标题: CQ40 本本 [打印本页] 作者: 新疆东方维修 时间: 2011-10-26 15:47 标题: CQ40 本本 the system bios has detected your notebook pc was placed in hibernation to avoid overheating. the system is now operating normally and your data should remain intact
overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification. the notebook pc should return to normal operation once the situation is resolved.
system temperature (90D)
enter-continue startup
for more information,please visit:
风扇清过了 怎么解决 作者: AK-47 时间: 2011-10-26 15:59
好像就是风扇的问题 作者: jijiji 时间: 2011-10-26 16:41
温高报警作者: tianpengliang 时间: 2011-10-26 17:59
换风扇就OK了 作者: 鸿威电脑 时间: 2011-10-26 18:36
看一下铜管是不是好的作者: 蓝色快车2008 时间: 2011-10-26 19:57
刷个BIOS看下作者: psxly 时间: 2011-10-26 19:59
看下温控模块是不是好的
