标题: ST的盘跑SF到31 [打印本页]
作者: 馨然电脑维修    时间: 2008-4-19 21:58
标题: ST的盘跑SF到31
现在跑到age=31了,已经将近六个小时了,请问这属不属于正常呀??但是查lba还在变
Temp Diode 595A
( 39 C )
Temp Diode 5A5A
                          Power Cycling
ASCII logging off
OkEnd Test 25
Begin Test 31
                      Not Power Cycling
EP=0, TA=0, HiGain=0, OTRd=0, Early Rd=0, Splash=0, Reload=0, NPML=0, MRBias=0
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=0, ECC 1=0, ECC 0=0
Data=00, Write=32, ID=FF
Age=31 Type=20 MxCyl=16358 MxHd=0 MxSct=44C BSz=0000 TCode=0000
Pgm=31 Trk=0B2FE(0B2FE).0(0).0DC(000) Zn=F Err=00 ErCt=0034 Hlth=0008 CHlth=0000 Ready LBA=0181B3A4
Pgm=31 Trk=0B2FE(0B2FE).0(0).0DC(000) Zn=F Err=00 ErCt=00CC Hlth=0008 CHlth=0000 Ready LBA=0181B3A4
Pgm=31 Trk=0B3C7(0B3C7).0(0).0DC(000) Zn=F Err=00 ErCt=00B2 Hlth=0008 CHlth=0000 Ready LBA=01865F08
Pgm=31 Trk=0B3E7(0B3E7).0(0).0DC(000) Zn=F Err=00 ErCt=00CB Hlth=0008 CHlth=0000 Ready LBA=018718A8
Pgm=31 Trk=0B3F8(0B3F8).0(0).0DC(000) Zn=F Err=00 ErCt=0073 Hlth=0008 CHlth=0000 Ready LBA=01877D34
Pgm=31 Trk=0B405(0B405).0(0).0DC(000) Zn=F Err=00 ErCt=0050 Hlth=0008 CHlth=0000 Ready LBA=0187CB68
Pgm=31 Trk=0B409(0B409).0(0).0DC(000) Zn=6 Err=00 ErCt=00DC Hlth=0008 CHlth=0000 Ready LBA=0187E454
Pgm=31 Trk=0B457(0B457).0(0).0DC(000) Zn=F Err=00 ErCt=00A7 Hlth=0008 CHlth=0000 Ready LBA=0189B8B0
Pgm=31 Trk=0B511(0B511).0(0).0DC(000) Zn=F Err=00 ErCt=009D Hlth=0008 CHlth=0000 Ready LBA=018E0B90
Pgm=31 Trk=0B5C1(0B5C1).0(0).0DC(000) Zn=F Err=00 ErCt=00DA Hlth=0008 CHlth=0000 Ready LBA=019224DC
Pgm=31 Trk=0B932(0B932).0(0).0DC(000) Zn=F Err=00 ErCt=00D3 Hlth=0008 CHlth=0000 Ready LBA=01A6B7F9
Pgm=31 Trk=0BACD(0BACD).0(0).0DC(000) Zn=F Err=00 ErCt=0021 Hlth=0008 CHlth=0000 Ready LBA=01B05615
Pgm=31 Trk=0BB40(0BB40).0(0).0DC(000) Zn=F Err=00 ErCt=00B5 Hlth=0008 CHlth=0000 Ready LBA=01B303DD
Pgm=31 Trk=0BB55(0BB55).0(0).0DC(000) Zn=F Err=00 ErCt=00CF Hlth=0008 CHlth=0000 Ready LBA=01B38231
Pgm=31 Trk=0BC25(0BC25).0(0).0DC(000) Zn=F Err=00 ErCt=00B6 Hlth=0008 CHlth=0000 Ready LBA=01B86049
Pgm=31 Trk=0BC4E(0BC4E).0(0).0DC(000) Zn=F Err=00 ErCt=00B4 Hlth=0008 CHlth=0000 Ready LBA=01B95611
Pgm=31 Trk=0BCA9(0BCA9).0(0).0DC(000) Zn=F Err=00 ErCt=00A4 Hlth=0008 CHlth=0000 Ready LBA=01BB76E9
Pgm=31 Trk=0BCAA(0BCAA).0(0).0DC(000) Zn=F Err=00 ErCt=0087 Hlth=0008 CHlth=0000 Ready LBA=01BB7CED
Pgm=31 Trk=0BD44(0BD44).0(0).0DC(000) Zn=F Err=00 ErCt=006A Hlth=0008 CHlth=0000 Ready LBA=01BF1A79
Pgm=31 Trk=0BE5F(0BE5F).0(0).0DC(000) Zn=F Err=00 ErCt=00C1 Hlth=0008 CHlth=0000 Ready LBA=01C5BD75
Pgm=31 Trk=0BF5C(0BF5C).0(0).0DC(000) Zn=F Err=00 ErCt=0092 Hlth=0008 CHlth=0000 Ready LBA=01CBADB1
Pgm=31 Trk=0C242(0C242).0(0).0DC(000) Zn=F Err=00 ErCt=0034 Hlth=0008 CHlth=0000 Ready LBA=01DD12FA
Pgm=31 Trk=0C386(0C386).0(0).0DC(000) Zn=F Err=00 ErCt=00D2 Hlth=0008 CHlth=0000 Ready LBA=01E4AC9A
Pgm=31 Trk=0C607(0C607).0(0).0DC(000) Zn=F Err=00 ErCt=00B5 Hlth=0008 CHlth=0000 Ready LBA=01F3BAE6
作者: 长治维修    时间: 2008-4-19 22:03
正常的.等吧,一般要很长时间的,和你的盘的大小,和坏道的多少有关的.
