compaq516黑屏 大小写灯闪
xmahly
2012-1-18 13:30
compaq516黑屏 大小写灯闪
大小写灯闪,CPU 内存换了也不行。。求助高手啊
桂林笔记本维修
2012-1-18 13:33
闪几次?对应一下故障
Caps Lock/Num Lock LED Component Tested Error Condition
LEDs blink 1 time CPU CPU not functional
LEDs blink 2 times BIOS BIOS corruption failure
LEDs blink 3 times Memory Module error not functional
LEDs blink 4 times Graphics Graphics controller not functional
LEDs blink 5 times System board General system board failure
LEDs blink 6 times BIOS BIOS authentication failure
xmahly
2012-1-18 13:36
5次能说的简单易懂点吗?刚学说的太深奥不会嘿嘿
沈塘
2012-1-18 13:59
桥虚焊了!!!
十年后
2012-1-18 14:00
这样的问题,我就先做北桥,
鲁鹏维修
2012-1-18 14:21
这个闪应是没有过内存,你可以用诊断卡帮着确认故障点的
