标题: 希捷串口7代盘No log 4E on disk [打印本页] 作者: 毅然坚强 时间: 2008-7-2 09:02 标题: 希捷串口7代盘No log 4E on disk Interface task reset
4096k x 16 buffer detected
PUMA - 1_Disk M-22f 06-01-05 09:44
Head Mask FFFF - Switch to full int.
Spin Ready
3.42 07-18-05 10:42 4096k x 16 buffer
(P)(H)SATA Reset
Not Interface Age!
AutoRd Err 43 at ffffffff.00.012e
INVALID Cert Disk Code - ROM Resident Revision Required: 3.42
Command Inactive - No VALID Cert Code Detected
T>E4E
No log 4E on disk
T>N2,,22
T>No valid SeaDex script in buffer.
Begin Test 02
ASCII logging on
Not Power Cycling
Temp Diode 008B
( 27 C )
Not Power Cycling
Zones 0-F, Heads 0-1, adaptives set to defaults
Head Mask FFFF -
Read Bias - Head 0 1 2 3
9 9
Spin Ready
ASCII logging off
MRASYM 80 00009c47 BER 00000002
MRASYM 7d 00009bd2 BER 00000002 update 7d hold
Servo Zone 11, OD [0000D8AA.0,FC5D,025D,C0]
Left Bath = FEF0, Right Bath = FFE7 : Pick (FF6B) ( Min/Max AGC 51FF )
Servo Zone 11, ID [0000EDEF.0,FD09,0309,C0]
Left Bath = FFB4, Right Bath = 0084 : Pick (001C) ( Min/Max AGC 7EFF )
Servo Zone 12, OD [0000EE00.0,FD0A,030A,C0]
Left Bath = FFAF, Right Bath = 0081 : Pick (0018) ( Min/Max AGC 7EFF )
Servo Zone 12, ID [000103CB.0,FDBF,03BF,C0]
Left Bath = 0056, Right Bath = 014B : Pick (00D0) ( Min/Max AGC 52FF )
Test 0000f313.00 0000946a BER 00000fff
Servo Zone 0, OD [00000020.0,F70D,FD0D,C0]
Left Bath = F988, Right Bath = FA73 : Pick (F9FD) ( Min/Max AGC 41FF )
Servo Zone 0, ID [00000067.0,F73C,FD3C,C0]
Left Bath = F982, Right Bath = FA6D : Pick (F9F7) ( Min/Max AGC 43FF )
Servo Zone 1, OD [00000078.0,F744,FD44,C0]
Left Bath = F982, Right Bath = FA69 : Pick (F9F5) ( Min/Max AGC 45FF )
Servo Zone 1, ID [00000759.0,F769,FD69,C0]
Left Bath = F9AD, Right Bath = FA9C : Pick (FA24) ( Min/Max AGC 43FF )
Servo Zone 2, OD [0000076A.0,F76A,FD6A,C0]
Left Bath = F9A1, Right Bath = FA8D : Pick (FA17) ( Min/Max AGC 46FF )
Servo Zone 2, ID [00000E52.0,F787,FD87,C0]
Left Bath = F9CE, Right Bath = FABA : Pick (FA44) ( Min/Max AGC 44FF )
Servo Zone 3, OD [00000E63.0,F788,FD88,C0]
Left Bath = F9BF, Right Bath = FAB2 : Pick (FA38) ( Min/Max AGC 47FF )
Servo Zone 3, ID [00001713.0,F7AF,FDAF,C0]
Left Bath = FA00, Right Bath = FAF3 : Pick (FA79) ( Min/Max AGC 42FF )
Test 0000130d.00 0000d1ea BER 00000fff
Test 0000f313.00 0000980b BER 00000fff
Adjust ATTR 01 VGAS 3d VGAR 77 FREQR 80 within _ATT
MRASYM 7d 0000972b BER 00000fff
MRASYM 89 00009756 BER 00000fff hold
Default Tap Weight 00000000 Settle Tap Weight 00000154
XDCTAP 96 0000587e BER 00000000 adapt
XDCTAP 7f 00005979 BER 00000000 hold
CUTOFF Lower 021b Upper 032f Step 0003 Right 17 Mask 00000008
Default 033a 000059d8 BER 00000000
Floor 1 10 0000c13c 00014a1b
Left 1 0318 0000aaab
Middle 0 0321 00006864
Right 1 032f 000066ad
Lowest 1 032a 00006669
Restore 033a 00005a1d BER 00000000
Update Default Servo Cutoff and Range 033A
SV TAP5 Lower 0020 Upper 00df Step 0006 Right 1f Mask 00001000
Default 0065 00005a0a BER 00000000
Floor 1 20 00005f75 00005f75
Left 1 0026 00005822
Middle 1 004f 00005684
Right 1 0079 00005eb5
Lowest 1 0032 00005553
Z = -A1/(2*A2) : FFE0
X = Z + Xavg : FFEF
Curve 00d4 0000659c
New 004f 00005627 BER 00000000
00005627 BER 00000000 _ATT 01 VGAS 3d VGAR 66 FREQR 81 Taps frozen read adapt
Current Tap Weight 00004971 diff ffffb68f tap limits
000055f1 BER 00000000 _ATT 01 VGAS 3e VGAR 61 FREQR 80 Taps frozen read adapt
Current Tap Weight 0000002f diff 00004942 tap limits
000055fd BER 00000000 _ATT 01 VGAS 3d VGAR 67 FREQR 81 Taps frozen read adapt
Current Tap Weight 00000030 diff ffffffff Save servo Force servo update
Rbck Default DATA load
Test 0000f313.00 00009c5a BER 00000fff
Adapt Servo 0000f313.01
Adapts Loaded
Rbck DATA load
NPML 00
Test 0000f313.01 0000e269 BER 00000004
Adjust ATTR 00 VGAS 6a VGAR 6f FREQR 7f within _ATT
MRASYM 80 0000f229 BER 0000000a
MRASYM ba 0000bb6d BER 00000006 update ba hold
Servo Zone 11, OD [0000D843.1,FC5D,025D,C0]
Left Bath = FF14, Right Bath = FFDD : Pick (FF78) ( Min/Max AGC 78FF )
Servo Zone 11, ID [0000ED88.1,FD09,0309,C0]
Left Bath = FFCC, Right Bath = 0090 : Pick (002E) ( Min/Max AGC 7CFF )
Servo Zone 12, OD [0000ED99.1,FD0A,030A,C0]
Left Bath = FFCE, Right Bath = 0095 : Pick (0031) ( Min/Max AGC 7EFF )
Servo Zone 12, ID [00010364.1,FDBF,03BF,C0]
Left Bath = 0087, Right Bath = 014E : Pick (00EA) ( Min/Max AGC 7EFF )
Test 0000f313.01 00007131 BER 00000fff
Servo Zone 1, OD [00000020.1,F744,FD44,C0]
Left Bath = F987, Right Bath = FA41 : Pick (F9E4) ( Min/Max AGC 6FFF )
Servo Zone 1, ID [000006F2.1,F769,FD69,C0]
Left Bath = F9AE, Right Bath = FA75 : Pick (FA11) ( Min/Max AGC 68FF )
Servo Zone 2, OD [00000703.1,F76A,FD6A,C0]
Left Bath = F9A7, Right Bath = FA67 : Pick (FA07) ( Min/Max AGC 6CFF )
Servo Zone 2, ID [00000DEB.1,F787,FD87,C0]
Left Bath = F9D9, Right Bath = FA96 : Pick (FA37) ( Min/Max AGC 6FFF )
Servo Zone 3, OD [00000DFC.1,F788,FD88,C0]
Left Bath = F9CC, Right Bath = FA86 : Pick (FA29) ( Min/Max AGC 6FFF )
Servo Zone 3, ID [000016AC.1,F7AF,FDAF,C0]
Left Bath = FA07, Right Bath = FAC7 : Pick (FA67) ( Min/Max AGC 6CFF )
Test 0000130d.01 0000abf7 BER 00000fff
