T>N1
AutoRd Err 47 at 00e330.00.0000
AutoRd Err 47 at 00e330.00.0140
smartres.c - ovl L1 failed
1>
1>/T
T>#,,22
Enter Drive S/N 4JV4REKQ
Enter Packwriter S/N 9W2003
Code - 33 Track 0E330.0.140 Sns 140 Rty F7FF.FF.80FF Rtf 1800 LBA 00000000
T>N2,AA,22
T>Begin Test 02
ASCII logging on
Not Power Cycling
Not Power Cycling
Zone 00 Head 00 adaptives set to defaults
Zone 00 Head 01 adaptives set to defaults
Zone 01 Head 00 adaptives set to defaults
Zone 01 Head 01 adaptives set to defaults
Zone 02 Head 00 adaptives set to defaults
Zone 02 Head 01 adaptives set to defaults
Zone 03 Head 00 adaptives set to defaults
Zone 03 Head 01 adaptives set to defaults
Zone 04 Head 00 adaptives set to defaults
Zone 04 Head 01 adaptives set to defaults
Zone 05 Head 00 adaptives set to defaults
Zone 05 Head 01 adaptives set to defaults
Zone 06 Head 00 adaptives set to defaults
Zone 06 Head 01 adaptives set to defaults
Zone 07 Head 00 adaptives set to defaults
Zone 07 Head 01 adaptives set to defaults
Zone 08 Head 00 adaptives set to defaults
Zone 08 Head 01 adaptives set to defaults
Zone 09 Head 00 adaptives set to defaults
Zone 09 Head 01 adaptives set to defaults
Zone 0A Head 00 adaptives set to defaults
Zone 0A Head 01 adaptives set to defaults
Zone 0B Head 00 adaptives set to defaults
Zone 0B Head 01 adaptives set to defaults
Zone 0C Head 00 adaptives set to defaults
Zone 0C Head 01 adaptives set to defaults
Zone 0D Head 00 adaptives set to defaults
Zone 0D Head 01 adaptives set to defaults
Zone 0E Head 00 adaptives set to defaults
Zone 0E Head 01 adaptives set to defaults
Zone 0F Head 00 adaptives set to defaults
Zone 0F Head 01 adaptives set to defaults
Head Mask FFFF -
Read Bias - Head 0 1 2 3
9 9
HiTemp Bias Head 0 1 2 3
9 9
Head Mask FFFF - Switch to full int.
Spin Ready
Ref Trk Tan Timing Skew (h0 to h0) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h0) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h1) = 19F5 servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = 00AD servo clocks.
Ref Trk Tan Timing Skew (h0 to h2) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h2) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h3) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h3) = 0000 servo clocks.
Calibrating Physical Track 0 on heads 0 thru 1
Calibrating Head 0 ...
Calibrating Head 1 ...
Radial Offset Table:
Head 0 Offset = A53
Head 1 Offset = A36
Head 2 Offset = 1388
Head 3 Offset = 1388
SkpCylList deleted
Sys= 0EC3B-0ECBA 0280 SPTK on sys trks
<empty>
drive must be reformatted
Skipping MDW oversample s/n cylinders.
Zone 00: 00018 - 00BE8 1100 (044C) 683.439
Zone 01: 00BE9 - 027FE 1056 (0420) 666.63
Zone 02: 027FF - 04707 1026 (0402) 646.275
Zone 03: 04708 - 06CA3 990 (03DE) 622.431
Zone 04: 06CA4 - 08B66 953 (03B9) 602.353
Zone 05: 08B67 - 0A479 916 (0394) 580.392
Zone 06: 0A47A - 0C405 880 (0370) 545.882
Zone 07: 0C406 - 0D99A 836 (0344) 527.59
Zone 08: 0D99B - 0ECD9 806 (0326) 506.144
Zone 09: 0ECDA - 10337 770 (0302) 480.724
Zone 0A: 10338 - 11397 733 (02DD) 461.672
Zone 0B: 11398 - 12854 691 (02B3) 437.423
Zone 0C: 12855 - 13F38 660 (0294) 410.353
Zone 0D: 13F39 - 14AE7 623 (026F) 396.401
Zone 0E: 14AE8 - 155D6 605 (025D) 383.316
Zone 0F: 155D7 - 16358 572 (023C) 363.922
Total LBAs = 095333FC
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
No entries in Log
All Hds 0-1, All Cyls 00018-16358, Rnd data
Performing AFC Zone Cal
......(文字太多了,我就省略了啦!)......
