标题: 清华同方超锐F5600问题 [打印本页]
作者: 开心蒙太奇    时间: 2011-11-10 18:04
标题: 清华同方超锐F5600问题
开机出现
warning-cmos checksum invalid -run scuwarning-keyboard controller failure
base memory       0000640 kb
extended memory   1031168 kb
total memory      1032192 kb
shared memory     016384  kb
warning- no interrupts from timer 0
auto detecting ide devices[done]
press F2 to enter system configuration utility
initializing boot cd-rom - none
press F1 to continue
键盘用不了,南桥做了,BIOS也刷了,没思路了,请问各位高手怎么解决????
作者: 维维豆    时间: 2011-11-10 18:29
键盘用不了你不查KBC换南桥干毛啊
