4脚是参考设置脚,内部有个恒流源。所以能测到电压A resistor from the RI pin to ground will generate a constant current source for the SG6842.
This current charges an internal capacitor. This determines the switching frequency.
Increasing the resistance will decrease the amplitude of the current from the current source,
and thereby reduce the switching frequency. Using a 26kΩ resistor Ri results in a 50uA
constant current Ii and a 65kHz switching frequency.
