[8 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID 0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.8 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.8 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.8 not found
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
error : R055A.8 not found
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.8 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.8 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.8 not found
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
error : R065A.8 not found
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.8 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.8 not found
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.8 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
error : R075A.8 not found
[9 ] Line slopes/dir/P/solid : FAIL
Error ID 0TR010
error : R051A.9 not found
error : R052A.9 not found
error : R053A.9 not found
error : R055A.9 not found
error : R061A.9 not found
error : R062A.9 not found
error : R063A.9 not found
error : R065A.9 not found
error : R071A.9 not found
error : R072A.9 not found
error : R073A.9 not found
error : R075A.9 not found
Failure detected.
