10300          0008         0014
10500         -0011         000F
10700         -000D        -0029
10900         -000B        -0020
10B00         -0005        -0020
10D00         -0004        -0020
10F00         -0002        -001F
11100          0001        -001C
11300          0027        -0015
11500          0008         002A
11700          000A        -0015
11900          000E         000B
11B00          0018        -0009
11D00          0059        -0003
11F00          001D         0001
12100          0024         0044
12300          0024         0045
12500          002C         000F
12700          0033         0018
12900          005F         0060
12B00          004E         002A
12D00          0055         0034
12F00          0062         0043
13100          0073         006C
13300          0076         005B
13500          0082         0066
13700          008B         006C
13900          009D         009C
13B00          00AC         0087
13D00          00B7         009A
13F00          00F2         00F5
14100          00DF         00F5
14300          00EC         0115
14500          0108         00E7
14700          011A         00FE
14900          0145         0142
14B00          017D         017D
14D00          016C         014A
14F00          0189         0169
15100          01B2         01B6
15300          01C7         01A4
15500          0227         01CB
15700          020C         022A
15900          0243         0246
15B00          0256         0240
15D00          0282         026A
15F00          02A7         0297
16100          02EA         0315
16300          0355         035E
Cyl = 0162AC
Cyl = 0002D4
Cyl = 00B2C0
Head Gain Measure
   00  3B52  33B3  336F  3484  3475  3602  3B52  3B0C  3576
   00  0000  037C  06F3  0A7D  0E06  11AA  15A9  19A4  1D3E
   00  FFC0  FFCF  FFDE  FFEE  FFFD  000D  001F  0030  0040
Channel Srvo Table
ACFC Calibration:
00018.00 00f4 0014 0001 0005 0019 0001 006d 0005 0000
02000.00 00f4 000a 0001 000a 0022 0001 0089 0005 0000
04000.00 00ca 000d 0001 0005 0029 0001 0099 0001 0000
06000.00 00b5 000a 0001 0001 0019 0000 0082 0009 0000
08000.00 00a4 000a 0001 0005 0022 0000 00a9 000a 0000
0a000.00 0091 000a 0004 0002 001d 0001 0082 0005 0000
0e000.00 0062 000a 0009 0008 0010 0002 0082 0001 0000
10000.00 0071 0005 0009 0008 0010 0000 0055 0004 0000
12000.00 0082 0009 0019 000d 0022 0001 0082 000d 0000
14000.00 0091 000a 0024 0014 0055 0002 0082 0005 0000
16000.00 0091 000a 0035 0022 00b9 0008 0082 000a 0000
ACFC Calibration:
00018.00 0001 0000 0000 0000 0002 0000 0001 0002 0000
02000.00 0004 0000 0000 0001 0000 0000 0004 0005 0000
04000.00 0004 0000 0000 0000 0001 0000 0001 0004 0000
06000.00 0001 0000 0000 0000 0001 0000 000a 0000 0000
08000.00 0001 0000 0000 0000 0001 0000 0000 0000 0000
0a000.00 0004 0000 0000 0000 0000 0000 0005 0001 0000
0e000.00 0001 0000 0000 0000 0000 0000 0001 0001 0000
10000.00 0001 0000 0000 0000 0000 0001 0001 0001 0000
12000.00 0001 0000 0000 0001 0000 0000 0001 0001 0000
14000.00 0001 0000 0000 0000 0000 0000 0001 0000 0000
16000.00 0001 0000 0000 0001 0001 0000 0001 0000 0000
Actuator Geometry Test ...
Geometry Difference = 1 Microseconds
ASCII logging off
    Code - 47  Track 0E6D9.0.046  Sns 046  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.046  Sns 046  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
AbEnd Test 03
Begin Test 4D
ASCII logging on
                      Not Power Cycling
ASCII logging off
ASCII logging on
Fail Log Summary .....
