关于上面的猜想,在Wikipedia英文版上得到证实,原文如下:
IBM UltraPort
From Wikipedia, the free encyclopedia
Jump to: navigation, search
IBM UltraPort was a nonstandard USB 1.1 port used by IBM on its range of Thinkpad laptop computers.
翻译:IBM UltraPort 是一种非标准的USB1.1连接口,使用于IBM在其ThinkPad笔记本上
Description
Electrically the UltraPort connector is identical to the standard USB port. UltraPort uses a proprietary mechanical connection, so UltraPort devices cannot be plugged into a normal USB interface. However the UltraPort devices shipped with an adapter which allowed them to be attached to a regular USB port.
具体描述:UltraPort 在电子上和标准的USB接口是一致的。(但是)UltraPort 使用其独特的机械连接方式,所以此种设备不可以直接连接到普通的USB接口上。然而随着和UltraPort 一起运送而来的适配器使用的话即可以在标准的USB接口上使用。
