标题: CQ40 (LA-4101P) LAPTOP CHARGING PROBLEM [打印本页]
作者: sangramrout    时间: 2011-11-8 12:34
i receive a CQ40 (LA-4101P) laptop with charging problem. its charging led is glow without battery also and the charging voltage also come in battery connector. when i power on the laptop its working fine for 1-2 min after that the charging led is blinking and power off automatically. i replace the bq24740(PU101) ic but not solved. without PU101 also the charging led is on and aftersometime blinking & power off.
作者: 三木    时间: 2011-11-8 13:13
晕。这那看得懂啊。来中文的吧。
作者: 我学电脑网    时间: 2011-11-8 14:07
中文  中文
作者: aduluck69    时间: 2011-11-8 15:27
I understand your question,it Is a charging circuit problem.Battery and the charging voltage is not compatible.You'd better replace charging chip,PU101 is it right? You said charging chip.
作者: chinachenhua    时间: 2011-11-8 15:42
This machine for BIOS problem.
作者: sangramrout    时间: 2011-11-8 19:39
aduluck69 发表于 2011-11-8 15:27
I understand your question,it Is a charging circuit problem.Battery and the charging voltage is not  ...
i tried it
作者: 刘键    时间: 2011-11-8 21:11
WHERE ARE YOU FORM?