Cum Health = 608C
    Code - 47  Track 0E6D9.0.002  Sns 002  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6D9.0.006  Sns 006  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.060  Sns 060  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.06C  Sns 06C  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.070  Sns 070  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.072  Sns 072  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.109  Sns 109  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.117  Sns 117  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.123  Sns 123  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.12F  Sns 12F  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.13B  Sns 13B  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.147  Sns 147  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 43  Track 0E6DA.0.153  Sns 153  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.15F  Sns 15F  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.16B  Sns 16B  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.177  Sns 177  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.183  Sns 183  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.18F  Sns 18F  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.19B  Sns 19B  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.1A7  Sns 1A7  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.1B3  Sns 1B3  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.24D  Sns 24D  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.1BF  Sns 1BF  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DB.0.00A  Sns 00A  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.0C4  Sns 0C4  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.0B6  Sns 0B6  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E4.0.01F  Sns 01F  Rty FFFF.20.20FF  Rtf 1802  LBA 048C4916
    Code - 47  Track 0E6DA.0.1D7  Sns 1D7  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 43  Track 0E6DC.0.17D  Sns 17D  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.076  Sns 076  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.0BA  Sns 0BA  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6D9.0.0C6  Sns 0C6  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.03B  Sns 03B  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.03D  Sns 03D  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.1C7  Sns 1C7  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E1.0.18C  Sns 18C  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.1E1  Sns 1E1  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DB.0.010  Sns 010  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DB.0.204  Sns 204  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DC.0.179  Sns 179  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DC.0.17B  Sns 17B  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DC.0.17F  Sns 17F  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DD.0.0F4  Sns 0F4  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DE.0.069  Sns 069  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DA.0.1E5  Sns 1E5  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DE.0.25F  Sns 25F  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DF.0.1D4  Sns 1D4  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E0.0.149  Sns 149  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E1.0.0BE  Sns 0BE  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6E1.0.0C0  Sns 0C0  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E1.0.0C2  Sns 0C2  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6E1.0.196  Sns 196  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6E1.0.260  Sns 260  Rty FFFF.20.20FF  Rtf 1802  LBA 048C4916
    Code - 47  Track 0E6E3.0.08A  Sns 08A  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6E3.0.0E2  Sns 0E2  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E4.0.019  Sns 019  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.1E7  Sns 1E7  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6E3.0.0A2  Sns 0A2  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E1.0.18E  Sns 18E  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E3.0.0AA  Sns 0AA  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E3.0.0DC  Sns 0DC  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E3.0.0E6  Sns 0E6  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DE.0.06B  Sns 06B  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.1DB  Sns 1DB  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E4.0.1A1  Sns 1A1  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.1E9  Sns 1E9  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6E4.0.1E1  Sns 1E1  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6DA.0.21B  Sns 21B  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E4.0.221  Sns 221  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E4.0.023  Sns 023  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
    Code - 47  Track 0E6DC.0.17D  Sns 17D  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E7.0.154  Sns 154  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
    Code - 47  Track 0E6E3.0.1B0  Sns 1B0  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
Head Mask 0000 -
                      B
                      B
Switch to full int.
              Spin Ready
    Code - 47  Track 0E6D9.0.006  Sns 006  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
Error Reading Log
Scanning Log 8 ....      Code - 47  Track 0E6D9.0.076  Sns 076  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
Error Reading Log
    Code - 47  Track 0E6D9.0.076  Sns 076  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
Scanning Log 31 ....      Code - 47  Track 0E6DB.0.010  Sns 010  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
