七彩虹 8500GT MATS测试结果
hzhoudongjiea
2012-4-22 22:35
七彩虹 8500GT MATS测试结果
LANE EB0 READ ERR EB0 WRT ERR EB1 READ ERR EB1 WRT ERR UNKNOWN ERR
FBD[ 31: 0] 2018460 71648763 2015685 71630641 0
FBD[ 63: 32] 7276544 68769022 7260412 68763885 0
External Bank 0 Failing bits:
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
External Bank 1 Failing bits:
Read Error Count: 18571101
Write Error Count: 280812311
Unknown Error Count: 0
BIT FRONT WRITE FRONT READ BACK WRITE BACK READ UNKNOWN
0 43297859 1444368 43287052 1442885 0
1 58183450 1205804 58177509 1202555 0
2 43519749 1552633 43509906 1550131 0
3 58530777 1292645 58523495 1290458 0
4 43236408 1427798 43235335 1423107 0
5 58520377 1207939 58517224 1204071 0
6 43340280 1437955 43337191 1431671 0
7 58466584 1328454 58465926 1326883 0
8 35434947 1413981 35427017 1410274 0
9 56190727 1259504 56187711 1256313 0
10 35307404 1235078 35300579 1231035 0
11 55971599 1224797 55967784 1221108 0
12 35663197 1236084 35663045 1233576 0
13 56410279 1375090 56408910 1373591 0
14 35984175 1565641 35981283 1563815 0
15 56334558 1435349 56332636 1432768 0
16 29767657 842315 29758976 839545 0
17 52697493 891043 52693062 887834 0
18 29768242 842457 29759707 839684 0
19 52696184 890929 52692142 887678 0
20 29710585 842082 29709504 839202 0
21 52715165 891413 52714399 888089 0
22 29709532 842090 29708570 839345 0
23 52712176 890949 52711981 887692 0
24 29765748 841698 29756495 838861 0
25 52705343 891669 52700648 888309 0
26 29766338 841844 29757057 838998 0
27 52704079 891562 52699768 888153 0
28 29709314 841476 29708579 838564 0
29 52715868 891822 52715597 888358 0
30 29708327 841319 29707706 838495 0
31 52713155 891407 52713274 887991 0
32 39485754 3863890 39495025 3853757 0
33 49426244 5821550 49441236 5808861 0
34 39325871 3780897 39336440 3771025 0
35 50343233 5848287 50356928 5834749 0
36 42280406 3753163 42283601 3747710 0
37 48394331 5793156 48396085 5781064 0
38 41928562 3667645 41926040 3658325 0
39 47771502 5537251 47771325 5527915 0
40 32185213 3974731 32193176 3964413 0
41 45557397 5618008 45562507 5605803 0
42 31966237 3881885 31976171 3872438 0
43 45647586 5891219 45651831 5876816 0
44 33807679 4029111 33812662 4022178 0
45 44318698 5551094 44322955 5540417 0
46 34063151 4177063 34062906 4167683 0
我用的 7 测得 我感觉测得不对吧 显存有 好多个呢 大家看看哪个问题 是不是GPU坏了哦
hzhoudongjiea
2012-4-22 22:35
本文来自:迅维网(
www.chinafix.com.cn
),出处:
http://www.chinafix.com.cn/forum ... d=526976&extra=
qw7436867
2012-4-23 09:12
换8和9都试试。然后写下bios再测。不行把GPU加焊