Test 0000f313.01 00006dd8 BER 00000fff
Adjust ATTR 00 VGAS 69 VGAR 6b FREQR 81 within _ATT
MRASYM ba 00006e9a BER 00000fff
MRASYM b4 000070a3 BER 00000fff hold
XDCTAP 96 00005db6 BER 00000000 adapt
XDCTAP 7c 00005f91 BER 00000000 hold
Default 033a 00005ff7 BER 00000000
Floor 1 0f 0000afb2 000123b3
Left 1 0318 0000a850
Middle 0 0321 000074b5
Right 1 032f 0000727b
Lowest 1 032d 0000727b
Restore 033a 0000610d BER 00000000
Default 0065 00006174 BER 00000000
Floor 1 20 00006c6c 00006c6c
Left 1 0032 000063af
Middle 1 005e 00006097
Right 1 008b 000069a8
Lowest 1 004a 00005d08
Z = -A1/(2*A2) : FFFF
X = Z + Xavg : 000E
Curve 0074 0000660e
New 005e 00005ef2 BER 00000000
00005ee8 BER 00000000 _ATT 01 VGAS 6d VGAR 61 FREQR 82 Taps frozen read adapt
Current Tap Weight 00004579 diff ffffba87 tap limits
00005f8b BER 00000000 _ATT 01 VGAS 6f VGAR 61 FREQR 81 Taps frozen read adapt
Current Tap Weight 0000001a diff 0000455f tap limits
00005f47 BER 00000000 _ATT 01 VGAS 6c VGAR 62 FREQR 81 Taps frozen read adapt
Current Tap Weight 0000000e diff 0000000c Save servo Force servo update
Test 0000f313.01 0000817c BER 00000fff作者: 毅然坚强 时间: 2008-7-2 09:06
HiTemp Bias BackOff Head 0 1 2 3
9 9
Media 0000
Adapt Data Zone 00
Test 000009a2.00 0000cc7c BER 00000003
Test 000009a2.00 0000d608 BER 00000003
Adapt Data 000009a2.00
Rbck DATA load
MRASYM 80 0000ce41 BER 00000002
MRASYM 94 0000cba2 BER 00000001 update 94 hold
Test 00000020.00 0000be83 BER 00000001
Servo Zone 00 OD OFST Lower f99d Upper fa5c Step 0006 Right 1f Mask 00004340
Default f9fd 0000c4b5 BER 00000003
Floor 1 1f 00031db2 00031db2
Left 1 f9c7 00030aaa
Middle 1 fa05 0000c150
Right 1 fa44 00031506
Lowest 1 fa09 0000b9fd
Z = -A1/(2*A2) : 359A
X = Z + Xavg : 35A9
Curve fa51 00060f72
New fa05 0000bda7 BER 00000000 AUTO
Test 00000067.00 0000b502 BER 00000000
Servo Zone 00 ID OFST Lower f997 Upper fa56 Step 0006 Right 1f Mask 00008340
Default f9f7 0000bb51 BER 00000000
Floor 1 20 00033954 00033954
Left 1 f9c1 0002c9a5
Middle 1 f9ff 0000b8de
Right 1 fa3e 000257dd
Lowest 1 fa03 0000b2ca
Z = -A1/(2*A2) : FBD8
X = Z + Xavg : FBE7
Curve fa4b 00054eac
New f9ff 0000b4b3 BER 00000000 AUTO
Test 00000078.00 0000c722 BER 00000000
Servo Zone 01 OD OFST Lower f995 Upper fa54 Step 0006 Right 1f Mask 00004340
Default f9f5 0000c0ba BER 00000000
Floor 1 1c 000310cb 000310cb
Left 1 f9cb 00027d8e
Middle 1 fa03 0000b3b8
Right 1 fa3c 0002e8b0
Lowest 1 fa07 0000af71
Z = -A1/(2*A2) : 0000
X = Z + Xavg : 000F
Curve f9ef 0000d55f
New fa03 0000b48c BER 00000000 AUTO
Test 00000759.00 0000c275 BER 00000001
Servo Zone 01 ID OFST Lower f9c4 Upper fa83 Step 0006 Right 1f Mask 00008340
Default fa24 0000c8b7 BER 00000001
Floor 1 1e 00040f1d 00040f1d
Left 1 f9fa 0003f1ce
Middle 1 fa35 0000bcdd
Right 1 fa71 00033c52
Lowest 1 fa30 0000bcdd
X = Z + Xavg : 000F
Curve fa1e 0000dddb
New fa35 0000c272 BER 00000003 AUTO
Test 0000076a.00 0000be88 BER 00000000
Servo Zone 02 OD OFST Lower f9b7 Upper fa76 Step 0006 Right 1f Mask 00004340
Default fa17 0000c0bc BER 00000000
Floor 1 1d 000385ef 000385ef
Left 1 f9f3 0002f8f3
Middle 1 fa2b 0000bf5b
Right 1 fa64 0003497e
Lowest 1 fa1d 0000ba36
X = Z + Xavg : 000F
Curve fa11 0000e30f
New fa2b 0000c38f BER 00000000
Test 00000e52.00 0000c6ad BER 00000001
Servo Zone 02 ID OFST Lower f9e4 Upper faa3 Step 0006 Right 1f Mask 00008340
Default fa44 0000bec2 BER 00000000
Floor 1 1d 0003a537 0003a537
Left 1 fa1a 0002eaa9
Middle 1 fa55 0000bda3
Right 1 fa91 0003988d
Lowest 1 fa50 0000bda3
X = Z + Xavg : 000F
Curve fa3e 0000cd82
New fa55 0000c394 BER 00000001
Test 00000e63.00 0000ccb0 BER 00000003
Servo Zone 03 OD OFST Lower f9d8 Upper fa97 Step 0006 Right 1f Mask 00004340
Default fa38 0000c362 BER 00000000
Floor 1 1c 0003728a 0003728a
Left 1 fa14 0002b4c7
Middle 1 fa4c 0000bf6c
Right 1 fa85 0002d041
Lowest 1 fa44 0000bde7
X = Z + Xavg : 000F
Curve fa32 0000e479
New fa4c 0000c58c BER 00000001
Adjust ATTR 01 VGAS 64 VGAR 5c FREQR 81 within _ATT VGAR FREQR
Test 000009a2.00 0000c660 BER 00000000
Noise target 00000000
Rbck Noise OFF
Rbck DATA save
WRITE_I Lower 0003 Upper 001b Step 0001 Right 18 Mask 00000342
Default 000e 0000db90 BER 00000002
Floor 1 0e 0000dc44 0000e0ac
Left 1 0009 0000dbf5
Middle 1 000f 0000da9e
Right 1 0016 0000d9d0
Lowest 1 000b 0000d708
X = Z + Xavg : 000C
Curve 000f 0000da9e
New 000f 0000ec4a BER 00000003
Test 000009a2.00 0000be3c BER 00000000
MRASYM 94 0000be2b BER 00000001
MRASYM 8d 0000bce9 BER 00000000 update 8d hold
PRECOMP Lower 0000 Upper 000a Step 0001 Right 0a Mask 00000004
Default 0003 0000c014 BER 00000000
Floor 1 0b 0000ca8e 0000e0e9
Left 1 0000 0000ca8e
Middle 1 0002 0000ca06
Right 1 0004 0000c987
Lowest 1 0001 0000bb66
Z = -A1/(2*A2) : FFFC
X = Z + Xavg : 0001
Curve 0001 0000bb66
New 0002 0000bc2a BER 00000000
Test 000009a2.00 0000bcac BER 00000001
XDCTAP 96 0000c23b BER 00000000 adapt
XDCTAP 69 0000c319 BER 00000001 hold
CUTOFF Lower 0514 Upper 0538 Step 0002 Right 12 Mask 00000348
Default 052c 0004fa9d BER 00000001
Floor 1 0f 0005017f 00052462
Left 1 0522 0004e513
Middle 1 0528 0004f183
Right 1 0530 0004ff33