Error Reading Log
Scanning Log 32 ....      Code - 47  Track 0E6DB.0.204  Sns 204  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
Error Reading Log
Scanning Log 33 ....      Code - 47  Track 0E6DC.0.179  Sns 179  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
Error Reading Log
Scanning Log 34 ....      Code - 47  Track 0E6DC.0.17B  Sns 17B  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
Error Reading Log
Scanning Log 3A ....      Code - 47  Track 0E6DE.0.25F  Sns 25F  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
Error Reading Log
    Code - 47  Track 0E6E1.0.18E  Sns 18E  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
Head   #Defect   #Align radial defect(%)  EC59    EC60
0            .               .            Code - 47  Track 0E6E4.0.271  Sns 271  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
                          Power Cycling
ASCII logging off
    Code - 47  Track 0E6E3.0.0E6  Sns 0E6  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
AbEnd Test 4D
Begin Test 39
ASCII logging on
ASCII logging off
AbEnd Test 39
Begin Test 4E
ASCII logging on
                      Not Power Cycling
ASCII logging off
ASCII logging on
02: Log Read Not OK
03: Log Read Not OK
    Code - 47  Track 0E6D9.0.060  Sns 060  Rty FFFF.20.20FF  Rtf 1802  LBA 048C4916
04: Log Read Not OK
    Code - 47  Track 0E6D9.0.06C  Sns 06C  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
05: Log Read Not OK
06: Log Read Not OK
07: Log Read Not OK
10: Log Read Not OK
11: Log Read Not OK
    Code - 47  Track 0E6DA.0.123  Sns 123  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
12: Log Read Not OK
13: Log Read Not OK
14: Log Read Not OK
15: Log Read Not OK
    Code - 47  Track 0E6DA.0.153  Sns 153  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
16: Log Read Not OK
17: Log Read Not OK
    Code - 47  Track 0E6DA.0.16B  Sns 16B  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
18: Log Read Not OK
19: Log Read Not OK
    Code - 47  Track 0E6DA.0.183  Sns 183  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
1A: Log Read Not OK
1B: Log Read Not OK
    Code - 47  Track 0E6DA.0.19B  Sns 19B  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
1C: Log Read Not OK
    Code - 47  Track 0E6DA.0.1A7  Sns 1A7  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
1D: Log Read Not OK
1E: Log Read Not OK
2A: Log Read Not OK
1F: Log Read Not OK
2F: Log Read Not OK
    Code - 47  Track 0E6D9.0.0C4  Sns 0C4  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
0B: Log Read Not OK
09: Log Read Not OK
    Code - 47  Track 0E6E4.0.01F  Sns 01F  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
58: Log Read Not OK
    Code - 47  Track 0E6DA.0.1D7  Sns 1D7  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
21: Log Read Not OK
35: Log Read Not OK
    Code - 47  Track 0E6D9.0.076  Sns 076  Rty FFFF.20.20FF  Rtf 1822  LBA 048C4916
08: Log Read Not OK
0A: Log Read Not OK
0C: Log Read Not OK
0D: Log Read Not OK
    Code - 47  Track 0E6DA.0.03D  Sns 03D  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
0E: Log Read Not OK
20: Log Read Not OK
40: Log Read Not OK
25: Log Read Not OK
31: Log Read Not OK
32: Log Read Not OK
33: Log Read Not OK
34: Log Read Not OK
36: Log Read Not OK
    Code - 43  Track 0E6DD.0.0F4  Sns 0F4  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
37: Log Read Not OK
    Code - 47  Track 0E6DE.0.069  Sns 069  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
38: Log Read Not OK
    Code - 43  Track 0E6DA.0.1E5  Sns 1E5  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
26: Log Read Not OK
3A: Log Read Not OK
3B: Log Read Not OK
3C: Log Read Not OK
    Code - 43  Track 0E6E1.0.0BE  Sns 0BE  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
3D: Log Read Not OK
    Code - 47  Track 0E6E1.0.0C0  Sns 0C0  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
3E: Log Read Not OK
3F: Log Read Not OK
42: Log Read Not OK
    Code - 47  Track 0E6E1.0.260  Sns 260  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
43: Log Read Not OK
    Code - 47  Track 0E6E3.0.08A  Sns 08A  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
47: Log Read Not OK
4B: Log Read Not OK
    Code - 47  Track 0E6E4.0.019  Sns 019  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
56: Log Read Not OK
    Code - 47  Track 0E6DA.0.1E7  Sns 1E7  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
27: Log Read Not OK
48: Log Read Not OK
41: Log Read Not OK
49: Log Read Not OK
    Code - 47  Track 0E6E3.0.0DC  Sns 0DC  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
4A: Log Read Not OK
4D: Log Read Not OK
39: Log Read Not OK
    Code - 47  Track 0E6DA.0.1DB  Sns 1DB  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
22: Log Read Not OK
61: Log Read Not OK
    Code - 47  Track 0E6DA.0.1E9  Sns 1E9  Rty FFFF.20.20FF  Rtf 1820  LBA 048C4916
28: Log Read Not OK
    Code - 47  Track 0E6E4.0.1E1  Sns 1E1  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
62: Log Read Not OK
29: Log Read Not OK
63: Log Read Not OK
59: Log Read Not OK
35: Log Read Not OK
6F: Log Read Not OK
Total Cert Time = 00:00:00
ASCII logging off
    Code - 47  Track 0E6E3.0.1B0  Sns 1B0  Rty FFFF.20.20FF  Rtf 1800  LBA 048C4916
AbEnd Test 4E
T>
作者: 夜雨十三天    时间: 2008-7-16 16:23
换固件试试
如果不行应该是磁头挂了!
磁头挂的几率很大!
作者: 夜雨十三天    时间: 2008-7-16 16:30
另外你这个提问就有问题!:" .7的SF LOG 到4E异常停止"
不是LOG到4E停止!当测试过一个代码后,会把LOG写到硬盘里!
另外4E记录的应该是校准中各个流程的时间!
如果说停止也应该是从03后面就停止了! 注意这里的代码!
AbEnd Test 03
Begin Test 4D
自己找个K7盘的SF LOG看看4D应该是快结束时的流程!
停止的原因可能是固件有问题或磁头有问题! 自己找解决方案吧!
作者: 孤帆远影    时间: 2008-7-16 16:42
是O头挂了
问了火速
火速也教了从那个信息看出的0头挂了
其实错误的TEST信息也可以学点东西
[ 本帖最后由 孤帆远影 于 2008-7-16 16:43 编辑 ]
作者: cqzuo    时间: 2008-7-16 17:52
恩,同意十三看法,不过还是换板试下F维修看。如果还这样只有挂主头了还有可能转换器坏了。其实ST的是最好修的,个人认为。
