The Master Boot Record is located at the physical beginning of a hard disk, editable using the
Disk Editor. It consists of a master bootstrap loader code (446 bytes) and four subsequent,
identically structured partition records. Finally, the hexadecimal signature 55AA completes a valid
Master Boot Record.
B,必须注意:扇区号的高二位占用柱面号所在字节的最高二位,即柱面号为
10位,扇区
号
6位。
The format of a partition record is as follows:
Offset Size Description
0 8 bit A value of 80 designates an active partition.
1 8 bit Partition start head
2 8 bit Partition start sector (bits 0-5)
3 8 bit Partition start track (bits 8,9 in bits 6,7 of sector)
4 8 bit Operating system indicator
5 8 bit Partition end head
6 8 bit Partition end sector (bits 0-5)
7 8 bit Partition end track (bits 8,9 in bits 6,7 of sector)
8 32 bit Sectors preceding partition
C 32 bit Length of partition in sectors
Operating system indicators: (hexadecimal, incomplete list)
00 Empty partition-table entry
01 DOS FAT12
04 DOS FAT16 (up to 32 MB)
05 DOS 3.3+ extended partition
06 DOS 3.31+ FAT16 (over 32 MB)
07 OS/2 HPFS, Windows NT NTFS, Advanced Unix
08 OS/2 v1.0-1.3, AIX bootable partition, SplitDrive
09 AIX data partition
0A OS/2 Boot Manager
0B Windows 95+ FAT32
0C Windows 95+ FAT32 (using LBA-mode INT 13 extensions)
0E DOS FAT16 (over 32 MB, using INT 13 extensions)
0F Extended partition (using INT 13 extensions)
17 Hidden NTFS partition
1B Hidden Windows 95 FAT32 partition
1C Hidden Windows 95 FAT32 partition (using LBA-mode INT 13 extensions)
1E Hidden LBA VFAT partition
42 Dynamic disk volume
50 OnTrack Disk Manager, read-only partition
51 OnTrack Disk Manager, read/write partition
81 Linux
82 Linux Swap partition, Solaris (Unix)
83 Linux native file system (ext2fs/xiafs)
85 Linux EXT
86 FAT16 volume/stripe set (Windows NT)
87 HPFS fault-tolerant mirrored partition, NTFS volume/stripe set
BE Solaris boot partition
C0 DR-DOS/Novell DOS secured partition
C6 Corrupted FAT16 volume/stripe set (Windows NT)
C7 Corrupted NTFS volume/stripe set
F2 DOS 3.3+ secondary partition
Usually 32 sectors Logical sector
=0032h
Logical sector =0032h+
2*sectors_per_FAT
DOS Boot Recore 3
SectorsReserved sectorsCopy of recordReserve sectorsFAT1FAT2Data area(where files
and all bdirectories
are stored)
10 Standard information: contains time stamps and DOS attributes,
30 File name: contains the file's name for different name spaces (usually NT's native Unicode file
name and DOS compatible DOS file name),
80 Data: if the entry represents a file, this attribute contains the file's data.
90 Index root: if the entry is a directory, this attribute describes the root of a binary tree in which
the directory entries are located,
A0 Index allocation: if the entry is a directory, this attribute contains a list of file names.
