标题: Tiny wall1.0.3 [打印本页] 作者: 范德萨 时间: 2012-1-24 12:45 标题: Tiny wall1.0.3 TinyWall is a free software to harden and control the advanced firewall built into Windows Vista and Windows 7.
tinywall是一个免费软件用来坚固和控制windows 7防火墙的
Features:
Non-intrusive operation
TinyWall lets you work while protecting you. No annoying popups and simple configuration.
没有烦人的弹窗口设置简单
Lightweight 轻量级
Using the advanced Windows Firewall built into newer Windows versions, TinyWall´s performance impact is neglible.
More than just a controller
Password lock, firewall tinkering protection and built-in tight firewall rules make TinyWall secure.
Safe operation
No drivers or kernel-components are installed, which keeps your system stable.
Convenient
Firewall modes and lots of other convenience features make TinyWall extremely easy to use for anybody.
No cost
100% free, no ads, no artifical limitations, no upgrades. 免费无广告无限制不需要升级
Editor's Note: After installation TinyWall blocks all communications. To use the internet or network-enabled applications, select one of the "Whitelist by ..." options in the tray menu to unblock specific programs.