Lowest 1 0524 0004dda5
New 0528 0004f717 BER 00000000 AUTO
BOOST Lower 0000 Upper 0016 Step 0001 Right 16 Mask 00000360
Default 000b 00050f3c BER 00000000
Floor 1 17 00054726 0005effa
Left 1 0000 00054726
Middle 1 0006 000521d8
Right 1 000c 00052465
Lowest 1 0009 0004fee4
Z = -A1/(2*A2) : FFFD
X = Z + Xavg : 0008
Curve 0008 000510ba
New 0006 0004d9fe BER 00000000 AUTO
TAPDELT Lower 0000 Upper 000f Step 0001 Right 0f Mask 00000350
Default 000b 0004fe99 BER 00000000
Floor 1 10 0005a3f8 0006e40a
Left 1 0007 00057d3b
Middle 1 000b 0004f2f5
Right 1 000f 0005a3f8
Lowest 1 000b 0004f2f5
Z = -A1/(2*A2) : 0004
X = Z + Xavg : 000B
Curve 000b 0004f2f5
New 000b 0004ffd6 BER 00000000作者: 毅然坚强 时间: 2008-7-2 09:06
Servo Zone 00 OD OFST Lower f9a5 Upper fa64 Step 0006 Right 1f Mask 00004340
Default fa05 0000bd81 BER 00000000
Floor 1 20 00035bcd 00035bcd
Left 1 f9c9 0002dbbb
Middle 1 fa07 0000bddf
Right 1 fa46 00032d61
Lowest 1 fa05 0000bddf
Z = -A1/(2*A2) : 1EC4
X = Z + Xavg : 1ED3
Curve fa59 00095b36
New fa07 0000c2b2 BER 00000000
Servo Zone 00 ID OFST Lower f99f Upper fa5e Step 0006 Right 1f Mask 00008340
Default f9ff 0000be00 BER 00000000
Floor 1 20 0003099d 0003099d
Left 1 f9c3 00027389
Middle 1 fa01 0000b93f
Right 1 fa40 00029463
Lowest 1 fa05 0000b7db
Z = -A1/(2*A2) : FBD6
X = Z + Xavg : FBE5
Curve fa53 0007ee71
New fa01 0000bfab BER 00000000
Servo Zone 01 OD OFST Lower f9a3 Upper fa62 Step 0006 Right 1f Mask 00004340
Default fa03 0000bbe3 BER 00000000
Floor 1 1f 00042bc5 00042bc5
Left 1 f9c7 0003178f
Middle 1 fa02 0000c5bc
Right 1 fa3e 000380f6
Lowest 1 fa09 0000bc5d
Z = -A1/(2*A2) : 6252
X = Z + Xavg : 6261
Curve fa57 000e154d
New fa02 0000bd79 BER 00000001
Servo Zone 01 ID OFST Lower f9d5 Upper fa94 Step 0006 Right 1f Mask 00008340
Default fa35 0000ca7c BER 00000001
Floor 1 1f 0004226e 0004226e
Left 1 f9f9 0003d49c
Middle 1 fa37 0000c7ce
Right 1 fa76 00040db3
Lowest 1 fa2f 0000c21e
Z = -A1/(2*A2) : 2B01
X = Z + Xavg : 2B10
Curve fa89 000df0d1
New fa37 0000ca22 BER 00000000 AUTO
Servo Zone 02 OD OFST Lower f9cb Upper fa8a Step 0006 Right 1f Mask 00004340
Default fa2b 0000ca26 BER 00000000
Floor 1 1e 0003d99e 0003d99e
Left 1 f9ef 00036ecb
Middle 1 fa2a 0000c03d
Right 1 fa66 0003a9bd
Lowest 1 fa25 0000c03d
X = Z + Xavg : 000F
Curve fa25 0000c03d
New fa2a 0000c618 BER 00000000 AUTO
Servo Zone 02 ID OFST Lower f9f5 Upper fab4 Step 0006 Right 1f Mask 00008340
Default fa55 0000ce3a BER 00000000
Floor 1 1d 0003af08 0003af08
Left 1 fa19 0003157c
Middle 1 fa54 0000cd9e
Right 1 fa90 00031c41
Lowest 1 fa55 0000c9a4
X = Z + Xavg : 000F
Curve fa4f 0000cd9e
New fa54 0000c8f8 BER 00000001 AUTO
Servo Zone 03 OD OFST Lower f9ec Upper faab Step 0006 Right 1f Mask 00004340
Default fa4c 0000ca62 BER 00000001
Floor 1 1c 00037742 00037742
Left 1 fa16 0002bfca
Middle 1 fa4e 0000d13a
Right 1 fa87 0002ea95
Lowest 1 fa40 0000c530
X = Z + Xavg : 000F
Curve fa46 0000ce8a
New fa4e 0000c9bb BER 00000000 AUTO
CUTOFF Lower 0522 Upper 0530 Step 0001 Right 0e Mask 00000348
Default 0528 00050540 BER 00000001
Floor 1 07 00050883 00051760
Left 1 0524 0004ffa3
Middle 1 0528 00050921
Right 1 052c 0004faee
Lowest 1 052c 0004faee
New 0528 000527ab BER 00000000
BOOST Lower 0000 Upper 000d Step 0001 Right 0d Mask 00000360
Default 0006 0004f4a0 BER 00000001
Floor 1 0e 00051043 00051b48
Left 1 0000 00051043
Middle 1 0004 0004f829
Right 1 0009 00050bf8
Lowest 1 0006 0004e21c
X = Z + Xavg : 0005
Curve 0005 0004fdf7
New 0004 000502b1 BER 00000001
Default 000b 0004ec91 BER 00000000
Floor 1 10 0005b1a2 000712e7
Left 1 0009 0005a620
Middle 1 000c 000520a2
Right 1 000f 0005b1a2
Lowest 1 000b 00050430
X = Z + Xavg : 000B
Curve 000b 00050430
New 000c 0004f1c4 BER 00000001
Rbck Noise OFF
Adjust ATTR 01 VGAS 67 VGAR 70 FREQR 7f within _ATT VGAR FREQR
MRASYM 8d 0000c119 BER 00000003
MRASYM 8d 0000bb3f BER 00000005 update 8d adapt
Test 000009a2.00 0000b786 BER 00000000
MRASYM 8d 0000bac0 BER 00000001
MRASYM 7a 0000b2c4 BER 00000001 update 7a hold
NPML 03 0000b529 BER 00000000 NPML update
NPML 03 0001f2c3 BER 00000000
MRASYM 7a 0001f695 BER 00000001
MRASYM 7e 0001f1f6 BER 00000000 update 7e adapt
BETTER UPDATE TAPS Rbck DATA save
Media 0000
Test 000009a2.01 0000b093 BER 00000000
Test 000009a2.01 0000acbf BER 00000000
Adapt Data 000009a2.01
Rbck DATA load
NPML 00
Test 000009a2.01 0000b3f2 BER 00000000
Adjust ATTR 00 VGAS 9a VGAR 55 FREQR 7f within _ATT VGAR FREQR
MRASYM 80 0000d55d BER 00000002
MRASYM cb 0000b2c3 BER 00000000 update cb hold
Test 00000020.01 0000ada5 BER 00000002
Servo Zone 01 OD OFST Lower f984 Upper fa43 Step 0006 Right 1f Mask 00004340
Default f9e4 0000aff3 BER 00000000
Floor 1 1d 0003610c 0003610c
Left 1 f9b4 00033a00
Middle 1 f9f2 0000a94f
Right 1 fa31 0002885d
Lowest 1 f9f0 0000a94f
X = Z + Xavg : 000F
Curve f9de 0000c4e5
New f9f2 0000ad54 BER 00000000 AUTO
Test 000006f2.01 0000a7f0 BER 00000000
Servo Zone 01 ID OFST Lower f9b1 Upper fa70 Step 0006 Right 1f Mask 00008340
Default fa11 0000a6fb BER 00000000
Floor 1 1d 00030702 00030702
Left 1 f9e7 00025416
Middle 1 fa22 0000a5de
Right 1 fa5e 0002503a
