标题: 广达SW9\TW9 主板BIOS QL4Q3F82--WIN7版(官方发布) [打印本页]
作者: 若风 时间: 2011-9-6 00:30
SW9SW/TW9SW/QL4SW/SW9DB/SW9D/QL2D/SW9U/QL2U/TW9D/QL24D/TW9U/QL4U准系统系列笔记本bios Q3F82 WINDOWS 7版
适用部分机型:
优雅A560-i7 优雅A460-i5 | 优雅A550-i5 | 优雅A550-i3
海尔T6
提示:A560系列是Q44Q3F82,此包为自动识别的,不符合不会刷黑。
再此警告,刷机有风险,需谨慎
附件包含2M和4M BIOS
DOS下运行QL4Q3F82.bat
压缩包包含
:TW9U准系统 Q44Q3F82.fd
:TW9D准系统Q42Q3F82.fd HASEE SLIC2.1
:SW9U准系统Q44Q3F82.fd
:SW9D准系统Q42Q3F82.fd HASEE SLIC2.1
:TW9SW准系统Q44Q3F82.fd
:SW9SW准系统Q44Q3F82.fd
QUICK SUMMARY OF FUNCTIONAL CHANGES or Fixed QITS issues :
A. System BIOS
No. QITS No. Comments
1 None Modify hotkey function for third party OSD
2 None Modify max level of the P-state for Arrandale
3 None Modify AVC touch pad HID for TW9A
4 None Modify AVC touch pad detect function for reducing detect times
5 None Add 4M SPI ROM EN25F32100H2P support
6 None Add EC checksum check function
7 None Add internal keyboard disable function for LG OSD
8 None Add 3G card hotkey support and WLAN, bluetooth hotkey protection
9 None Modify brightness for smart indicator can’t slide to level 1
10 None Disable AES for LG request
11 None Fix QL4 sometimes hang on HDD password dialog after warm reboot
12 None Disable WLAN ASPM for CB
13 None Hidden model name in flashing BIOS
14 None Modify memory dim name string in setupmenu
15 None Enable Intel HDMI Audio device in setupmenu
16 None Remove NVIF support for brightness in Win7
17 None Modify TJ90 throttling temperature to 83 degree
18 None Clear RTC_WAK flag after S5
19 None Modify IRQ of the PEG root port to fix high definition audio device yellow bang when Clarksfield CPU mount on HM55
20 None Modify SLP display item in setupmenu
21 None Add Haier Dolby support
22 None Add EON EN25F16 EN25F40 ROM part support
23 None Fix OSD does not show not exist when disable Bluetooth or WLAN
24 None Fix Realtek control panel does not support SRS for LG
25 None Remove S4 resume time reduce function
26 None Modify PCIE port 5 hardware scan notice function
27 None Fix Arrandale processor sighting 3622219 for flashing BIOS by Insyde Winflash
28 None Fix Clark and HM55 S4 long run failed
29 None Fix can’t input HDD password after warm reset
30 None Fix S3 resume login sound lag issue by modifying sleep time from 300 ms to 1000 ms
31 None Support EC native version OSD function for LG
32 None Add Insyde cmos checksum solution
33 None Add PCIE port 5 scan delay time
34 None Fix Logo appear garbage when pushing F2 or F10
35 None Fix can’t install OS in IDE mode
36 None Add 2M/4M BIOS ROM identify item at address 2M 0x0018CA30 is 0x02 and 4M 0x0x0038CA30 is 0x04
37 None Add nVIDIA WMI1 function for optimus platform
38 None Modify BIOS code to let UMA and SG platform use the same code base
39 None Fix the screen will show garbage on UMA platform when hot plug CRT device
40 None Add Insyde chipset and kernel CMOS area checksum function
41 None Lock Intel ME and add Insyde update IGNITION/FUll sku ME binary function
B .KBC BIOS
1 None Add Fan self test routine
2 None Disable internal keypad when disable flag is set by BIOS
3 None Modify QL2/TW9 Fan table
4 None Modify Fan start volage at 2.53V, and initial CPU thermal at 53'C
5 None Modify Tj90 shutdown temperature at 95'C
6 None Update QL2 CPU and VGA fan table
7 None Update RF/3G hotkey behavior. ( hotkey Fn + F2 for shot time is enable/disable RF, over 1.5 second is enable/disable 3G)
8 None Add TW9 1st step Fan speed of UMA platform
9 None Modify Q80 threshold from 85'C to 75'C
10 None Modify QL2 VGA fan table
11 None Modify mute off delay time to 400ms.(HW request).
12 None Remove TPD work around function. (KBD hang up when AVC TPD device is remove after resume.)
13 None Sync NumLk function.
14 None EC according WOL flag to turn on/off Lan power in AC mode, and turn off Lan power in DC mode when system is shutdown
QL4Q3F82WIN7.part1.rar
(1.91 MB, 下载次数: 276)
