标题: 应该不难 [打印本页]
作者: yinzongjie    时间: 2011-8-18 17:42
标题: 应该不难
小弟新手,一个对大家都小菜的问题难倒我了。
一显卡花屏,加焊gpu无果,便老老实实测了一番。七彩虹9600gt,512m,8个颗粒,从左到右m1m2m3M4M5M8M6M7
测试结果如下:
MATS version 4.100.3.  Testing G94 with 512 MB of memory.
Errors found.  Use .Status() or .PrintErrors() for more info.
This message will only appear once.
   LANE    EB0 READ ERR EB0 WRT ERR  UNKNOWN ERR
FBA[31: 0]           0            0            0
FBA[63:32]           0            0            0
FBB[31: 0]           0            0            0
FBB[63:32]           3     49104378            0
FBC[31: 0]           0            0            0
FBC[63:32]           0            0            0
FBD[31: 0]           0            0            0
FBD[63:32]           0            0            0
External Bank 0 Failing bits:
   B32 B33 B34 B35 B36 B37 B38 B39
Read    Error Count: 3
Write   Error Count: 49104378
Unknown Error Count: 0
BIT  FRONT WRITE  FRONT READ  UNKNOWN
B32     6368769           1           0
B32     6398504           0           0
B32     6361446           1           0
B32     6363357           0           0
B33     6279676           2           0
B33     6248912           0           0
B33     6254296           1           0
B33     6229782           0           0
B34     6341595           2           0
B34     6367881           0           0
B34     6365738           1           0
B34     6383399           0           0
B35     6215364           1           0
B35     6244188           0           0
B35     6231695           0           0
B35     6217246           0           0
B36     6347258           2           0
B36     6399640           0           0
B36     6363110           1           0
B36     6379470           0           0
B37     8398208           0           0
B37     8398208           0           0
B37     8398207           1           0
B37     8398208           0           0
B38     6391011           1           0
B38     6357798           0           0
B38     6361009           1           0
B38     6398725           0           0
B39     6244410           2           0
B39     6229827           0           0
B39     6184798           1           0
B39     6217826           0           0