Lowest 1 fa23 0000a357
X = Z + Xavg : 000F
Curve fa0b 0000b6f8
New fa22 0000a9ec BER 00000001
Test 00000703.01 0000b308 BER 00000002
Servo Zone 02 OD OFST Lower f9a7 Upper fa66 Step 0006 Right 1f Mask 00004340
Default fa07 0000ac85 BER 00000000
Floor 1 1b 00029001 00029001
Left 1 f9e3 0002324b
Middle 1 fa1b 0000aca0
Right 1 fa54 00027a65
Lowest 1 fa13 0000a4e0
Z = -A1/(2*A2) : 0947
X = Z + Xavg : 0956
Curve fa5b 0004a0bf
New fa1b 0000a6c4 BER 00000000 AUTO
Test 00000deb.01 0000a81b BER 00000000
Servo Zone 02 ID OFST Lower f9d7 Upper fa96 Step 0006 Right 1f Mask 00008340
Default fa37 0000a859 BER 00000000
Floor 1 1c 0002d544 0002d544
Left 1 fa07 000242b0
Middle 1 fa3f 0000b0a1
Right 1 fa78 000233c5
Lowest 1 fa43 0000a9b2
Z = -A1/(2*A2) : FCF0
X = Z + Xavg : FCFF
Curve fa8b 008db224
New fa3f 0000a91c BER 00000000
Test 00000dfc.01 0000b3ad BER 00000000
Servo Zone 03 OD OFST Lower f9c9 Upper fa88 Step 0006 Right 1f Mask 00004340
Default fa29 0000b276 BER 00000002
Floor 1 1b 0002bd9e 0002bd9e
Left 1 fa05 0002330e
Middle 1 fa3a 0000b11b
Right 1 fa70 00020050
Lowest 1 fa3b 0000ac39
X = Z + Xavg : 000F
Curve fa23 0000cda3
New fa3a 0000ae05 BER 00000000 AUTO
Adjust ATTR 00 VGAS 99 VGAR 57 FREQR 7d within _ATT VGAR FREQR
Test 000009a2.01 0000a7d7 BER 00000000
Rbck Noise OFF
Rbck DATA save
Default 000e 0000c288 BER 00000000
Floor 1 0f 0000be73 0000c5a2
Left 1 0011 0000bde0
Middle 1 0016 0000bc1e
Right 1 001b 0000bd6a
Lowest 1 0012 0000b7d7
Z = -A1/(2*A2) : 0009
X = Z + Xavg : 0015
Curve 0018 0000bdda
New 0016 0000c10f BER 00000002 AUTO
Test 000009a2.01 0000a0a0 BER 00000001
MRASYM cb 00009f06 BER 00000000
MRASYM be 00009f41 BER 00000000 hold
Default 0003 0000a614 BER 00000000
Floor 1 0b 000095b8 0000be7e
Left 1 0000 000095b8
Middle 1 0000 000095b8
Right 1 0000 000095b8
Lowest 1 0000 000095b8
Z = -A1/(2*A2) : FFFA
X = Z + Xavg : FFFF
Curve 0009 0000edd0
New 0000 0000950f BER 00000001
Test 000009a2.01 000094ee BER 00000000
XDCTAP 96 00009c24 BER 00000000 adapt
XDCTAP 68 00009b66 BER 00000000 hold
Default 052c 0004a3ae BER 00000000
Floor 1 0e 000496cf 000502ab
Left 1 0522 000487b1
Middle 1 052c 00048707
Right 1 0538 00048847
Lowest 1 0532 00048404
New 052c 00049ba4 BER 00000000 AUTO
Default 000b 00049a41 BER 00000000
Floor 1 17 00053e60 00053e60
Left 1 0005 000533dd
Middle 1 000b 0004a67e
Right 1 0011 00051d5e
Lowest 1 000c 00049cf6
X = Z + Xavg : 000B
Curve 000b 0004a67e
New 000b 0004a55a BER 00000001
Default 000b 0004b619 BER 00000000
Floor 1 10 0004e6dd 0005f302
Left 1 0007 0004b1c5
Middle 1 000b 0004981c
Right 1 000f 0004e6dd
Lowest 1 000d 0004874f
Z = -A1/(2*A2) : 0005
X = Z + Xavg : 000C
Curve 000c 00048ca9
New 000b 0004ac52 BER 00000000 AUTO
Servo Zone 01 OD OFST Lower f992 Upper fa51 Step 0006 Right 1f Mask 00004340
Default f9f2 0000ac26 BER 00000000
Floor 1 1f 0003fe13 0003fe13
Left 1 f9b6 000378c8
Middle 1 f9f4 0000b258
Right 1 fa33 00030699
Lowest 1 f9f8 0000b1f9
X = Z + Xavg : 000E
Curve f9e6 0000bbda
New f9f4 0000b31e BER 00000001
Servo Zone 01 ID OFST Lower f9c2 Upper fa81 Step 0006 Right 1f Mask 00008340
Default fa22 0000b5bb BER 00000000
Floor 1 1f 0003b632 0003b632
Left 1 f9e0 00038c95
Middle 1 fa21 0000af7f
Right 1 fa63 000340f8
Lowest 1 fa1c 0000af7f
Z = -A1/(2*A2) : 25E0
X = Z + Xavg : 25EF
Curve fa76 000c5048
New fa21 0000ae3d BER 00000001 AUTO
Servo Zone 02 OD OFST Lower f9bb Upper fa7a Step 0006 Right 1f Mask 00004340
Default fa1b 0000b789 BER 00000002
Floor 1 1d 00035f33 00035f33
Left 1 f9df 00032430
Middle 1 fa1a 0000b21b
Right 1 fa56 0002f3a0
Lowest 1 fa0f 0000b00b
X = Z + Xavg : 000F
Curve fa15 0000b21b
New fa1a 0000b4ff BER 00000000 AUTO
Servo Zone 02 ID OFST Lower f9df Upper fa9e Step 0006 Right 1f Mask 00008340
Default fa3f 0000ac5d BER 00000000
Floor 1 1f 0003c285 0003c285
Left 1 fa03 00031ebf
Middle 1 fa41 0000af6b
Right 1 fa80 0002f4c0
Lowest 1 fa3f 0000af6b
Z = -A1/(2*A2) : F10E
X = Z + Xavg : F11D
Curve fa93 000ad81a
New fa41 0000b0ab BER 00000000作者: 毅然坚强 时间: 2008-7-2 09:07
Servo Zone 03 OD OFST Lower f9da Upper fa99 Step 0006 Right 1f Mask 00004340
Default fa3a 0000b5d8 BER 00000001
Floor 1 1c 00030134 00030134
Left 1 fa04 00021a4d
Middle 1 fa3c 0000b190
Right 1 fa75 0002d869
Lowest 1 fa3a 0000b190
X = Z + Xavg : 000F
Curve fa34 0000b1b9
New fa3c 0000b449 BER 00000000 AUTO
CUTOFF Lower 0522 Upper 0538 Step 0001 Right 16 Mask 00000348
Default 052c 0004b295 BER 00000000
Pgm=02 Trk=009A2(009A2[0149C]).1(1).000(42E) Zn=0 Err=00 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=005206D4
Floor 1 0c 00049f33 0004a93b
Left 1 0523 000498de
Middle 1 052d 0004b20f
Right 1 0538 00049679
Lowest 1 0538 00049679
New 052d 0004a2fd BER 00000000 AUTO
BOOST Lower 0004 Upper 0012 Step 0001 Right 0e Mask 00000360
Default 000b 0004a70d BER 00000000
Floor 1 0f 0004f088 0004f088
Left 1 0008 0004c2d4
Middle 1 000b 00049af9
Right 1 000f 0004cda2
Lowest 1 000b 00049af9
X = Z + Xavg : 0007
Curve 000b 00049af9
New 000b 0004a740 BER 00000000
Default 000b 0004aad6 BER 00000000
Floor 1 10 000504a7 0006021d
Left 1 0007 0004b9c6
Middle 1 000b 0004b404
Right 1 000f 000504a7
