R3MEMID version 1.12, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Failing bits in test [1] Fill
errcount: 12582400
MDA0: 16 23
Failing bits in test [2] Data line toggle (GUI)
errcount: 6290688
MDA0: 16 23
Failing bits in test [3] RW column (GUI)
errcount: 4194304
MDA0: 16 23
Failing bits in test [4] RW page (GUI)
errcount: 4194176
MDA0: 16 23
Failing bits in test [5] RW channel (GUI)
errcount: 4194176
MDA0: 16 23
Failing bits in test [6] Data mask
errcount: 8388352
MDA0: 16 23
Failing bits in test [7] Macro + Micro8x2 tiling read
errcount: 2183168
MDA0: 16 23
Failing bits in test [8] Macro + Micro4x4 tiling write
errcount: 2183317
MDA0: 16 23
Failing bits in test [9] Byte swap macro+micro8x2 read
errcount: 12582912
MDA0: 16 23
Failing bits in test [10] Byte swap macro+micro4x4 write
errcount: 12582904
MDA0: 16 23
Failing bits in test [11] Marco+Micro8x2 alignment write
errcount: 37376
MDA0: 23
Failing bits in test [12] Macro+Micro4x4 alignment read
errcount: 37376
MDA0: 23
TEST RESULT SUMMARY:
RV380/M24 A23 (0x3e50) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID G0VB001
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 16 23
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
[3 ] RW column (GUI) : FAIL
Error ID G0VB024
[4 ] RW page (GUI) : FAIL
Error ID G0VB025
[5 ] RW channel (GUI) : FAIL
Error ID G0VB028
[6 ] Data mask : FAIL
Error ID G0VB006
[7 ] Macro + Micro8x2 tiling read : FAIL
Error ID G0VC006
[8 ] Macro + Micro4x4 tiling write : FAIL
Error ID G0VC009
[9 ] Byte swap macro+micro8x2 read : FAIL
Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write : FAIL
Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write : FAIL
Error ID G0VC052
failing bit : MDA0 23
[12 ] Macro+Micro4x4 alignment read : FAIL
Error ID G0VC057
[13 ] Movblit, 4 align, T : FAIL
Error ID G0TR055
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID G0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.14 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.14 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.14 not found
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
error : R055A.14 not found
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.14 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.14 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.14 not found
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
error : R065A.14 not found
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.14 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.14 not found
error : R073A.14 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
error : R075A.14 not found
[15 ] Line slopes/dir/P/solid : FAIL
Error ID G0TR010
error : R051A.15 not found
error : R052A.15 not found
error : R053A.15 not found
error : R055A.15 not found
error : R061A.15 not found
error : R062A.15 not found
error : R063A.15 not found
error : R065A.15 not found
error : R071A.15 not found
error : R072A.15 not found
error : R073A.15 not found
error : R075A.15 not found
Failure detected.
看不懂。刚想学修显卡。这个显存是elexir 公司的。正反一共8颗显存。。请指教下。最好给讲怎么看R3检测结果的。 作者: 张林河南 时间: 2012-2-1 13:05
那片550测试软件。只有这样测试的我是全部测试。如何用数字测试。。作者: 月饼 时间: 2012-2-1 17:34
右边最下面的正面或者反面颗粒问题。作者: 山水学院 时间: 2012-2-2 10:26
想认真学下如何看测试结果作者: 月饼 时间: 2012-2-2 11:25
