标题: 联想 S10 解决冷机掉电和B4蓝屏 BIOS 14CN56WW [打印本页]
作者: yangyonglge    时间: 2011-12-25 23:16
解决冷机掉电 热机正常
Summary of changes
1. Resolves the problem with One Key Recovery button which makes the system automatically power on when the LCD cover is closed, especially if pressure is applied to the cover nearby the battery.
2. Add Password-on-boot functionality to BIOS CMOS settings.
3. Resolves the problem with the units carrying a  6-cell battery, where the computer's battery indicator displays wrong values for both the status (upon removing the AC adapter) and the volume charged.
4. Resolves the problem with the short-cut key for wireless connections configuration (FN+F5).The system is not able to save the changes entered through the short-cut key.
5. Fix S9/S10/M10 auto shut-down in low temperature issue.
6. Fix Linpus S4 auto entry S3 after wake up issue.
7. Fix S9/S10/M10 Fan turning on/off frequently issue.
14CN56WW.rar (1.89 MB, 下载次数: 115)