Lowest 1 000c 00048764
X = Z + Xavg : 000C
Curve 000c 00048764
New 000b 0004ab04 BER 00000000
Rbck Noise OFF
Adjust ATTR 00 VGAS 99 VGAR 5d FREQR 83 within _ATT VGAR FREQR
MRASYM cb 00009dd9 BER 00000001
MRASYM b3 0000a221 BER 00000000 adapt
Test 000009a2.01 00009305 BER 00000000
MRASYM cb 00009387 BER 00000000
MRASYM c3 000095d7 BER 00000000 hold
NPML 03 00009510 BER 00000000 NPML update
NPML 03 000127fe BER 00000000
MRASYM cb 000124a1 BER 00000000
MRASYM bf 0001234d BER 00000000 update bf adapt
Media 0000
Adapt Servo Zone 09
Adapt Servo 0000f313.00
Adapts Loaded
Rbck DATA load
NPML 00
Test 0000f313.00 0000951b BER 00000002
Adjust ATTR 00 VGAS 5f VGAR 42 FREQR 7f SRVTEST 10
Adjust ATTR 01 VGAS 60 VGAR 73 FREQR 81 within _ATT
MRASYM 80 00009800 BER 00000005
MRASYM 7b 000097dd BER 00000001 update 7b hold
Test 0000f313.00 0000957c BER 00000000
Test 0000130d.00 000201b2 BER 00000000
RDBIAS Lower 0001 Upper 0009 Step 0001 Right 08 Mask 00002000
Default 0009 00020f6d BER 00000000
Adjust 0001 0003eeac BER 00000010
Adjust 0002 000374b4 BER 00000003
Adjust 0003 00030832 BER 00000004
Adjust 0004 0002ced6 BER 00000001
Adjust 0005 00028ad9 BER 00000000
Adjust 0006 00025b1b BER 00000000
Adjust 0007 00024555 BER 00000000
Adjust 0008 00021ea8 BER 00000002
Adjust 0009 0002100c BER 00000000
Floor 1 09 0002100c 0002bb27
Left 1 0009 0002100c
Middle 1 0009 0002100c
Right 1 0009 0002100c
Lowest 1 0009 0002100c
X = Z + Xavg : 0008
Curve 0008 00021ea8
New 0009 00020778 BER 00000000
RdBias Upper 0009 Lower 0001 Step 0001
SPT 044c Revs 00de
RdBias 09 VGAR 6e Rbt 09.0 OTF 09.0 Raw 07.2
RdBias 08 VGAR 77 Rbt 09.0 OTF 09.0 Raw 07.2
RdBias 07 VGAR 80 Rbt 09.0 OTF 09.0 Raw 07.2
RdBias 06 VGAR 8a Rbt 09.0 OTF 09.0 Raw 06.9
RdBias 05 VGAR 94 Rbt 09.0 OTF 09.0 Raw 06.9
RdBias 04 VGAR 9f Rbt 09.0 OTF 09.0 Raw 06.7
RdBias 03 VGAR a8 Rbt 09.0 OTF 09.0 Raw 06.5
RdBias 02 VGAR b4 Rbt 09.0 OTF 09.0 Raw 06.1
RdBias 01 VGAR c0 Rbt 09.0 OTF 09.0 Raw 05.7
RdBias 07 VGAR 80 Rbt 09.0 OTF 09.0 Raw 07.0
Test 0000f313.00 0000a2dc BER 00000000
Adjust ATTR 01 VGAS 71 VGAR 87 FREQR 83 within _ATT
MRASYM 7b 00009f5d BER 00000002
MRASYM 94 000098f4 BER 00000002 update 94 hold
XDCTAP 96 0000609b BER 00000000 adapt
XDCTAP 80 0000633d BER 00000000 hold
Default 033a 00006486 BER 00000000
Floor 1 0e 0000c7c9 00016ab5
Left 1 031b 0000a2c8
Middle 0 0324 000075b4
Right 1 032f 00007728
Lowest 1 032a 00007439
Restore 033a 0000684b BER 00000000
Default 0065 00006687 BER 00000000
Floor 1 20 0000626c 000069e6
Left 1 0020 0000626c
Middle 1 0043 00005ebd
Right 1 0067 000061cf
Lowest 1 004a 00005e07
X = Z + Xavg : 000E
Curve 0074 000066ca
New 0043 00005cec BER 00000000
00005cdf BER 00000000 _ATT 01 VGAS 6e VGAR 7c FREQR 81 Taps frozen read adapt
Current Tap Weight 0000540e diff ffffabf2 tap limits
00005d81 BER 00000000 _ATT 01 VGAS 6f VGAR 7a FREQR 80 Taps frozen read adapt
Current Tap Weight 0000000c diff 00005402 tap limits
00005d0a BER 00000000 _ATT 01 VGAS 6d VGAR 7c FREQR 81 Taps frozen read adapt
Current Tap Weight 00000006 diff 00000006 Save servo Force servo update
Test 0000f313.00 00009f3d BER 00000fff
Adapts Loaded
Rbck DATA load
NPML 00
Test 0000f313.01 00007db1 BER 00000000
Adjust ATTR 00 VGAS 8c VGAR 6e FREQR 80 within _ATT
MRASYM 80 000080d7 BER 00000001
MRASYM b3 00006e39 BER 00000000 update b3 hold
Test 0000f313.01 00007085 BER 00000000
Test 0000130d.01 000121e0 BER 00000000
Default 0009 00012432 BER 00000000
Adjust 0001 0002c4e3 BER 00000004
Adjust 0002 00024cf2 BER 00000002
Adjust 0003 0001ec3f BER 00000001
Adjust 0004 0001b6c4 BER 00000001
Adjust 0005 00018534 BER 00000000
Adjust 0006 00017115 BER 00000000
Adjust 0007 0001529d BER 00000000
Adjust 0008 00013dd0 BER 00000000
Adjust 0009 00012e07 BER 00000000
Floor 1 09 00012e07 0001b665
Left 1 0009 00012e07
Middle 1 0009 00012e07
Right 1 0009 00012e07
Lowest 1 0009 00012e07
Z = -A1/(2*A2) : 0003
X = Z + Xavg : 0007
Curve 0008 00013dd0
New 0009 00012aa8 BER 00000000
SPT 044c Revs 00de
RdBias 09 VGAR 5b Rbt 09.0 OTF 09.0 Raw 08.0
RdBias 08 VGAR 61 Rbt 09.0 OTF 09.0 Raw 07.8
RdBias 07 VGAR 66 Rbt 09.0 OTF 09.0 Raw 07.7
RdBias 06 VGAR 6d Rbt 09.0 OTF 09.0 Raw 07.3
RdBias 05 VGAR 75 Rbt 09.0 OTF 09.0 Raw 07.1
RdBias 04 VGAR 7d Rbt 09.0 OTF 09.0 Raw 06.8
RdBias 03 VGAR 83 Rbt 09.0 OTF 09.0 Raw 06.6
RdBias 02 VGAR 8b Rbt 09.0 OTF 09.0 Raw 06.0
RdBias 01 VGAR 94 Rbt 09.0 OTF 09.0 Raw 05.7
Test 0000f313.01 0000801d BER 00000000
Adjust ATTR 00 VGAS a9 VGAR 86 FREQR 80 within _ATT
MRASYM b3 0000831f BER 00000002
MRASYM ae 0000834b BER 00000000 hold
XDCTAP 96 00006648 BER 00000000 adapt
XDCTAP 7c 00006945 BER 00000000 hold
Default 033a 00006a63 BER 00000000
Floor 1 0d 0000b66a 0001268a
Left 1 031b 00009ba2
Middle 0 0324 000080d7
Right 1 032f 00007eeb
Lowest 1 032d 00007eeb
Restore 033a 00006a6d BER 00000000
Default 0065 000069f3 BER 00000000
Floor 1 20 000077f6 000077f6
Left 1 0032 00006b7e
Middle 1 005e 00006986
Right 1 008b 000075a2
Lowest 1 0044 000064e2
Z = -A1/(2*A2) : FFEC
X = Z + Xavg : FFFB
Curve 00d4 000086a5
New 005e 00006977 BER 00000000