Code - 43 Track 0EC55.0.032 Sns 032 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
2A: Log Read Not OK
Log 1F - No Log on Disk
Code - 43 Track 0EC55.0.0AA Sns 0AA Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
2F: Log Read Not OK
Code - 43 Track 0EC54.0.188 Sns 188 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
0B: Log Read Not OK
Code - 43 Track 0EC54.0.16C Sns 16C Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
09: Log Read Not OK
Code - 43 Track 0EC5C.0.002 Sns 002 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
58: Log Read Not OK
Code - 43 Track 0EC54.0.0EC Sns 0EC Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
08: Log Read Not OK
Code - 43 Track 0EC54.0.174 Sns 174 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
0A: Log Read Not OK
Code - 43 Track 0EC5E.0.1B7 Sns 1B7 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
72: Log Read Not OK
Code - 43 Track 0EC54.0.18C Sns 18C Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
0C: Log Read Not OK
Log 0E - No Log on Disk
Log 0D - No Log on Disk
Code - 43 Track 0EC59.0.05D Sns 05D Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
40: Log Read Not OK
Code - 43 Track 0EC55.0.0B6 Sns 0B6 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
31: Log Read Not OK
Code - 43 Track 0EC56.0.036 Sns 036 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
32: Log Read Not OK
Code - 43 Track 0EC56.0.235 Sns 235 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
33: Log Read Not OK
Code - 43 Track 0EC56.0.239 Sns 239 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
34: Log Read Not OK
Code - 43 Track 0EC56.0.241 Sns 241 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
36: Log Read Not OK
Log 37 - No Log on Disk
Log 26 - No Log on Disk
Code - 43 Track 0EC58.0.041 Sns 041 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
3A: Log Read Not OK
Code - 43 Track 0EC57.0.000 Sns 000 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
38: Log Read Not OK
Log 68 - No Log on Disk
Code - 43 Track 0EC5D.0.000 Sns 000 Rty FFFF.20.20FF Rtf 1862 LBA 09177AE1
69: Log Read Not OK
Code - 43 Track 0EC58.0.240 Sns 240 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
3B: Log Read Not OK
Log 3C - No Log on Disk
Log 3D - No Log on Disk
Log 3E - No Log on Disk
Code - 43 Track 0EC59.0.000 Sns 000 Rty FFFF.20.20FF Rtf 1862 LBA 09177AE1
3F: Log Read Not OK
Code - 43 Track 0EC59.0.205 Sns 205 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
43: Log Read Not OK
Log 20 - No Log on Disk
Log 47 - No Log on Disk
Log 4B - No Log on Disk
Log 48 - No Log on Disk
Code - 43 Track 0EC59.0.061 Sns 061 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
41: Log Read Not OK
Log 27 - No Log on Disk
Log 49 - No Log on Disk
Log 4A - No Log on Disk
Code - 43 Track 0EC5B.0.000 Sns 000 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
4D: Log Read Not OK
Code - 43 Track 0EC57.0.0C1 Sns 0C1 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
39: Log Read Not OK
Log 22 - No Log on Disk
Log 61 - No Log on Disk
Log 28 - No Log on Disk
Log 62 - No Log on Disk
Code - 43 Track 0EC55.0.000 Sns 000 Rty FFFF.20.20FF Rtf 1862 LBA 09177AE1
29: Log Read Not OK
Log 63 - No Log on Disk
Code - 43 Track 0EC5C.0.00A Sns 00A Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
59: Log Read Not OK
Code - 43 Track 0EC5B.0.275 Sns 275 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
56: Log Read Not OK
Code - 43 Track 0EC5E.0.1AF Sns 1AF Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
6F: Log Read Not OK
Total Cert Time = 00:00:00
ASCII logging off
Code - 43 Track 0EC5B.0.0A5 Sns 0A5 Rty FFFF.20.20FF Rtf 1822 LBA 09177AE1
!!! Adaptives corrupt !!!
AbEnd Test 4E
