标题: ST常见错误维修一例(GC Seek Error 2 ) [打印本页] 作者: 夜雨十三天 时间: 2008-4-28 15:26 标题: ST常见错误维修一例(GC Seek Error 2 ) 从行内一个修硬盘的哥们哪里拿的一堆废盘,有一片160G的,感觉有维修价值,所以拿来玩玩~
开始是接电后,多等一会,指令上就没有反映了,所以直接加电就强制进F级,然后用一个M21,8.01的固件做F级引导,
回到T级后,AGE=60,直接N50,,22,AGE=50,输入#修改SN,修改后,N2,,22开始校准,开始几十秒后报GC Seek Error 2 !!!,校准停止!
这个时候用前几天论坛朋友说的方法,/8到8级后C20,出现SN后再从N2,,22开始跑,现在盘正在校准中...
F>
Age=60 Type=20 MxCyl=16358 MxHd=0 MxSct=294 BSz=0000 TCode=0000
T>N50,,22
Code - 33 Track 15050.0.000 Sns 000 Rty F7FF.FF.80FF Rtf 1800 LBA 00000000
T>Age=50 Type=20 MxCyl=16358 MxHd=0 MxSct=294 BSz=0000 TCode=0000
T>#
Enter Drive S/N 4JS0JN2T
Enter Packwriter S/N 123
T>N2,,22
T>(No valid SeaDex script in buffer.
Begin Test 02
ASCII logging on
Not Power Cycling
Not Power Cycling
Zone 00 Head 00 adaptives set to defaults
Zone 00 Head 01 adaptives set to defaults
Zone 00 Head 02 adaptives set to defaults
Zone 00 Head 03 adaptives set to defaults
Zone 01 Head 00 adaptives set to defaults
Zone 01 Head 01 adaptives set to defaults
Zone 01 Head 02 adaptives set to defaults
Zone 01 Head 03 adaptives set to defaults
Zone 02 Head 00 adaptives set to defaults
Zone 02 Head 01 adaptives set to defaults
Zone 02 Head 02 adaptives set to defaults
Zone 02 Head 03 adaptives set to defaults
Zone 03 Head 00 adaptives set to defaults
Zone 03 Head 01 adaptives set to defaults
Zone 03 Head 02 adaptives set to defaults
Zone 03 Head 03 adaptives set to defaults
Zone 04 Head 00 adaptives set to defaults
Zone 04 Head 01 adaptives set to defaults
Zone 04 Head 02 adaptives set to defaults
Zone 04 Head 03 adaptives set to defaults
Zone 05 Head 00 adaptives set to defaults
Zone 05 Head 01 adaptives set to defaults
Zone 05 Head 02 adaptives set to defaults
Zone 05 Head 03 adaptives set to defaults
Zone 06 Head 00 adaptives set to defaults
Zone 06 Head 01 adaptives set to defaults
Zone 06 Head 02 adaptives set to defaults
Zone 06 Head 03 adaptives set to defaults
Zone 07 Head 00 adaptives set to defaults
Zone 07 Head 01 adaptives set to defaults
Zone 07 Head 02 adaptives set to defaults
Zone 07 Head 03 adaptives set to defaults
Zone 08 Head 00 adaptives set to defaults
Zone 08 Head 01 adaptives set to defaults
Zone 08 Head 02 adaptives set to defaults
Zone 08 Head 03 adaptives set to defaults
Zone 09 Head 00 adaptives set to defaults
Zone 09 Head 01 adaptives set to defaults
Zone 09 Head 02 adaptives set to defaults
Zone 09 Head 03 adaptives set to defaults
Zone 0A Head 00 adaptives set to defaults
Zone 0A Head 01 adaptives set to defaults
Zone 0A Head 02 adaptives set to defaults
Zone 0A Head 03 adaptives set to defaults
Zone 0B Head 00 adaptives set to defaults
Zone 0B Head 01 adaptives set to defaults
Zone 0B Head 02 adaptives set to defaults
Zone 0B Head 03 adaptives set to defaults
Zone 0C Head 00 adaptives set to defaults
Zone 0C Head 01 adaptives set to defaults
Zone 0C Head 02 adaptives set to defaults
Zone 0C Head 03 adaptives set to defaults
Zone 0D Head 00 adaptives set to defaults
Zone 0D Head 01 adaptives set to defaults
Zone 0D Head 02 adaptives set to defaults
Zone 0D Head 03 adaptives set to defaults
Zone 0E Head 00 adaptives set to defaults
Zone 0E Head 01 adaptives set to defaults
Zone 0E Head 02 adaptives set to defaults
Zone 0E Head 03 adaptives set to defaults
Zone 0F Head 00 adaptives set to defaults
Zone 0F Head 01 adaptives set to defaults
Zone 0F Head 02 adaptives set to defaults
Zone 0F Head 03 adaptives set to defaults
Head Mask FFFF -
Read Bias - Head 0 1 2 3
A A A A
HiTemp Bias Head 0 1 2 3
A A A A
Head Mask FFFF - Switch to full int.
Spin Ready
Ref Trk Tan Timing Skew (h0 to h0) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h0) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h1) = 001C servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = 0018 servo clocks.
Ref Trk Tan Timing Skew (h0 to h2) = 001F servo clocks.
ID-OD Delta Timing Skew (h0 to h2) = 0010 servo clocks.
Ref Trk Tan Timing Skew (h0 to h3) = 003A servo clocks.
ID-OD Delta Timing Skew (h0 to h3) = 0028 servo clocks.
Calibrating Physical Track 0 on heads 0 thru 3
Calibrating Head 0 ...
GC Seek Error 2 !!!
!!! Adaptives corrupt !!!
AbEnd Test 02
T>/8
8>C20
(SN: 4JS0JN2T)
8>/
T>N2,,22
T>(ASCII logging off
Begin Test 02
ASCII logging on
Not Power Cycling
Not Power Cycling
Head Mask FFFF -
A A A A
A A A A
Spin Ready