00006a4f BER 00000000 _ATT 01 VGAS a7 VGAR 7d FREQR 82 Taps frozen read adapt
Current Tap Weight 0000424d diff ffffbdb3 tap limits
00006a17 BER 00000000 _ATT 01 VGAS aa VGAR 80 FREQR 81 Taps frozen read adapt
Current Tap Weight 00000012 diff 0000423b tap limits
00006a4d BER 00000000 _ATT 01 VGAS ac VGAR 7f FREQR 80 Taps frozen read adapt
Current Tap Weight 00000012 diff 00000000 Save servo Force servo update
Test 0000f313.01 0000934c BER 00000fff作者: 毅然坚强 时间: 2008-7-2 09:07
9 9
Media 0000
Channel Srvo Table
Head Addr VGA SATT Tap5 Tap6 Tap3 Tap7 Tap2 Tap8 Tap9 XDC
00 A548 7C 72 43 C8 51 79 9A 9D 72 96
01 A552 7F 72 5E BB 56 88 99 93 7E 96
Performing Servo Cals, view results in log 3
ASCII logging off
Head 0 Offset = AA5
Head 1 Offset = B0C
Head 2 Offset = 1388
Head 3 Offset = 1388
Radial ID Delta Offset Table - RPO:
Head 0 Offset = 0
Head 1 Offset = FFFF
Head 2 Offset = EE2E
Head 3 Offset = EE2E
Servo Zone 11, OD [0000D89E.0,FC6B,026B,C0]
Left Bath = FEF7, Right Bath = FFDF : Pick (FF6B) ( Min/Max AGC 63FF )
Servo Zone 11, ID [0000EDE3.0,FD1B,031B,C0]
Left Bath = FFA8, Right Bath = 0090 : Pick (001C) ( Min/Max AGC 66FF )
Servo Zone 12, OD [0000EDF4.0,FD18,0318,C0]
Left Bath = FFAE, Right Bath = 0091 : Pick (001F) ( Min/Max AGC 60FF )
Servo Zone 12, ID [000103BF.0,FDCF,03CF,C0]
Left Bath = 0066, Right Bath = 0146 : Pick (00D6) ( Min/Max AGC 66FF )
Servo Zone 11, OD [0000D837.1,FC78,0278,C0]
Left Bath = FF2D, Right Bath = FFCD : Pick (FF7D) ( Min/Max AGC 99FF )
Servo Zone 11, ID [0000ED7C.1,FD2D,032D,C0]
Left Bath = FFDE, Right Bath = 007E : Pick (002E) ( Min/Max AGC 98FF )
Servo Zone 12, OD [0000ED8D.1,FD31,0331,C0]
Left Bath = FFDC, Right Bath = 0084 : Pick (0030) ( Min/Max AGC 98FF )
Servo Zone 12, ID [00010358.1,FDE9,03E9,C0]
Left Bath = 009C, Right Bath = 0136 : Pick (00E9) ( Min/Max AGC 9BFF )
Adapt Data Zone 09
Test 0000f313.00 00005a0c BER 00000000
Test 0000f313.00 00005a04 BER 00000000
Adapt Data 0000f313.00
Rbck DATA load
NPML 00
Test 0000f313.00 000056cb BER 00000000
Adjust ATTR 00 VGAS 74 VGAR 43 FREQR 7e SRVTEST 10
Adjust ATTR 01 VGAS 75 VGAR 6f FREQR 7f within _ATT VGAR FREQR
MRASYM 80 000057c4 BER 00000000
MRASYM 8a 000056ed BER 00000001 update 8a hold
Test 0000ede3.00 00005431 BER 00000000
Servo Zone 11 ID OFST Lower ffbc Upper 007b Step 0006 Right 1f Mask 00008340
Default 001c 000053d1 BER 00000000
Floor 1 20 00020009 00020009
Left 1 ffe0 0001d045
Middle 1 0024 000055c5
Right 1 0069 0001dd0b
Lowest 1 0016 00005437
Z = -A1/(2*A2) : 9D08
X = Z + Xavg : 9D17
Curve 0070 00043540
New 0024 0000570e BER 00000000
Test 0000edf4.00 000054b3 BER 00000000
Servo Zone 12 OD OFST Lower ffbf Upper 007e Step 0006 Right 1f Mask 00004340
Default 001f 00005759 BER 00000000
Floor 1 20 0002100b 0002100b
Left 1 ffe3 00017ae3
Middle 1 0024 00005709
Right 1 0066 0001cef1
Lowest 1 0019 000056c2
Z = -A1/(2*A2) : EABB
X = Z + Xavg : EACA
Curve 0073 0005d00f
New 0024 000058f8 BER 00000000
Adjust ATTR 01 VGAS 78 VGAR 74 FREQR 7e within _ATT VGAR FREQR
Test 0000f313.00 000059c3 BER 00000000
Rbck Noise OFF
Rbck DATA save
Default 000e 00006294 BER 00000000
Floor 1 0e 00005d24 00006013
Left 1 0012 00005b72
Middle 1 0016 00005dad
Right 1 001b 00005b66
Lowest 1 0018 00005b26
Z = -A1/(2*A2) : 000B
X = Z + Xavg : 0017
Curve 001a 00005e4a
New 0016 00005aa2 BER 00000000 AUTO
Test 0000f313.00 0000574b BER 00000000
MRASYM 8a 00005582 BER 00000000
MRASYM 8f 000054f4 BER 00000000 update 8f hold
Default 0005 0000573d BER 00000000
Floor 1 0b 00005d64 00005d64
Left 1 0002 00005c4c
Middle 1 0004 00005578
Right 1 0007 00005ac2
Lowest 1 0005 00005461
X = Z + Xavg : 0005
Curve 0005 00005461
New 0004 0000564e BER 00000000
Test 0000f313.00 000058a2 BER 00000000
XDCTAP 96 00005660 BER 00000000 adapt
XDCTAP 6d 000056a7 BER 00000000 hold
CUTOFF Lower 041c Upper 0510 Step 0002 Right 14 Mask 00000348
Default 043c 0004858e BER 00000000
Floor 1 0e 00049f4f 0004d4d0
Left 1 042c 00049e8b
Middle 1 0436 0004a1a2
Right 1 050c 00048e4e
Lowest 1 0430 0004866b
New 0436 00049dca BER 00000000
Default 000d 0004f5a7 BER 00000000
Floor 1 17 0005768e 0005768e
Left 1 0007 00056f2f
Middle 1 000d 0004f5d5
Right 1 0013 00057252
Lowest 1 000e 0004edd2
Z = -A1/(2*A2) : 0001
X = Z + Xavg : 000C
Curve 000c 000509c5
New 000d 000498a7 BER 00000000 AUTO
Default 000b 0004a68c BER 00000000
Floor 1 10 00055c86 0005a520
Left 1 0005 00053b93
Middle 1 000a 0004ade5
Right 1 000f 00055c86
Lowest 1 000b 00048bd6
X = Z + Xavg : 000A
Curve 000a 0004ade5
New 000a 0004be72 BER 00000000
Servo Zone 11 ID OFST Lower ffc4 Upper 0083 Step 0006 Right 1f Mask 00008340
Default 0024 00005f58 BER 00000000
Floor 1 20 000218bd 000218bd
Left 1 ffe2 0001cbd3
Middle 1 0023 00005e53
Right 1 0065 0001b1e9
Lowest 1 0018 00005e4c
Z = -A1/(2*A2) : 4C00
X = Z + Xavg : 4C0F
Curve 0078 0006fcb0
New 0023 00005e70 BER 00000002 AUTO
Servo Zone 12 OD OFST Lower ffc4 Upper 0083 Step 0006 Right 1f Mask 00004340
Default 0024 00005e2c BER 00000000
Floor 1 20 000226c4 000226c4
Left 1 ffe2 0001c050
Middle 1 0023 00005ca6
Right 1 0065 0001c603
Lowest 1 001e 00005ca6
Z = -A1/(2*A2) : EFE0
X = Z + Xavg : EFEF
