标题: 接收PADT,服务端请求断开本次连接 [打印本页]
作者: 彭亮亮    时间: 2011-7-10 12:57
我有一个客户他说过2天就掉线,重插路由器就可以上了,反复都是这样,用的TP LINK 406的,这个方法我查个很多资料看过别人发的贴都没有人解决,我也不知道是什么原因,是联通屏蔽吗,重插又能上,不过他用4M的联通的,接7个人上网。希望遇到过的解决的朋友帮个忙,多谢了。
这是系统日志里的:索引 日 志 内 容
1  8510:IPCP tx Ack,IP=705FC801;
2  8510:IPCP RX Nak,IP=1B261DF0;DNS1=D215C406;DNS2=DD055858;
3  8510:IPCP tx Req,IP=1B261DF0;DNS1=D215C406;DNS2=DD055858;
4  8510:IPCP RX Ack,IP=1B261DF0;DNS1=D215C406;DNS2=DD055858;
5  8510:PPP connection succeeded. 27.38.29.240 .
6  8510:got a correct dial mode[ NORMAL ], the dial interval is 3 s.
7  10244:DHCPS: request(): cid=1:0x002454bfa094; ip=192.168.1.103; send_dhcp(ACK) done.
8  10812:DHCPS: request(): cid=1:0x00e0621513f6; ip=192.168.1.101; send_dhcp(ACK) done.
9  13845:DHCPS: request(): cid=1:0x002454bfa094; ip=192.168.1.103; send_dhcp(ACK) done.
10  17445:DHCPS: request(): cid=1:0x002454bfa094; ip=192.168.1.103; send_dhcp(ACK) done.
11  21046:DHCPS: request(): cid=1:0x002454bfa094; ip=192.168.1.103; send_dhcp(ACK) done.
12  28474:DHCPS: request(): cid=1:0x00ea011346a1; ip=192.168.1.102; send_dhcp(ACK) done.
13  32074:DHCPS: request(): cid=1:0x00ea011346a1; ip=192.168.1.102; send_dhcp(ACK) done.
14  32123:接收PADT,服务端请求断开本次连接.
15  32124:PPPoE 开启自动连接.
16  32124:发送PADI,请求建立连接.
17  32124:PPPOE_TAG_SVC_NAME=null
18  32124:The first service name is accepted.
19  32124:PPPOE: receive HOST-UNIQUE tag.
20  32124:PPPOE: reserve AC-COOKIE tag.
21  32124:接收PADO,AC-Name=b1-s-gdsz-lgtl-77,AC-MAC=00233ED83918.
22  32124:发送PADR.
23  32124:接收PADS,Session-ID=0x1,AC-MAC=00233ED83918.
24  32124:LCP tx Req,MRU=05D4;Magic=001D3F32;
25  32124:LCP RX Req,MRU=05D4;Auth=C023;Magic=7DAFE99A;
26  32124:LCP tx Ack,MRU=05D4;Auth=C023;Magic=7DAFE99A;
27  32125:LCP RX Ack,MRU=05D4;Magic=001D3F32;
28  32125:PAP IDLE -> REQ.
29  32125:PAP tx Req.
30  32125:PAP:密码验证成功.
31  32125:IPCP tx Req,IP=00000000;DNS1=00000000;DNS2=00000000;
32  32125:IPCP RX Req,IP=705FC801;
33  32125:IPCP tx Ack,IP=705FC801;
34  32125:IPCP RX Nak,IP=1B261F82;DNS1=D215C406;DNS2=DD055858;
35  32125:IPCP tx Req,IP=1B261F82;DNS1=D215C406;DNS2=DD055858;
36  32125:IPCP RX Ack,IP=1B261F82;DNS1=D215C406;DNS2=DD055858;
37  32125:PPP connection succeeded. 27.38.31.130 .
38  32125:got a correct dial mode[ NORMAL ], the dial interval is 1 s.
39  39244:DHCPS: request(): cid=1:0x00ea011346a1; ip=192.168.1.102; send_dhcp(ACK) done.
40  40120:DHCPS: request(): cid=1:0x00e04ca82a89; ip=192.168.1.100; send_dhcp(ACK) done.
H-Ver = R406 081C3113 : S-Ver = 3.7.9 Build 101020 Rel.56886nB
L = 192.168.1.1 : M = 255.255.255.0
Mode = PPPoE : W = 27.38.31.130 : M = 255.255.255.0 : G = 27.38.31.130
Free=1022, Busy=2, Bind=0, Inv=0/74, Bc=0/5, Dns=58, cl=27, fc=0/0, sq=0/0
作者: 剑波    时间: 2011-7-10 15:11
路由器过热或者老化
作者: yzz163    时间: 2011-7-11 11:57
写的很明确。
你啥应用?要求如此严格,不允许掉线,银行的要求也么这么严格呀?拉专线吧。
作者: 56625079    时间: 2011-7-11 13:21
ADSL的服务端(电信或网通机房)或客户端(猫这边)所接收到的校验错误次数达到一定值,就会请求断开的。
一般就出现这个提示:32123:接收PADT,服务端请求断开本次连接.
两天才断一次线,很正常了。可以把路由设为自动连接就行了。
还有就是加强一下猫的散热和路由的散热,断线也会减少。我以前的猫烫手,一天断一次线,后面我拆开猫和路由,给芯片加了散热片,把通风孔扩大,现在断线次数明显减少了。
断线一般就是猫和路由太热,不稳定;或是线路老化,离电信机房太远造成的
