HP nc6230奇怪故障
张哈哈
2011-9-21 22:41
HP nc6230奇怪故障
nc6230 ,不插硬盘什么问题都没有,也可以正常进PE,但是只要是插上硬盘,一开机过了HP logo以后,就出现下面一大串字符,PE也进不去,用安装盘装系统也装不了,硬盘更换过,硬盘接口更换过,南桥芯片更换过,内存更换过,CPU更换过,bios放电试过,有人遇到过类似的故障吗?
TRAP 00000006=============EXCEPTION=========
trz=0028 cr=0000009 cr2=00000000 cr3=00000000
gbtlimit=03FF base=00017000 idtlinit=07FF base=00017000
cs:eip=0008:00306A0F ss:esp=0010:00060698 errcode=0000
flags=00010006 Noly NoZr IntDis Down TrapDis
eax=00030000 ebx=00000400 ecx=00000000 edx=00030003 ds=0010 es=0010
edi=00031000 esi=000000F17 ebp=00024120 cro=00000011 fs=0030 gs=0000