Curve 0078 00078d64
New 0023 00005da1 BER 00000000 AUTO
CUTOFF Lower 042c Upper 050c Step 0001 Right 14 Mask 00000348
Default 0436 0004b422 BER 00000000
Floor 1 0b 0004a5ad 0004b291
Left 1 042c 0004a56d
Middle 1 0431 00049a69
Right 1 0437 0004a1cf
Lowest 1 042d 00049a20
New 0431 0004a5d7 BER 00000000 AUTO
BOOST Lower 0006 Upper 0014 Step 0001 Right 0e Mask 00000360
Default 000d 0004a5f6 BER 00000000
Floor 1 0f 0004eb09 0004eb09
Left 1 0009 0004e426
Middle 1 000d 0004a786
Right 1 0011 0004d66f
Lowest 1 000e 00049a48
X = Z + Xavg : 0007
Curve 000d 0004a786
New 000d 0004addf BER 00000000
Default 000a 0004a96d BER 00000000
Floor 1 10 00058f0c 0005a9c7
Left 1 0005 00052039
Middle 1 000a 0004c759
Right 1 000f 00058f0c
Lowest 1 000b 00048f96
Z = -A1/(2*A2) : 0002
X = Z + Xavg : 0009
Curve 0009 0004df25
New 000a 0004be43 BER 00000000
Rbck Noise OFF
Adjust ATTR 01 VGAS 75 VGAR 77 FREQR 80 within _ATT VGAR FREQR
MRASYM 8f 00005fa0 BER 00000000
MRASYM 9c 00005f65 BER 00000002 update 9c adapt
Test 0000f313.00 00005cb3 BER 00000000
MRASYM 9c 00005cca BER 00000000
MRASYM 98 00005c5d BER 00000000 update 98 hold
NPML 03 00005d01 BER 00000002 NPML update
NPML 03 0000b216 BER 00000000
MRASYM 98 0000b085 BER 00000000
MRASYM 99 0000ad22 BER 00000000 update 99 adapt
Media 0000
Test 0000f313.01 000057b8 BER 00000000
Test 0000f313.01 000056a7 BER 00000000
Adapt Data 0000f313.01作者: 毅然坚强 时间: 2008-7-2 09:09
Rbck DATA load
NPML 00
Test 0000f313.01 0000553a BER 00000000
Adjust ATTR 00 VGAS aa VGAR 7b FREQR 80 within _ATT VGAR FREQR
MRASYM 80 00006443 BER 00000000
MRASYM b7 000055d1 BER 00000000 update b7 hold
Test 0000ed7c.01 000051d0 BER 00000002
Servo Zone 11 ID OFST Lower ffce Upper 008d Step 0006 Right 1f Mask 00008340
Default 002e 000050a9 BER 00000000
Floor 1 20 0001d67a 0001d67a
Left 1 ffec 0001d22f
Middle 1 0030 000052ef
Right 1 0075 00017824
Lowest 1 0034 00005279
X = Z + Xavg : 000E
Curve 0022 0000580f
New 0030 000053e5 BER 00000000
Test 0000ed8d.01 0000514f BER 00000000
Servo Zone 12 OD OFST Lower ffd0 Upper 008f Step 0006 Right 1f Mask 00004340
Default 0030 00004fee BER 00000000
Floor 1 1f 00018838 00018838
Left 1 fff4 0001374e
Middle 1 0032 000054d9
Right 1 0071 000122d3
Lowest 1 002a 00005421
Z = -A1/(2*A2) : 0010
X = Z + Xavg : 001F
Curve 0084 000463ae
New 0032 000053af BER 00000000
Adjust ATTR 00 VGAS ab VGAR 76 FREQR 81 within _ATT VGAR FREQR
Test 0000f313.01 000057f7 BER 00000000
Rbck Noise OFF
Rbck DATA save
Default 000e 00005959 BER 00000000
Floor 1 0e 000058a0 00005c40
Left 1 0016 00005759
Middle 1 0018 000056cc
Right 1 001b 0000556f
Lowest 1 001b 0000556f
Z = -A1/(2*A2) : 0026
X = Z + Xavg : 0032
Curve 001a 000055b6
New 0018 00005891 BER 00000000 AUTO
Test 0000f313.01 000053b4 BER 00000000
MRASYM b7 00005153 BER 00000000
MRASYM b5 000051b8 BER 00000000 hold
Default 0005 00005312 BER 00000000
Floor 1 0b 00005095 0000567b
Left 1 0000 00005095
Middle 1 0002 00004d5c
Right 1 0004 00004f58
Lowest 1 0002 00004d5c
Z = -A1/(2*A2) : FFFE
X = Z + Xavg : 0003
Curve 0003 00004f3b
New 0002 000050f8 BER 00000000
Test 0000f313.01 00004de3 BER 00000000
XDCTAP 96 00004e2f BER 00000000 adapt
XDCTAP 6d 00004dff BER 00000000 hold
Default 043c 000455d6 BER 00000000
Floor 1 0f 00045d22 0004a3eb
Left 1 042e 00044861
Middle 1 0438 00045501
Right 1 050e 00045aab
Lowest 1 0432 0004422b
New 0438 00045609 BER 00000000
Default 000d 0004a37e BER 00000000
Floor 1 17 00052053 00052053
Left 1 000a 000503f5
Middle 1 000f 00047c5a
Right 1 0015 0005165c
Lowest 1 0010 000474e2
X = Z + Xavg : 0010
Curve 0010 000474e2
New 000f 00045829 BER 00000000 AUTO
Default 000b 00045803 BER 00000000
Floor 1 10 00050e6b 0005486b
Left 1 0005 0004bea8
Middle 1 000a 00046772
Right 1 000f 00050e6b
Lowest 1 0008 00043eaa
X = Z + Xavg : 000A
Curve 000a 00046772
New 000a 00046290 BER 00000000
Servo Zone 11 ID OFST Lower ffd0 Upper 008f Step 0006 Right 1f Mask 00008340
Default 0030 00005ab9 BER 00000000
Floor 1 20 0001e817 0001e817
Left 1 ffee 0001b047
Middle 1 0032 00005a97
Right 1 0077 0001da10
Lowest 1 0036 000058a0
Z = -A1/(2*A2) : AC00
X = Z + Xavg : AC0F
Curve 0084 0004b1a7
New 0032 0000593f BER 00000002 AUTO
Servo Zone 12 OD OFST Lower ffd2 Upper 0091 Step 0006 Right 1f Mask 00004340
Default 0032 00005d93 BER 00000000
Floor 1 20 0001df30 0001df30
Left 1 fff0 00019546
Middle 1 0031 00005b03
Right 1 0073 00017edf
Lowest 1 0032 000057cd
Z = -A1/(2*A2) : D800
X = Z + Xavg : D80F
Curve 0086 00052ab3
New 0031 00005a85 BER 00000000 AUTO
CUTOFF Lower 042e Upper 050e Step 0001 Right 14 Mask 00000348
Default 0438 000472d8 BER 00000000
Floor 1 0c 00046778 00046c89
Left 1 042e 000466fb
Middle 1 0437 0004711b
Right 1 050d 000466f4
Lowest 1 042f 00045f1b
New 0437 000472f3 BER 00000000
BOOST Lower 0009 Upper 0016 Step 0001 Right 0d Mask 00000360
Default 000f 0004cf5e BER 00000000
Floor 1 0e 0005151b 0005151b
Left 1 000d 00050d18
Middle 1 0010 0004bb38
Right 1 0014 0004f767
Lowest 1 0010 0004bb38
X = Z + Xavg : 0007
Curve 0010 0004bb38
New 0010 00046f63 BER 00000000 AUTO
Default 000a 00047a1e BER 00000000
Floor 1 10 000543c2 00054412