作者: 馨然电脑维修    时间: 2008-4-19 22:05
现在已经开始到13个小时了,在这里就已经停了6个小时了,还要等多长时间呢?这个是40G的盘。
作者: 火速挪移    时间: 2008-4-19 22:11
缺陷很少的ST盘  40G大概8个小时
缺陷多的就不好说了
挂他72小时还没完
就N50,,22
写ATA
搽一次看什么情况在打算
作者: 馨然电脑维修    时间: 2008-4-19 22:16
原帖由 火速挪移 于 2008-4-19 22:11 发表
缺陷很少的ST盘  40G大概8个小时
缺陷多的就不好说了
挂他72小时还没完
就N50,,22
写ATA
搽一次看什么情况在打算
我现在断电从进吗??
就N50,,22
写ATA吗??
作者: 火速挪移    时间: 2008-4-19 22:17
72小时后还不没做完的话在断电从进吗
就N50,,22
写ATA
作者: 馨然电脑维修    时间: 2008-4-19 22:19
还要等48小时啊。 :L 再从进的话还是以安全模式进呗。这个硬盘如果从进的话又到F级啦
作者: cqzuo    时间: 2008-4-19 22:19
此盘坏道太多了。结果就是做到丢失LOG。
作者: 馨然电脑维修    时间: 2008-4-19 22:20
丢失log会出现什么现象呢,又该怎么样处理??
作者: 网络飞花    时间: 2008-4-20 02:19
碰到这样的盘我总是二个办法处理,不一定正确,不过结果对于我来说,还能接受
  1 测试31(你可以看看31流程是做什么用的^_^)的时候本来时间就长,等一下去也可以,也没有看到报错,LBA地址也有变化,说明测试还在继续,
  2 掉电再加电,让它完成,我碰到有时做这个流程很慢的时候,重新加电,速度会变快,不太理解,不过这是事实啊,相信也有人碰到过吧
作者: 殷利军    时间: 2008-4-20 05:32
提示: 作者被禁止或删除 内容自动屏蔽
作者: 砍头    时间: 2008-4-20 06:56
大家給的建議都不錯
不過還沒試過
有機會試試看
感謝大家分享喔
作者: 馨然电脑维修    时间: 2008-4-20 08:35
原帖由 网络飞花 于 2008-4-20 02:19 发表
  1 测试31(你可以看看31流程是做什么用的^_^)的时候本来时间就长,等一下去也可以,也没有看到报错,LBA地址也有变化,说明测试 ...
1:31流程怎么看是什么做的呢?
2:我的这个盘是不认盘的,也不敢断电啊,一断电进来怕又是F级了,还要从头做啊。
作者: 馨然电脑维修    时间: 2008-4-20 08:36
原帖由 殷利军 于 2008-4-20 05:32 发表
做校盘的时候要看一下大概时间E4E.这样你也能控制一下时间
请问一下E4E是时间怎么看呢??
作者: cqzuo    时间: 2008-4-20 09:15
E4E显示的是是上次做的,只可以参照。。
作者: 馨然电脑维修    时间: 2008-4-20 10:39
这是第一次做怎么能知道E4E呢??在哪里显示呢??
作者: 夜雨十三天    时间: 2008-4-20 12:46
没事 硬盘的状态没问题!
应该让他继续跑!
作者: 路人乙    时间: 2008-4-20 13:00
我的K4也正在跑这个,跑N久了,还是31
再等等
作者: 馨然电脑维修    时间: 2008-4-20 17:22
一共等了不到40个小时,终于做成功了,现在已经可以认盘了,但是为什么还有个别的红块呢,就是擦完了不一定什么时候还会在某个地方出,而且扫到红块的地方硬盘就吱一声,是不是这个硬盘还是用不住啊。
作者: 馨然电脑维修    时间: 2008-4-20 17:30
怎么现在找出来不少红块了呢,第一次扫描还没有呢 :'( :'( :'( :'(
作者: 网络飞花    时间: 2008-4-20 20:05
希捷成功做完SF的话还有红绿的真的很少,可以再偿试做一次,如果还有,就是SA区和磁头不稳定
作者: 馨然电脑维修    时间: 2008-4-20 22:22
这个是有时间有红块,有时候扫描就没有红块啦。 还要再做一次哦
作者: tyki    时间: 2008-4-21 02:52
你的盘应该还没跑玩sf  等着把  还有啊。千万别断电。。要写了ata在断电 不然 就麻烦了。我就这样搞死一个盘。。
作者: 馨然电脑维修    时间: 2008-4-21 07:57
都已经到4f了,还没跑完吗,而且ata也已经写回去啦。
