标题: ST做SF不过的错误代码 [打印本页] 作者: 缘来这么难 时间: 2008-5-13 19:30 标题: ST做SF不过的错误代码 T>N2,,22
T>Begin Test 02
ASCII logging on
Not Power Cycling
Not Power Cycling
Zone 00 Head 00 adaptives set to defaults
Zone 00 Head 01 adaptives set to defaults
Zone 01 Head 00 adaptives set to defaults
Zone 01 Head 01 adaptives set to defaults
Zone 02 Head 00 adaptives set to defaults
Zone 02 Head 01 adaptives set to defaults
Zone 03 Head 00 adaptives set to defaults
Zone 03 Head 01 adaptives set to defaults
Zone 04 Head 00 adaptives set to defaults
Zone 04 Head 01 adaptives set to defaults
Zone 05 Head 00 adaptives set to defaults
Zone 05 Head 01 adaptives set to defaults
Zone 06 Head 00 adaptives set to defaults
Zone 06 Head 01 adaptives set to defaults
Zone 07 Head 00 adaptives set to defaults
Zone 07 Head 01 adaptives set to defaults
Zone 08 Head 00 adaptives set to defaults
Zone 08 Head 01 adaptives set to defaults
Zone 09 Head 00 adaptives set to defaults
Zone 09 Head 01 adaptives set to defaults
Zone 0A Head 00 adaptives set to defaults
Zone 0A Head 01 adaptives set to defaults
Zone 0B Head 00 adaptives set to defaults
Zone 0B Head 01 adaptives set to defaults
Zone 0C Head 00 adaptives set to defaults
Zone 0C Head 01 adaptives set to defaults
Zone 0D Head 00 adaptives set to defaults
Zone 0D Head 01 adaptives set to defaults
Zone 0E Head 00 adaptives set to defaults
Zone 0E Head 01 adaptives set to defaults
Zone 0F Head 00 adaptives set to defaults
Zone 0F Head 01 adaptives set to defaults
Head Mask 000F -
Read Bias - Head 0 1 2 3
B B
HiTemp Bias Head 0 1 2 3
B B
Head Mask 000F - Switch to full int.
Spin Ready
Ref Trk Tan Timing Skew (h0 to h0) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h0) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h1) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h2) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h2) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h3) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h3) = 0000 servo clocks.
Calibrating Physical Track 0 on heads 0 thru 1
Radial Offset Table:
Head 0 Offset = 0
Head 1 Offset = 0
Head 2 Offset = 0
Head 3 Offset = 0
SkpCylList deleted
Sys= 0F68E-0F70D 0280 SPTK on sys trks
<empty>
drive must be reformatted
Skipping MDW oversample s/n cylinders.
Zone 00: 00018 - 00BE8 1100 (044C) 683.439
Zone 01: 00BE9 - 027FE 1056 (0420) 666.63
Zone 02: 027FF - 04707 1026 (0402) 646.275
Zone 03: 04708 - 06CA3 990 (03DE) 622.431
Zone 04: 06CA4 - 08B66 953 (03B9) 602.353
Zone 05: 08B67 - 0A479 916 (0394) 580.392
Zone 06: 0A47A - 0C405 880 (0370) 545.882
Zone 07: 0C406 - 0D99A 836 (0344) 527.59
Zone 08: 0D99B - 0ECD9 806 (0326) 506.144
Zone 09: 0ECDA - 10337 770 (0302) 480.724
Zone 0A: 10338 - 11397 733 (02DD) 461.672
Zone 0B: 11398 - 12854 691 (02B3) 437.423
Zone 0C: 12855 - 13F38 660 (0294) 410.353
Zone 0D: 13F39 - 14AE7 623 (026F) 396.401
Zone 0E: 14AE8 - 155D6 605 (025D) 383.316
Zone 0F: 155D7 - 16358 572 (023C) 363.922
Total LBAs = 095333FC
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
No entries in Log
All Hds 0-1, All Cyls 00018-16358, Rnd data
HiTemp Bias BackOff Head 0 1 2 3
B B
Adapt Data Zone 00
Test 00000600.00 WRITE FAILED
Test 00000620.00 WRITE FAILED
Test 00000640.00 WRITE FAILED
Test 00000660.00 WRITE FAILED
Adapt Data 00000660.00
Dbck DATA load
NPML 00
Test 00000098.00 WRITE FAILED
Media 0014
FAILED DATA Zone 00 Head 00 Error 00cd
Test 00000600.01 WRITE FAILED
Test 00000620.01 WRITE FAILED
Test 00000640.01 WRITE FAILED
Test 00000660.01 WRITE FAILED
Adapt Data 00000660.01
Dbck DATA load
NPML 00
Test 00000098.01 WRITE FAILED
Media 0014
FAILED DATA Zone 00 Head 01 Error 00cd
Adapt Servo Zone 08
Adapt Servo 0000e33a.00
Adapts Loaded
Dbck DATA load
NPML 00
Test 0000e33a.00 WRITE FAILED
Dbck Default DATA load
Ratio 0001
Adapt Servo 0000e35a.00
Adapts Loaded
Dbck DATA load
NPML 00
Test 0000e35a.00 WRITE FAILED
Ratio 0001
Adapt Servo 0000e37a.00
Adapts Loaded
Dbck DATA load
NPML 00
Test 0000e37a.00 WRITE FAILED
Ratio 0001
Adapt Servo 0000e39a.00
Adapts Loaded
Dbck DATA load
NPML 00
Test 0000e39a.00 WRITE FAILED
Ratio 0001
FAILED SERVO Zone 08 Head 00 Error 00cd
Adapt Servo 0000e33a.01
Adapts Loaded
Dbck DATA load
NPML 00
Test 0000e33a.01 WRITE FAILED
Ratio 0001
Adapt Servo 0000e35a.01
Adapts Loaded
Dbck DATA load
NPML 00
Test 0000e35a.01 WRITE FAILED
Ratio 0001
Adapt Servo 0000e37a.01
Adapts Loaded
Dbck DATA load
NPML 00
Test 0000e37a.01 WRITE FAILED