Left 1 0005 0004ae5a
Middle 1 000a 00046faf
Right 1 000f 000543c2
Lowest 1 0007 00044131
X = Z + Xavg : 000A
Curve 000a 00046faf
New 000a 0004742a BER 00000000 AUTO
Rbck Noise OFF
Adjust ATTR 00 VGAS ab VGAR 74 FREQR 81 within _ATT VGAR FREQR
MRASYM b7 000056c8 BER 00000000
MRASYM b8 00005517 BER 00000000 update b8 adapt
Test 0000f313.01 00004fe4 BER 00000000
MRASYM b8 0000545b BER 00000000
MRASYM b8 000050d6 BER 00000000 update b8 hold
NPML 03 0000514e BER 00000001 NPML update
NPML 03 0000abc9 BER 00000000
MRASYM b8 0000b350 BER 00000000
MRASYM b9 0000ae81 BER 00000000 update b9 adapt
Media 0000作者: 毅然坚强 时间: 2008-7-2 09:09
Performing AFC Zone Cal
Power Cycling
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
ASCII logging on
(SN: 4MR3VRJ6)
.PW 4MR3VRJ6
ASCII logging off
.088
Channel Srvo Table
DC Erasing zero Offset tracks
Skipping MDW oversample s/n cylinders.
Unable to write SeaDex script to disc.
Power Cycling
AbEnd Test 02
Begin Test 4D
ASCII logging on
Not Power Cycling
ASCII logging off
ASCII logging on
Fail Log Summary .....
Cum Health = 2000
Log 01 - Health 2000
Log 02 - Health 2000
Head Mask FFFF -
9 9
Switch to full int.
Spin Ready
No log on disk
Scanning Log 8 .... No log on disk
Scanning Log 31 .... No log on disk
Scanning Log 32 .... No log on disk
Scanning Log 33 .... No log on disk
Scanning Log 34 .... No log on disk
Scanning Log 3A .... No log on disk
=====================================================================作者: 毅然坚强 时间: 2008-7-2 09:10
Head #Defect #Align radial defect(%) EC59 EC60
User Slip Defect List
Close slip list
Error Close Slip List 59
0 000001d . . .
Close slip list
Power Cycling
ASCII logging off
OkEnd Test 4D
Begin Test 39
ASCII logging on
ASCII logging off
OkEnd Test 39
Begin Test 22
ASCII logging on
Not Power Cycling
No log on disk
The average VGA amplitude for zone 0 head 0 is 9B.
The delta of VGA amplitudes for Zone 0 head 0 exceeds the limit (14)
The average VGA amplitude for zone 0 head 1 is AC.
The delta of VGA amplitudes for Zone 0 head 1 exceeds the limit (14)
The average VGA amplitude for zone 9 head 0 is BE.
The delta of VGA amplitudes for Zone 9 head 0 exceeds the limit (14)
The average VGA amplitude for zone 9 head 1 is B6.
The delta of VGA amplitudes for Zone 9 head 1 exceeds the limit (14)
The average VGA amplitude for zone F head 0 is 6C.
The delta of VGA amplitudes for Zone F head 0 exceeds the limit (14)
The average VGA amplitude for zone F head 1 is A3.
The delta of VGA amplitudes for Zone F head 1 exceeds the limit (14)
Power Cycling
ASCII logging off
OkEnd Test 22
Begin Test 61
OkEnd Test 61
Begin Test 28
ASCII logging on
OkEnd Test 4E
Begin Test 4E
ASCII logging off
ASCII logging on
Not Power Cycling
ASCII logging off
ASCII logging on
Log 02 - Health 2000 - HlthDtl 0000 - Time = 00:37:23 Log Type = 01
Log 82 - No Log on Disk
Log 83 - No Log on Disk
Log 84 - No Log on Disk
Log 03 - No Log on Disk
Log 73 - No Log on Disk
Log 05 - No Log on Disk
Log 06 - No Log on Disk
Log 07 - No Log on Disk
Log 0F - No Log on Disk
Log 10 - No Log on Disk
Log 11 - No Log on Disk
Log 12 - No Log on Disk
Log 13 - No Log on Disk
Log 14 - No Log on Disk
Log 15 - No Log on Disk
Log 16 - No Log on Disk
Log 17 - No Log on Disk
Log 18 - No Log on Disk
Log 19 - No Log on Disk
Log 1A - No Log on Disk
Log 1B - No Log on Disk
Log 1C - No Log on Disk
Log 1D - No Log on Disk
Log 1E - No Log on Disk
Log 2A - No Log on Disk
Log DA - No Log on Disk
Log DC - No Log on Disk
Log D6 - No Log on Disk
Log D7 - No Log on Disk
Log D8 - No Log on Disk
Log D9 - No Log on Disk
Log 56 - No Log on Disk
Log B0 - No Log on Disk
Log B1 - No Log on Disk
Log B2 - No Log on Disk
Log 0B - No Log on Disk
Log 7D - No Log on Disk
Log 58 - No Log on Disk
Log 08 - No Log on Disk
Log 0C - No Log on Disk
Log 0D - No Log on Disk
Log 40 - No Log on Disk
Log 31 - No Log on Disk
Log 32 - No Log on Disk
Log 33 - No Log on Disk
Log 34 - No Log on Disk
Log 36 - No Log on Disk
Log 37 - No Log on Disk
Log 26 - No Log on Disk
Log 3A - No Log on Disk
Log 0A - No Log on Disk
Log 8A - No Log on Disk
Log 3B - No Log on Disk
Log 3C - No Log on Disk
Log 3D - No Log on Disk
Log 3E - No Log on Disk
Log A9 - No Log on Disk
Log 3F - No Log on Disk
Log 09 - No Log on Disk
Log 20 - No Log on Disk
Log 77 - No Log on Disk
Log 43 - No Log on Disk
Log 27 - No Log on Disk
Log B3 - No Log on Disk
Log B4 - No Log on Disk
Log B5 - No Log on Disk
Log 51 - No Log on Disk
Log 48 - No Log on Disk
Log 41 - No Log on Disk
Log 49 - No Log on Disk
Log 4B - No Log on Disk
Log 4A - No Log on Disk
Log 4D - Health 0000 - HlthDtl 0000 - Time = 00:00:11 Log Type = 01
Log 39 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 01
Log 22 - Health 0008 - HlthDtl 0003 - Time = 00:00:14 Log Type = 01
Log 61 - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log 28 - No Log on Disk
Log 62 - No Log on Disk
Log 29 - No Log on Disk
Log 63 - No Log on Disk
Log 59 - No Log on Disk
Log B6 - No Log on Disk
Log B7 - No Log on Disk
Log B8 - No Log on Disk
Log 6F - No Log on Disk
Total Cert Time = 00:37:48
ASCII logging off
